Old Sep 12, 2011, 08:17 AM
RCSquale is offline
Find More Posts by RCSquale
Sometimes it work some don't
RCSquale's Avatar
╔mirats arabes unis, Ras el Kha´mah, Ras Al-Khaimah
Joined Oct 2010
I hear you my friend this is why I'm planning to fly it again unless I have at least a 2200 kva motor and healtier battery! Cheers for that!
RCSquale is offline Find More Posts by RCSquale
Old Sep 12, 2011, 05:55 PM
Captain Bravo is offline
Find More Posts by Captain Bravo
USA, MI
Joined Jul 2008
I need to place another hobby king order soon. Any recommendations for a motor from there that would give more thrust and speed than a 2212-6?
Planning on a standard size build so 6" prop max.
Captain Bravo is offline Find More Posts by Captain Bravo
Old Sep 12, 2011, 10:23 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Well, speed is sorta limited on this bird due to the inlet dividers blocking a lot of airflow. I think the only thing you can do to go faster is leave them off.
If you want speed, try the Saab Draken from Marcel or the Nico Hobbies Concorde. Both do about 75mph on the 2212-6 system.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old Sep 13, 2011, 02:41 AM
nrg2go is offline
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
Pat
My F22s (100% & 65%) do not have inlet plates. Didn't see the need and I thought airflow was more important than looks.
I don't think you could go past the 2212-6, if you can't get a LSSPJ motor.
nrg2go is offline Find More Posts by nrg2go
Old Sep 13, 2011, 05:54 AM
USA, MI
Joined Jul 2008
Actually I have the plans cut for the Draken and plan to build that one first.
The F-22 is one of my favorite planes, and following the Draken I want to build one these. I am not opposed to just buying another 2212-6, but if there was a bigger/better/faster setup for cheap...
Old Sep 21, 2011, 04:16 PM
jsweari2 is offline
Find More Posts by jsweari2
Joined Mar 2011
Here is my 50% F-22. The whole plane is made from 6mm depron foam. It is running on Hobbykings 18-11 2000kv brushless, 10 amp ESC, and two 3.7 gram servos. I have 3 different batteries to run on this plane. With a 350mah 3s AUW= 97grams, 500mah 3s AUW= 108grams, and 800mah 3s AUW= 126 grams. The 500mah battery gives this plane unlimited vertical (limited due to the fact i have no rudder to keep it straight) and about 5 min flight times. I have not yet tried the 800mah yet. I love this little plane and its pretty quick for it size. Speeds are probably close to 40 mph. I would highly recommend building it. The plane next to it in the pic is my full size f-22 by rcpowers. Its a fun 80mph jet on the super mega jet V2. Its running on a 2200mah 4s putting out just over 1000watts and 40 oz of thrust. HOLD ON!!!!
jsweari2 is offline Find More Posts by jsweari2
Old Sep 21, 2011, 07:49 PM
jsweari2 is offline
Joined Mar 2011
just flew 2 of each batter and I think the 500mah is the best size of the three. It gives a 1:1 ratio for thrust for good performance. I was getting about 7 mins of hard flying and the motor came down a little warm and the battery was at about 3.8V per cell. The 800mah battery was a little too much for the ESC. It caused my ESC to go into thermal shut down and the plane crashed with minor damage to the nose. That battery is ok if you take it easy and it will give over 10 mins of flying. The 350mah was light and fun but you sacrifice on the flying time. Well thats my review of this plane. It has been a blast to fly and will continue to be a blast for a looong time.
Old Oct 02, 2011, 11:40 PM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Re-maiden of my F-22
Well since I cap sized my Polaris in the sea lately with a 2200kva and 2200mAh battery and 40 amps ESC... Fortunately when I reached home I passed everything under soft water and let them dry outside for the night.
To my surprise in the following morning, I hooked up everything together and all was fine... So I decided to place these electronics on the F-22...
Maid 2 flight already and the video is uploding on Vimeo, will pass the link as soon as available.
Here are some pictures:
Old Oct 03, 2011, 12:10 AM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Here is my morning flight video:
F-22 Morning flight (4 min 47 sec)
Old Oct 03, 2011, 09:25 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I managed to flip my Polaris and got it wet too. But all survived.
The motor even ran submerged !
You must be at an Oasis !!! :-)
Bob
birdofplay is online now Find More Posts by birdofplay
Old Oct 03, 2011, 01:02 PM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Here is my latest video with some rolls and loops done! great fliyer, fun parkjet
Moves with F-22 (5 min 44 sec)
Old Oct 04, 2011, 11:20 AM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Wow - those are some nice tight loops. Looks like fun. Nice airstrip too.
boardman is offline Find More Posts by boardman
Old Oct 04, 2011, 12:32 PM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Cheers buddy, made an inboard cam video by the end o the afternoon but I still need to edit it. It was a bit windy today to have nice and level flight but I dhould be able to manage something out of it...
Next trial I will need to place my cam slightly lower to have a better ground view.
Old Oct 04, 2011, 04:20 PM
RCSquale is offline
RCSquale's Avatar
Joined Oct 2010
Here is a new video of my F-22, mix between inboard and ground footage...
Hope you will enjoy it!
It was a bit windy so the inboard video is not that steady.
Mix inboard and ground footage F-22.wmv (4 min 48 sec)
Old Oct 07, 2011, 04:10 AM
dmaaero is offline
Find More Posts by dmaaero
dmaaero's Avatar
United States, NC, Jacksonville
Joined Jan 2010
You can allways put the e-flite six series 2700kv motor on it, run a 6x5.5 prop on 3s 2200mah flight times are short but vertical is unreal !!!!! Makes for a lot of fun harriering back down from 600 feet. You can put that motor on a stryker motor mount, the prop won"t hit the ground an you can take off without hand launching.......... or you can just stand it on the tail in the bed of your truck, an take off vertical.
dmaaero is offline Find More Posts by dmaaero
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
