Old Sep 29, 2007, 05:57 PM
Gandalf_Sr is offline
Find More Posts by Gandalf_Sr
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
First Build
I toyed with the idea of buying depron but found a 50ft x 4ft fanfold pack of bluecore (skin on 1 side only) fanfold at my local Lowes for $30 (I got em to discount it cos it was a bit beat up ) and I have enough to play for a loooooong time
I've never worked with bluecore before and I was worried that it seems a bit floppy but that was when it was in a big sheet, now I've cut the pieces, I'm amazed at how strong and light this stuff is. I've taped it together with scotch tape and so far it weighs 128g
The HXT 28-26 motor is on its way plus a few other parts.
Idea:
Add an extra layer of foam to the front of the wings to make a pseudo airfoil section
<<<<<<<<0
Where <<< = the foam and direction of flight and 0 = a CF support.
Will this work or am I wasting valuable time and brainwaves?
Now I need to make a decision, ailerons or not?
Gandalf_Sr is offline Find More Posts by Gandalf_Sr
Old Sep 30, 2007, 02:07 AM
Shadegrown is offline
Find More Posts by Shadegrown
Tampere, Finland
Joined Sep 2007
Originally Posted by superinstaller
Just flew it! flies fine and the TV works quite well, at about 3/4 back on the elevator she flips 180 and makes it look easy, even at high speed!
Very fun to fly! it was tail heavy and no ailerons all tail, Maybe later!
Nice to know that the thrust vectoring works well What motor & prop are you using?
Shadegrown is offline Find More Posts by Shadegrown
Old Sep 30, 2007, 06:22 AM
Tampere, Finland
Joined Sep 2007
Gandalf_Sr: You can install the ailerons later if you're not happy with just the tailerons
I installed the motor and servos today. I need to buy some accessories for control rods tomorrow and then I'm really close to get this thing flying
Old Sep 30, 2007, 07:10 AM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
I will probably do the ailerons with double servo linkage and maybe convert up to full ailerons later. Can anyone shed any light on the performance differences with/without ailerons?
What's your AUW weight at now Shadegrown?
Any thoughts on my wing-strengthening idea?
Old Sep 30, 2007, 07:51 AM
superinstaller is offline
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
2212-6 with a 6x4 apc from bphobbies great motor!
superinstaller is offline Find More Posts by superinstaller
Old Sep 30, 2007, 06:42 PM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Airframe Build Finished
My bluecore pieces were too bendy so I decided to put carbon fiber strip along the front edges of the wings as well as a strip right across the wing which most folks appear to have added anyway. Looking at the way the wing and front section joined together, I decided to modify the main wing piece so that the 'V' points forwards rather than backwards (see pictures) and this allows the CF strips to come right to the center where the center pillar of the front vertical section forming a very strong central point while adding very little weight.
I also added sharpened CF stiffener rods that are inserted inside the rear part and then follow the line of the front of the rear elevator section (see pictures).
Bare airframe weighs 180g so far.
Old Sep 30, 2007, 07:51 PM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Nice job Gandalf_Sr ! That cat with laser eyes is kinda scary.
Did you get my return pm several days ago?
Bill Bergman is offline Find More Posts by Bill Bergman
Old Sep 30, 2007, 08:44 PM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Yes thanks Bill, I got the PM. I still have a couple of questions:
1. Is the CofG 3.25 inches back from the front edge of the wing?
2. Should I bother with the rudder?
3. What is the AUW?
Thanks for the comments on the build, I was pleased with the way the CF additions went in and I have stopped considering the double wing idea for now.
I have 2 motors + ESCs on the way from UH, one is the HXT 28-26 that Shadegrown is using but hasn't actually tested yet. The other is a Hacker style 20-20 with slightly more power. My problem is that I have 2 standards of LiPo, 1300 mAH 10-15C ones that weigh 100g and 2200 mAH 25C ones that weigh 198g. My AUW is likely to be in the 300g range without battery so I could have a 400g or 500g AUW or buy another standard of battery.
Old Sep 30, 2007, 09:32 PM
Houston, Tx.
Joined Jan 2003
COG 3 to 3.25
I like the rudder for flat turns and believe it or not ....hovering
mine weighs 11 oz.
Old Oct 01, 2007, 04:35 AM
Tampere, Finland
Joined Sep 2007
I don't own a precision scale yet, so I don't have any idea what the weight is.
Old Oct 01, 2007, 11:46 AM
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
COG 3 to 3.25
mine weighs 11 oz.
Thanks Bill.
I think I will add the rudders, I was figuring on making them work from a single servo although I do have those really light (and cheap) servos on the way from UH. Were you happy with the control surface area I can see on your pictures or would you make them bigger?
I also think I'll go for the bigger A20-20 motor and use the heavier 2200 battery.
Shadegrown, you could do a non-precision measurement of your AUW using a bathroom scale?
Ted
Old Oct 01, 2007, 11:57 AM
Houston, Tx.
Joined Jan 2003
The amount of rudder I have is sufficient at slow speed and probably more than need for high speed. I could a little more as slow as I fly.
Old Oct 01, 2007, 06:02 PM
Joined May 2006
I was wondering about slow speed control (or lack of), the rudders must help some , Ill try them too!
Old Oct 02, 2007, 05:30 AM
frank48 is offline
Find More Posts by frank48
Went to mow a meadow
frank48's Avatar
United Kingdom, Dur
Joined Feb 2007
Hi
Great plan..!! Thanks for sharing
I'm thinking of scaling this down to 80% to make it easier to transport. Works out about 24" Span and 34" long. I have a 2409-12 delta and a 3c2200 mah lipo doing nothing at the moment, how do you guys think this will go using this combination ?
Thanks for advice
Frank
frank48 is offline Find More Posts by frank48
Old Oct 02, 2007, 06:23 AM
Tampere, Finland
Joined Sep 2007
I'll try the rudders too, if somebody knows how I can get them working with only one servo Any ideas?
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
