Old Jan 11, 2010, 11:50 PM
Glider-man is offline
Find More Posts by Glider-man
RC SAPRANOS
Glider-man's Avatar
At the field in 10...
Joined Jun 2008
... and page 100!
I found CA/Easy hinges to be very good, they are thin and there are no pins or anything waiting to be clogged.
Glider-man is offline Find More Posts by Glider-man
Old Jan 11, 2010, 11:57 PM
crxmanpat is offline
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Well, depends on how many posts per page you are set up for (I do 100 per page, so this is only page 16 for me ).
Pat
crxmanpat is offline Find More Posts by crxmanpat
Old Jan 18, 2010, 07:24 AM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
hey crxmanpat,is it better to use a 25c battery over a 20c?I flew mine yester day,and it flew great,but i was just wondering if 25c is better than the 20c i am using?
TheTrashMan is offline Find More Posts by TheTrashMan
Old Jan 18, 2010, 07:39 AM
Joined Jul 2009
oh and the thrust vectoring is awsome!!!!!!!In fact after watching me fly it ,my uncle and went home and bought 200$ worth of stuff to get him up and running!!!!!!!
Old Jan 18, 2010, 07:52 AM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
planeflyer94:
What motor and prop are you running?
What size (mah) 20c battery do you have?
These questions would help determine if 25c would be better for you.
Rob
Bombay is offline Find More Posts by Bombay
Old Jan 18, 2010, 08:16 AM
Joined Jul 2009
i have the grayson supersonic combo,and a 1300 20c 3cell.
Old Jan 18, 2010, 10:32 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Based on my tests with a 2212-6, at WOT with a 6x4 we were drawing 21 amps.
For a 1300 20c 3cell, I believe the calculation (1300 x 20) shows that the battery can deliver 26 amps. I think this is fine based on what I have read. You should be using a battery that can deliver approx 25% more amps than what the setup pulls. So, 21 amps + 25% = approx 26amps...which is about where you are.
Keep in mind that if your system is only pulling 21amps at WOT, you probably wouldn't see a performance increase by moving up to a much higher C rating battery. You are only going to pull approx 21 amps whether you have a 20, 25, 30 or 40c battery.
You might want to consider a higher capacity battery (mah). A higher capacity battery at the same c rating would give you longer flights plus more power potential. Check out these calculations:
3s 1300mah, 20c = 26amp potential
3s 1300mah, 25c = 32.5amp potential
3s 1550mah, 20c = 31amp potential (and longer flight times over a 1300mah)
3s 2200mah, 20c = 44amp potential (and longer flight times over a 1300mah)
For what it is worth, I am running 1550mah 30c batteries and my buddy is running 2200mah 20c batteries. So, this airframe can certainly handle larger, heavier batteries.
hope that helps
Rob
Old Jan 18, 2010, 10:57 AM
Joined Jul 2009
so the more mah also means more power too.
Old Jan 18, 2010, 11:23 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
yes
Old Jan 18, 2010, 02:20 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Will the plane go vertical with that 1300 20C (it should)? If it's flying fine with that lipo, then I say continue on with it. But like Rob said above, you can certainly use up to a 2200 lipo as well. The higher mAh gives you more power and duration.
Pat
Old Jan 18, 2010, 03:23 PM
Joined Jul 2009
it can go vertical for a couple of seconds,but then it goes to slow and i lose control.Like it will fly it fine but i am getting rerady to order some batterys and i am debating going to 25c.
Old Jan 19, 2010, 08:25 AM
HeliTB is offline
Find More Posts by HeliTB
Minister of R/C
HeliTB's Avatar
Fort Washington, MD
Joined Sep 2006
If you go with heavier batteries you will lose some of vertical ability simply because the plane is heavier.
HeliTB is offline Find More Posts by HeliTB
Old Jan 19, 2010, 02:08 PM
Joined Jul 2009
hey guys is my battery ruined if after it dies(loses charge)it gets left pluged in for oh say......................2 hours?
Old Jan 19, 2010, 02:14 PM
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Maybe, maybe not. Does your charger have the ability to select the charging rate? If so, hook it up and charge at like .2 amps for a few hours and see if it works (make sure you protect the surroundings in case the battery goes up). If you have the ability to balance charge, do that as well.
BTW, just to be sure (you should have very good vertical with your current setup), is your prop facing the right direction? The numbers on the face of the prop should be facing towards the front of the plane.
Pat
Old Jan 19, 2010, 03:01 PM
Joined Jul 2009
well i have been charging it for like 2 hours now on .3 amps(thats as low as it goes)And it seems fine.
My prop is on rite but i still dont get that great performance,and i dont know why.My first plane i put it on i had way more power,but it was hard to control,and there for it crashed a lot.Now i have it on my f-22,and i have great control but less performance from the motor.
Video f-22 with average pilot leadfeather Electric Plane Talk 1 Apr 24, 2008 12:49 AM
Video RCSuperPowers F-22 with Vectoring Thrust RCSuperPowers Electric Plane Talk 25 Feb 18, 2008 04:00 PM
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) meteor Electric Ducted Fan Jet Talk 30 Feb 09, 2005 09:57 AM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
f-22 with jeti brushless ivorz Foamies (Kits) 14 Oct 01, 2002 08:39 PM
