Old May 23, 2010, 04:45 AM
MonkeySpanker is offline
Find More Posts by MonkeySpanker
MonkeySpanker's Avatar
Skåne. Sweden
Joined Jan 2010
I actualy did tape the bottom right after i took the picture
I do have a problem with the paint though , when flying in damp weather the paint have a tendency to peal of , specialy when landing in high grass , the paint i used is "fascolor waterbased paint" , could i use a clear coat or does that melt the foam ?
i think "fascolor" makes a water based clear coat but wouldent the problem remain if i used that ?
this is a bit off topic i apologize
MonkeySpanker is offline Find More Posts by MonkeySpanker
Old May 23, 2010, 05:02 AM
Skåne. Sweden
Joined Jan 2010
i actualy did tape the bottom , right after i took the picture
I do have a problem with the paint though , when flying in damp weather the paint have tendency to peal of , im using "fascolor" water based paint , could i use clearcoat or would that melt the foam ? or ad to much weight ?
I think "fascolor" makes a waterbased clearcoat but wouldent the problem remain if i used that?
I apologize this is abit off topic
Old May 23, 2010, 05:03 AM
Skåne. Sweden
Joined Jan 2010
oops so sorry for double post
cant find were to delete post , so sorry guys.
Old May 23, 2010, 09:28 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
I believe straight acrylic paints (especially the cheapo craft paints) will probably peel or chip off of the depron if used on any large areas without a seal coat.
I've painted straight on with Krylon Fusion. You do have to be careful because it will eat the foam. The trick is to apply light coats. It works well and adheres well.
It is often recommended to wipe the pieces of depron down with alcohol before painting or gluing to remove the release agent from the manufacturing process. Others "prime" the depron with minwax clear polycrylic before painting. I used a finish coat of the minwax poly on the bottom of mine to protect the paint and decals...so far so good.
Bombay is offline Find More Posts by Bombay
Old May 23, 2010, 11:51 AM
HeliTB is offline
Find More Posts by HeliTB
Minister of R/C
HeliTB's Avatar
Fort Washington, MD
Joined Sep 2006
Yes, you can clearcoat it to protect it, but you must use Polycrylic from Minwax. It's water-based so it won't eat the foam. It comes in the spray can or you can get the pint and brush it on.
This also gives it a hard shell that protects the foam as well.
HeliTB is offline Find More Posts by HeliTB
Old May 23, 2010, 01:22 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Since you are in Sweden, I'm not sure what products are available to you. But what you want is a water-based polyurethane or polycrylic as a clear coat. You may have to go to a hardware store and ask, but you should be able to find something.
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old May 23, 2010, 03:04 PM
Skåne. Sweden
Joined Jan 2010
Thanks alot guys!! love this forum every one been so helpfull , cheers
Old May 23, 2010, 07:47 PM
HeliTB is offline
Minister of R/C
HeliTB's Avatar
Fort Washington, MD
Joined Sep 2006
Good catch Pat. I didn't realize MonkeySpanker was in Sweden.
Old May 27, 2010, 02:28 PM
pete bloom is offline
Find More Posts by pete bloom
Joined Aug 2003
Drawings for smaller size
been flying this model for quite a while now , today i was starting to figure how to build a smaller version , say about 60% or something , how can i get i smaller , im really lousy at computers so any help would be appreciated ,
pete bloom is offline Find More Posts by pete bloom
Old May 27, 2010, 04:26 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Pete,
You're in luck, all the work has already been done for you:
http://www.rcgroups.com/forums/showthread.php?t=795691
Pat
Old May 29, 2010, 07:30 PM
Glider-man is offline
Find More Posts by Glider-man
RC SAPRANOS
Glider-man's Avatar
At the field in 10...
Joined Jun 2008
Look at the very start of this thread as well, on the first page someone built a wee raptor... looks nice.
About paint, I personally would never use paint on any material for rc planes, ever again, it just can't compete with covering film, most covering films are lighter anyway... I would recommend covering depron with a low heat film (eg. solar film) it makes it very hard to snap if covered properly! But if you want to go really light I guess dye is your best option.
Glider-man is offline Find More Posts by Glider-man
Old May 29, 2010, 07:36 PM
RC SAPRANOS
Glider-man's Avatar
Joined Jun 2008
I like the colour scheme MonkeySpanker! Seems familiar...
Old May 29, 2010, 10:52 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
So the guys are out with their Me109's , P51's and Corsairs and they are QUITE !
I drag out my F22 to go mix it up with them and what a racket !
I presume it's due to the prop in slot.
Has anyone figured out a way to quiet this effect down ?
birdofplay is online now Find More Posts by birdofplay
Old May 29, 2010, 10:59 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Cut the slot in a bowtie shape. That's about it. Reduces the noise a little, but not a lot.
I like the noise. It lets everyone know I'm in the air!
Pat
Old May 30, 2010, 05:12 AM
Skåne. Sweden
Joined Jan 2010
Thanks Glider-Man , i got my inspiration from this pic but I didnt even come close
its a f18 i belive.
lol just took a peek at your blogg Glider Man and saw your F22 ....... i can see some resemblance
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
