Old Jan 01, 2012, 10:12 AM
y2k6vette is offline
Find More Posts by y2k6vette
Sandy, UT
Joined Nov 2009
Don,
Thanks for the Depron size info....I'll get some ordered from Grayson....I believe they also have the motor/esc combo I need.
y2k6vette is offline Find More Posts by y2k6vette
Old Jan 02, 2012, 10:46 AM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
If you get the bigger sheets from rc foam you can make the wing in one piece , they are a little narrower than the plane so you loose about a inch of wing span , but the 4 ive made all fly fine this size , i hate seaming sheets together .....
No. 4 has rudders and i think its worth the little extra work it takes to put them on , # 3 was 13 oz and # 4 is 13.9 oz , does some pretty quick snap rolls and other weird stuff with them , also helps in high alpha flight ...
I made the one flow by the bigger guy in the video above ...
Dennis Everett is offline Find More Posts by Dennis Everett
Old Jan 02, 2012, 10:49 AM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Or you can turn the template sideways for the full wing, and cut the nose section separately. Once the nose and wing are joined, the intake sides and fuse pieces provide enough strength to hold everything together.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Jan 02, 2012, 01:10 PM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Pat
That's what I did; my seam is just forward of the wing break and is supported by the 'fuselage'. It looks like I may have added two little pieces to the tips as my ws is 28".
Don
beemerdon is offline Find More Posts by beemerdon
Old Jan 03, 2012, 12:40 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
F-22 Foam
Here are a couple pictures of my F-22 ,1/2 in foam. This is my first scratch built. Plans only from 6mm.
Ordered the power set up yesterday from headsuprc.
Motor - Power Up 400 Zoom
ESC --- HURC 40A ESC
Prop -- EMP 6x4E
Will power up with my 11.1 v 2100 Lipo battery.
What say all of you on my first Build. Will paint them SOME WHAT LIKE THE [BLUE ANGLES].
SARG5
SARG5 is offline Find More Posts by SARG5
Old Jan 03, 2012, 03:06 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
SARG5 again
On the above Scratch Built planes out of 1/2.
Do you need to bevel the TRAILING EDGE of the control surfaces? Or can you leave them
squared off ?
Yes, I am beveling all of the LEADING EDGES.
SARG5
Old Jan 03, 2012, 03:16 PM
bigtruck169 is online now
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
anyone try duct fan? should mount it on top or mid of plane?
bigtruck169 is online now Find More Posts by bigtruck169
Old Jan 03, 2012, 03:48 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Originally Posted by SARG5 View Post
SARG5 again
squared off ?
SARG5
You actually don't need to round any edges, but if you do, just do the leading edges and don't worry about the trailing.
Pat
Old Jan 03, 2012, 03:50 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I know this is a very large thread, but there are several posts about using EDF and where they were mounted. You just need to search the thread.
Pat
Old Jan 03, 2012, 04:05 PM
nrg2go is offline
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
Pat
Like Pat said, there's no need to make things aerodynamic. Its a flying plank after all and even at scale it's not busting the sound barrier. I have shaped the leading edges because it looks better but the trailing edges (tailerons, ailerons and rudders) are all blunt.
nrg2go is offline Find More Posts by nrg2go
Old Jan 03, 2012, 05:21 PM
SARG5 is offline
SARG5
SARG5's Avatar
Joined Oct 2009
I am now wondering if I have made the Aile. too narrow. I made them about 1 1/4. Everupme else looks like the have made theirs about 1 1/2to 1 3/4.
What say you all
SARG5
Old Jan 03, 2012, 05:52 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I say since it flies fine without ailerons at all, leave them be. Some is better than none, even though none is required.
Pat
Old Jan 04, 2012, 03:19 PM
Joined Mar 2002
Pat, didnt you use a scoripion on one of thease jets ? If so , which one ?
Old Jan 04, 2012, 04:12 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
I did originally, I think it was a 2205-32. But once I found the 2212-6 I never went back to anything else.
EDIT - Yep, here was my oiginal post with my setup. Flew good with this, but flies better with the 2212-6.
http://www.rcgroups.com/forums/showp...&postcount=256
Pat
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
