6mmFlyRC Profile F-22 with Simple Thrust Vectoring
Here are plans for a profile F-22 Raptor with a simple form of thrust vectoring by having the elevons in the prop wash from a mid-mounted motor. It's intended to be built with 6 mm depron.
![]() Wingspan: 72.1 cm (28.4 in) Length: 99.9 cm (39.3 in) Suggested motor: 2200 RPM/V Suggested propeller: APC-E 6x4 Suggested battery: 3s 2200 mAh Suggested servos: 2 x HS-55 The design follows the outline of the attached three-view images, except for the elevons, which have been slightly widened. The elevons have also been extended forward to increase the thrust vectoring effect. The plans can be downloaded from http://rc.tomhe.net/f-22. The tiled plans should be printed centered at 100 %. UPDATE: This plane is now also available as a kit from 6mmFlyRC. UPDATE: A detailed build instruction manual is available for download from 6mmFlyRC. UPDATE: This plane can now be purchased as a kit from Grayson Hobby with a power combo set (motor, ESC, and propeller). |
Good idea! This is a very simple way to vector the thrust. It will be interesting to see if the effect is the same as the tilting motor method of thrust vecoting. Good luck!!
Latest blog entry: Quick Stick
Australia
Joined Oct 2000
I try to make one at 2.25 times the size of your A4 print using the micro UH outrunner with 2000KV. http://www.unitedhobbies.com/UNITEDH...idProduct=5358
In case the elevon surfaces are not big enough I'll just cut out ailerons and couple them to the elevons Ikarus Su-27 XXL style. |
As for the need for rudders at slow speed: I'm hoping that constant air from the propeller over the vectoring inlets of the elevons, present even at slow speeds, will lessen the need for rudders. It shall be very interesting to see how well they work. |
| Thread Tools | |
| Video f-22 with average pilot | leadfeather | Electric Plane Talk | 1 | Apr 24, 2008 12:49 AM |
| Video RCSuperPowers F-22 with Vectoring Thrust | RCSuperPowers | Electric Plane Talk | 25 | Feb 18, 2008 04:00 PM |
| Wattage F-22 with mixed surfaces & 208 watts/lb!! (video) | meteor | Electric Ducted Fan Jet Talk | 30 | Feb 09, 2005 09:57 AM |
| Wattage F-22 with ducted fan | The Blue Max | Electric Ducted Fan Jet Talk | 11 | May 10, 2003 01:13 PM |
| f-22 with jeti brushless | ivorz | Foamies (Kits) | 14 | Oct 01, 2002 08:39 PM |
