Old Apr 24, 2011, 08:11 AM
batusaix is offline
Find More Posts by batusaix
User Extraordinaire
Davao, Philippines
Joined Apr 2007
I got 13 minutes of flight with my F-22. Lipo used was a 2S 1000mah Turnigy.
I was pretty high up, I swear I caught some thermals. I could barely see it, it helps that my F-22 is red. Just floating with the wind.
When I got down & charged my lipo, it read ZERO. No matter, that was a long flight even by F-22 standards. My multi role(except go fast) plane.
batusaix is offline Find More Posts by batusaix
Old May 02, 2011, 08:38 PM
Runnikee is offline
Find More Posts by Runnikee
Crash and burn, huh Mav?
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
I recognize some names on here from a couple of my other builds, so hopefully you guys can help me out. I'm going to be running 3S 2200 mAh batts. Can anyone recommend a motor, prop, esc combo for this plane. I'd really like to go through headsuprc if possible. I'm not a fan at all of Graysons and have had nothing but good luck with headsup. Any help is appreciated.
Thanks in advance!
Runnikee is offline Find More Posts by Runnikee
Old May 02, 2011, 08:57 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
The tried and true standard for this plane is a 2200kv motor and 6x4 prop on 3s. Most places label the motor as a 2212-6...this looks like headsuprc's equiv.
http://www.headsuprc.com/servlet/the...oom/Categories
http://www.headsuprc.com/servlet/the...C-6-x-4/Detail
Bombay is offline Find More Posts by Bombay
Old May 02, 2011, 10:15 PM
Runnikee is offline
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
Thanks a lot, Bombay! I appreciate the info
Old May 03, 2011, 11:32 AM
Led Zepplin is online now
Find More Posts by Led Zepplin
Fly, dangit!!!
Led Zepplin's Avatar
Little Rock, AR USA
Joined Jan 2007
66% f22
Hello all - I spend most of my time over in the scale forum, but have just recently gotten into the profile foamies. It's nice to build something in a few nights, especially since it flies so well! I found Tom's plan and re-sized it by 66% (about 18" WS). It uses elevons only, but still will roll and loop no problem. I did mod the plan a bit since it's built from 3mm gray Depron, I doubled the layers at the nose and added a small amount of weight in the nose to balance it. All in all I spent about 40 bucks on the plane, RTF. Not bad for such a fun plane!
J. B.
IMG_1122.MOV (2 min 26 sec)
Led Zepplin is online now Find More Posts by Led Zepplin
Old May 03, 2011, 07:14 PM
ronaldf is offline
Find More Posts by ronaldf
ronaldf's Avatar
Oakhurst, CA
Joined May 2006
J. B.
Like this:
http://www.rcgroups.com/forums/showthread.php?t=795691
ronaldf is offline Find More Posts by ronaldf
Old May 03, 2011, 10:30 PM
Fly, dangit!!!
Little Rock, AR USA
Joined Jan 2007
Ha! Yeah, I knew it wasn't an original idea by any stretch, but it is a nice design that has been proven over and over it seems. I've got plenty of Depron left so I think I'll try the MiG29 as a dogfighting partner!
J. B.
Old May 09, 2011, 03:58 PM
AH-56 is online now
Find More Posts by AH-56
AH-56's Avatar
USA, CA, Canyon Country
Joined Apr 2009
Finally finished mine Still waiting on a 1800mah 30c before the first flight.
AH-56 is online now Find More Posts by AH-56
Old May 09, 2011, 04:13 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Sweet. Don't fly that against a grey sky. lol
Old May 09, 2011, 05:44 PM
GBazz is offline
Find More Posts by GBazz
Joined Sep 2010
What is the best way to cut out this stuff ?.Looks like fun
GBazz is offline Find More Posts by GBazz
Old May 09, 2011, 05:54 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
If you're cutting depron, a very sharp hobby knife (like an Xacto or similar) is best. I typically go through 2 blades cutting one of these out.
Just print the plans, cut out the templates, place over foam, then go to town!
Pat
crxmanpat is online now Find More Posts by crxmanpat
Old May 09, 2011, 06:10 PM
AH-56 is online now
AH-56's Avatar
Joined Apr 2009
I took the easy way out
http://www.6mmflyrc.com/quick-build-series/
Old May 09, 2011, 09:46 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Yeah, it's nice to have a place to go if you don't feel like cutting foam. I build a new mini F-22 for myself about once every couple of months (not to mention the ones I build as RX-ready for local customers). If I had to cut them by hand every time I'd go stir crazy!
And the good thing is, 6mmFlyRC is only a couple miles from ny house!
Pat
Old May 10, 2011, 08:31 AM
Runnikee is offline
Runnikee's Avatar
USA, IN, Fort Wayne
Joined Aug 2010
I just use a utility knife and have never had a single issue.
Old May 10, 2011, 05:23 PM
GBazz is offline
Joined Sep 2010
Thanks for answers as i have never used the stuff
Bazz
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
