Old Jun 21, 2011, 09:40 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
If it is working FOR you then DONT STOP.
My mileage may be different for any number of reasons..
I became very suspicious of connectors in general after that Eye Opener.
Maybe my PP connectors were old or corroded as I soldered my wires to em.
Hey with good connectors I BLEW two 30A esc's today !
The HK motors had C-clips and they were BINDING when I got down.
Very P!$$$ed just now :-(
Hey at least My wor torn battle hardened F-22 is still flying well !
L8r
bob
birdofplay is online now Find More Posts by birdofplay
Old Jun 22, 2011, 03:17 AM
joeblack is offline
Find More Posts by joeblack
Joined Jun 2010
Thanks Bombay, I am working more on finishing, the canopy is almost done, will update the pics.
Originally Posted by Bombay View Post
BTW - Joe Black, that build is looking great. I wouldn't worry about spending some extra time shaping it. It pays off in the end. I spent a lot of time painting mine and putting in lights...and it is still flying approx 1.5 years later.
joeblack is offline Find More Posts by joeblack
Old Jun 22, 2011, 05:52 AM
nrg2go is offline
Find More Posts by nrg2go
Aussie, Aussie, Aussie!
nrg2go's Avatar
Australia, NT, Katherine
Joined Apr 2009
Originally Posted by birdofplay View Post
Well ...
I used to think that also HOWEVER ...
I have an old ICE charger which has a Graphic display during charge.
It autozooms in on the charger ramp and shows the slope.
Well when I pick up the pak during charge and I see JAGGY SPIKES in the graph
I have to investigate.
I found my Power poles to be "Noisey" when Shaken ( not stirred ).
So I have since moved on to 3.5mm banana types from HK or similar.
I started using the 3.5mm sets with the Blue matching housings.
They are a pain if you get ANY solder on the outside of the barrel
as they then become difficult to Snap into the housing.
Otherwise I like em.
But lately I'm thinking that since the latest Lipos Paks are coming with the YEllow
connector I might have to eventually go to that style.
Yeh, I use the blue HK EC3s. Converted my entire fleet over to them before HK produced and started shipping the LiPos with the yellow XT60 connectors.
A trick with the EC3s is to get your self a small blow torch. Make a holding plate (something that won't burn) with holes for the male and female connectors. Tin the wire ready then put the male or female connector in the holding plate and torch from below, add some solder in the connector then put the pre-tinned wire into the connector. Don't remove the torch because if you do you will end up with a cold joint. Keep the torch heat there until the solder in the wire re-flows with the solder in the connector. Remove the heat and let cool, job done and no solder on the outside if you have been careful.
I would also recommend you buy a pair of cir clip pliers for disconnecting. One should never disconnect by pulling on the wires themselves. You can place the plier tips between the two connectors to separate them easily and quickly.
nrg2go is offline Find More Posts by nrg2go
Old Jun 22, 2011, 06:54 AM
batusaix is offline
Find More Posts by batusaix
User Extraordinaire
Davao, Philippines
Joined Apr 2007
My battle scarred first fighter poses beside a newbie yet to fly. Thought I'd take a side by side pic for comparison.
batusaix is offline Find More Posts by batusaix
Old Jun 22, 2011, 11:13 AM
Park_Flyer is offline
Find More Posts by Park_Flyer
Smarter than a 5th grader.
Park_Flyer's Avatar
United States, VA, Virginia Beach
Joined Jun 2005
That F-35 looks pretty slick. Is that an extra fin on top?
Park_Flyer is offline Find More Posts by Park_Flyer
Old Jun 22, 2011, 01:13 PM
batusaix is offline
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Yeah. I guess its supposed to be an aerial antenna. F-22 doesn't have it, the F-35 does. Looks good in breaking the profile lines though.
Thanks Park Flyer. I hope it performs as good as the F-22.
Old Jun 26, 2011, 05:57 PM
zanarkand is offline
Find More Posts by zanarkand
zanarkand's Avatar
Italia, Lazio, Gaeta
Joined Jan 2011
I can reach the moon with this
F22 TomHe fpv Gaeta, Calegna (5 min 24 sec)
zanarkand is offline Find More Posts by zanarkand
Old Jul 03, 2011, 02:33 AM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, CO, Aurora
Joined Nov 2007
Originally Posted by nrg2go View Post
Paint job done on my 65%. Ready for maiden. I may put some black bars on each wing underside.
No Stop! Please!
wingspan100 is offline Find More Posts by wingspan100
Latest blog entry: I really like this video:
Old Jul 03, 2011, 12:08 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Reasonable distance? You mean like 5km?
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jul 03, 2011, 01:01 PM
Park_Flyer's Avatar
Joined Jun 2005
That's a pretty slick scheme - hi-viz camouflage .
I would put something on the bottom - just the shock of NOT seeing the top could render it invisible
Old Jul 04, 2011, 06:19 AM
nrg2go is offline
nrg2go's Avatar
Joined Apr 2009
Yeh I accidentally turned left instead of right during the maiden of my little 75% Polaris the other day and flew across the sun!! I thought oh nooooooo
Hang on I can still see it
http://www.rcgroups.com/forums/showt...laris&page=792
I guess it is overkill given the 65% F22 isn't going to get too far away from me, but it is different.
Old Jul 16, 2011, 03:15 AM
nrg2go is offline
nrg2go's Avatar
Joined Apr 2009
16g motor http://www.hobbyking.com/hobbyking/s...idProduct=6311
Zippy 500mAh 3S 20C batt
Cut down 5" prop (approx 4.5")
HK 10A ESC
6Ch HK 2.4G Rx
AUW 205g/7.2oz
Maidened today and flies great!
A little under powered for my liking but still powers out of trouble. Just what I need for down the local park when I can't be bothered driving to the club field. Getting around 10mins flying time with 20% left in the pack.
Will try to get some vid at some stage. The GoPro tends to make small things disappear due to the wide angle.
Old Jul 16, 2011, 07:52 AM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Looking forward to pics and video!
At this size, I prefer this motor:
http://www.hobbyking.com/hobbyking/s...idproduct=5432
With a 10A ESC, GWS 4530 prop and a 3S 850 pack. She really comes alive on this setup.
Pat
Old Jul 16, 2011, 08:55 AM
nrg2go is offline
nrg2go's Avatar
Joined Apr 2009
Pat
Pics are at 2288 above. Vid to follow when I can.
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 01:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 05:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 10:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 02:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 09:39 PM
