Old Apr 05, 2011, 11:50 AM
wmcneal is offline
Find More Posts by wmcneal
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
@birdofplay. Thanks. It's Jacksonville Fl.
wmcneal is offline Find More Posts by wmcneal
Old Apr 05, 2011, 01:45 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
WOW again !
I flew at a contest at some airport on the west side of of 10 a Long long time ago.
I was at Warner Robins AFB back then.
I did a month or so stint at Green Cove Springs test track once along time ago too.
Pretty much Hog country back then.
I just always thought of FLA as Tree'd and relatively Lush.
That must be a landfill that has been grassed over.
As I did see a cooling tower or something like one.
With the limited viewing angle it just looked like some place "Out West"
Not biggy just chatting :-)
L8r
Bob
birdofplay is offline Find More Posts by birdofplay
Old Apr 06, 2011, 01:01 AM
presa1200 is offline
Find More Posts by presa1200
presa1200's Avatar
Joined Nov 2010
just want to ask can i use 8x3.8 prop for this plan ??
presa1200 is offline Find More Posts by presa1200
Old Apr 06, 2011, 07:58 AM
wmcneal is offline
AMA 125691
wmcneal's Avatar
Joined Jul 2002
@birdofplay. You are right. It is right next to the landfill on the north side of town. Jaxrc.com
@presa - I think an 8x3.8 prop is too big. It wont fit between the vertical stabs without cutting away some more foam. I think that would make it too weak in that high stress area. You might get away with a 7x5, but you really need a high kv motor with a smaller prop. I use the standard 2212-06 2200kv parkjet motor with a 6x4 sport prop.
Old Apr 07, 2011, 12:55 PM
Aussie Mick is offline
Find More Posts by Aussie Mick
United Kingdom, England, Bedford
Joined Feb 2011
63mm fan on my F22
Hi again,
I guess this is my lazy side showing through... can someone point me to a thread where someone may have fitted a ducted fan to their F22. My outrunner died a few days ago but fortunately my curiosity based buy from Hobby King, a 63mm ducted motor turned up today so i am going to have a go at retro fitting it. Any ideas greatfully acccepted.
Mick
Aussie Mick is offline Find More Posts by Aussie Mick
Old Apr 07, 2011, 01:27 PM
crucial is offline
Find More Posts by crucial
crucial's Avatar
USA, SE Wisconsin
Joined May 2009
Just hit the "search this thread" tool and search for edf. There's been a few guys that have done edfs on this bird. One guy even made a module that could swap between a dual and single edf.
crucial is offline Find More Posts by crucial
Old Apr 08, 2011, 01:02 AM
presa1200's Avatar
Joined Nov 2010
@wmcneal tq for the info ,
now I have 2208-8 2600kv ,40a esc , 6x4 and 2200mah 25c 3s battery
Old Apr 15, 2011, 04:09 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Originally Posted by Aussie Mick View Post
Hi again,
Mick
I've done 64mm & 55mm twin versions. I've posted on this thread, but its waaaayyy far back. Videos and details of both are on my blog page -- the single 64mm is at the bottom. Feel free to PM with any questions! Happy flying!
SNice is offline Find More Posts by SNice
Old Apr 18, 2011, 07:08 PM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
So would you guys say this is easier to make (less angles/cutting) then the 6mmflyrc F/A-18?
cloaked is offline Find More Posts by cloaked
Old Apr 19, 2011, 12:42 AM
toliplu is offline
Find More Posts by toliplu
depron crash tester
toliplu's Avatar
Germany
Joined Jun 2010
@cloaked: if you already builded a model, this one should be no problem. If you never builded any model before, this one should be no problem (of cause you should know how to use a knife and glue ). The F22 was my first scratchbuild, not really much to go wrong here. If it is easier than the F/A 18? I don't know, haven't yet builded her.
toliplu is offline Find More Posts by toliplu
Old Apr 19, 2011, 06:01 AM
gcok is offline
Find More Posts by gcok
Remote Controlled Crashes
gcok's Avatar
Osijek, Croatia
Joined Oct 2010
I have used 64mm EDF fan instead of propeller
And here is video:
F-22 s turbinom (4 min 16 sec)
gcok is offline Find More Posts by gcok
Old Apr 19, 2011, 12:22 PM
gcok is offline
gcok's Avatar
Osijek, Croatia
Joined Oct 2010
More images:
Old Apr 22, 2011, 01:43 PM
AH-56 is offline
Find More Posts by AH-56
AH-56's Avatar
USA, CA, Canyon Country
Joined Apr 2009
Battery Suggestion for stock set-up
Hello all,
I've been following this thread and decided to order the F-22 Quick Build from 6MMFLY RC and the recommended motor/ESC set-up from Grayson Hobby. ParkJet Combo 2212-06 V2 Super-Sonic Brushless Combo
I've searched this thread for battery recommendations and they're all over the spectrum. Since I'm new to "profiles", can anyone recommend the proper LiPo for the "stock" motor set-up? Keep in mind I not attempting to drill holes in the sky, I'll be satisfied with a normal (?) performance.
Thanks...
AH-56 is offline Find More Posts by AH-56
Old Apr 22, 2011, 04:19 PM
Bombay is online now
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
I fly most of my 6mm profile planes on Rhino 3s 1550mah 20c batteries at 129grams each. I get about 5 minutes with the appropriate capacity left on the pack (approx 20%).
You could easily go with 1800mah. And some folks stick the brick in there...2200mah...and it still flies good.
However, like anything else, if you keep adding weight, the performance suffers. My recommendation is to make the battery area large enough to be able to use different size packs (move them forwards and backwards)...and try out a couple to see what suits you best.
You've chosen a nice plane. The F22 looks good and flies like a dream.
http://www.rcgroups.com/forums/attac...mentid=3042112
In taking a second look at your Grayson combo, it says to choose a 3s battery that can sustain 30 amps. To do that, you will want to pick a battery that can deliver about 45+ amps at peak. It you choose a lower C rating then which is listed below, the battery will voltage will sag under load and you will not get the 30amps needed for max performance from that motor combo. If you can find it in stock, I would recommend the Turnigy nano-tech or the Gens Ace lipos in the 1800mah 30c range for your application.
Examples:
1500mah x 25c = 37,500 (37.5 amp capacity)
1500mah x 30c = 45,000 (45 amp " ")
1800mah x 25c = 45,000 (45 amp " ")
2200mah x 25c = 55,000 (55 amp " ")
Bombay is online now Find More Posts by Bombay
Old Apr 23, 2011, 12:07 PM
batusaix is offline
Find More Posts by batusaix
User Extraordinaire
Davao, Philippines
Joined Apr 2007
Just a regular afternoon, flying while chatting in our native dialect, very random stuff. I did get some smooth tight loops.
Deck cam Tomhe F-22 & GWS Formosa (4 min 48 sec)
batusaix is offline Find More Posts by batusaix
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
