Old Jan 04, 2012, 04:59 PM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
Originally Posted by bigtruck169 View Post
anyone try duct fan? Should mount it on top or mid of plane?
well i have build two of them , and i put that in middel on the place where you have motor right now.
F22-EDF (4 min 1 sec)
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Jan 04, 2012, 06:39 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
I wonder if anyone will have a 2212 at the ama show this weekend ?
Dennis Everett is offline Find More Posts by Dennis Everett
Old Jan 04, 2012, 07:21 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Look for RC Hot Deals. He's in California and usually goes to all the big shows.
EDIT - Just checked the vendor list, he'll be in booth 403.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 05, 2012, 10:27 AM
jeffsch is offline
Find More Posts by jeffsch
Jer. 29:11
jeffsch's Avatar
United States, WA, Snohomish
Joined Oct 2009
FWIW, HobbyPeople has a 2212/09 motor on sale for $17 (and will be at the AMA show):
http://www.hobbypeople.net/index.php...-hardware.html
jeffsch is offline Find More Posts by jeffsch
Old Jan 05, 2012, 12:04 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
That's not a good motor for this plane, the kv is too low. The Suppo 2212-6 2200kv motor is the one you need for this.
Pat
Old Jan 05, 2012, 02:11 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
Foam paint???
Built my F-22 out of OWENS CORNING [ Foamular] Pink foam.
Tried the Krylon spray paint. DOES NOT WORK.
Does anyone know of an paint that will work on theis foam.
You will make fun of my PINK plane if I do not paint it
SARG5
SARG5 is offline Find More Posts by SARG5
Old Jan 05, 2012, 02:35 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Testors, and Testors Model Master spray paints work great.
Pat
Old Jan 05, 2012, 03:03 PM
jeffsch is offline
Jer. 29:11
jeffsch's Avatar
Joined Oct 2009
Pat
Pat, thanks for the quick assessment! ::thumbs up::
Old Jan 05, 2012, 06:05 PM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Sarg, Testor's or any water-based paint.
Don
beemerdon is offline Find More Posts by beemerdon
Old Jan 05, 2012, 06:51 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
NOW THE FOLLOW UP QUESTION FOR THE PAINT
Where do I find Testors Modle Masters spray paint ???????????????????????
SARG5
Old Jan 05, 2012, 06:59 PM
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
I don't know but you find little half-pints of water-based paint at Lowe's and I get some colors at the local craft store. It's funny when I go into Michael's or Hobby Lobby as I am usually the only male in the place! Craft stores also have some glues we can use, and lots of stick on letters and stencils.
Don
Old Jan 05, 2012, 07:12 PM
Joined Mar 2002
I use craft paint from Michaels , mix 50/50 with windex , works pretty good but you need a sprayer , used it for this today ...
Old Jan 05, 2012, 08:46 PM
Byrdman is offline
Find More Posts by Byrdman
Winter Haven FL
Byrdman's Avatar
Joined Dec 2003
Originally Posted by gatorlynch View Post
Jeff -
Thanks. I use CA, epoxy, Gorilla Glue, hot glue & 3M High Strength 90 Spray Adhesive on coro, depending on the application. It's important to prep the surfaces properly.
On this build, the primary glue was Gorilla Glue on the tabs & slots of the airframe. The K-F step (upper wing piece) was attached to the main wing with 3M. Epoxy was used for the plywood motor mount & wood support blocks.
PM me if you want or need more info - I'd be happy to help.
Tim
I use to build SPADS out of coro. How are you prepping the coro? I use to rough it up with some sandpaper, but I also used paint thinner to take the top protective coating off too. Nice plane you did a good job. If my foam one doesnt hold up, I will try a coro one next.
Byrdman is offline Find More Posts by Byrdman
Old Jan 06, 2012, 07:39 AM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
Neet paint job DENNIS.
Thank all of you for your paint suggestions. I did go on the
www.testors.com site. Found a hobby store through them that is about 35 miles from me. They do not have a wide range of ACRYLIC colors. But will get me by.
KEEP THEM FLYING
SARG5
BUILDING, PAINTING, FLYING AND SEEING THE COUNTRY WE DEFEND
Old Jan 06, 2012, 11:21 AM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
This is my first Raptor to build and I have a FC2812 motor with a 7x6 prop about 23 oz of thrust. What do yall think? workable?
RTF Thumper is offline Find More Posts by RTF Thumper
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
