Old Aug 11, 2007, 09:16 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
They all have a "shift" which is another way of describing the polarity of the PPM stream.
IIRC it is only in the NA market that Futaba uses -ve shift.
For pretty much the rest of the world all radios are the same shift.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Aug 11, 2007, 10:34 AM
JKos is offline
Find More Posts by JKos
United States, CA, Redondo Beach
Joined Aug 2003
> stream.
But it's the "polarity" of the PPM stream in the FM "world", not necessarily the input to the module. The design of the module itself will determine which "polarity" of input creates postive or negative shift in the modulated RF signal.
Anyways, while we're talking about Airtronics... The Stylus has selectable shift.
- John
JKos is offline Find More Posts by JKos
Old Aug 11, 2007, 12:44 PM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
Originally Posted by JKos
.....Anyways, while we're talking about Airtronics... The Stylus has selectable shift.
- John
Yes, as does the RD6000 and RD8000 and VISION (thank goodness)
Old_dude
old_dude is offline Find More Posts by old_dude
Old Aug 11, 2007, 08:17 PM
pmackenzie's Avatar
Joined Dec 2002
> stream.
- John
You are probably correct. I was thinking about the decoded PPM stream at the rcvr end. It is inverted if the "shifts" don't match.
I have also seen circuits to go between the encoder and the RF module to reverse the shift that were just inverters.
Likely the selectable shift radios also work this way, by inverting the signal going to the module.
Pat MacKenzie
Old Aug 11, 2007, 08:49 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
I put one of those in my 9C, it's just an XOR logic chip and seems to work fine in the Futaba radios, at least with GWS receivers. I haven't tried it with my JR receiver yet, but it should be fine.
village_idiot is offline Find More Posts by village_idiot
Old Aug 12, 2007, 10:43 AM
Javier Garcia is offline
Find More Posts by Javier Garcia
Joined Nov 2004
Information support
Meng:
Thanks for your information and it is good for customers to have several manufacturers to choose from.
You told you are a comercial. Well, as you know, if a comercial donīt know technical information, uses to get it from the other department.
If you, and your company, want to sell, you have to give customers information required about the product, and specially, those tech infos to know if it is safe, and about legallity. And donīt forget the price.
So, please, as european customer, could your company certificate that product as compliant the ETSI EN 300 238 rules.
Javier Garcia is offline Find More Posts by Javier Garcia
Old Aug 12, 2007, 10:52 AM
Joined Nov 2004
Fhss or DSSS
Meng:
It is very important for european users to know if your system is FHSS or another.
If it is a FHSS, the module could have 100mW, but, in other case, only 10 mW per 1Mhz.
You said that there are not only FHSS and DSSS, but, in Europe, the Law only makes diference about FHSS and the others.
Old Aug 12, 2007, 11:02 PM
ASSAN is offline
Find More Posts by ASSAN
CHINA
Joined Apr 2005
X8 Vedio in Heli
thank you, guys.
i will try all my best.
here is the Vedio of X8 in Heli recently.
X8 2.4G in Heli (5 min 2 sec)
hope you like it.
best,
meng
Http://www.assan.cn
MSN&E-MAIL: sales@assan.cn
ASSAN is offline Find More Posts by ASSAN
Old Aug 20, 2007, 08:24 AM
Prof. Dr. YoMan is offline
Find More Posts by Prof. Dr. YoMan
Holger Rusch
Prof. Dr. YoMan's Avatar
Germany, Karlsruhe
Joined Apr 2003
Updates?
Technical Data?
FCC, ETSI?
Prof. Dr. YoMan is offline Find More Posts by Prof. Dr. YoMan
Old Aug 22, 2007, 05:00 AM
ASSAN is offline
CHINA
Joined Apr 2005
Originally Posted by Prof. Dr. YoMan
Updates?
Technical Data?
FCC, ETSI?
we have been get FCC Grantee Code.
we have upload the User Manual to our website.
meng
Http://www.assan.cn
Old Aug 22, 2007, 05:33 AM
ModelTony is offline
Find More Posts by ModelTony
ModelTony's Avatar
Irvine, Scotland
Joined Jun 2004
meng
Http://www.assan.cn
From the manual:
Minimum voltage 4.2 volts.
System has to be re-bound each time the system is turned on.
No mention of what is lowest range acceptable during range test.
No failsafe, all channels stay at hold position on loss of signal.
Tony
ModelTony is offline Find More Posts by ModelTony
Old Aug 22, 2007, 05:51 AM
ASSAN is offline
CHINA
Joined Apr 2005
Originally Posted by ModelTony
From the manual:
Tony
yes, we don't want the user take a low volatge battery to play.when the input voltage down below 4.5v,your servos' respect is slowly,it's dangerous for using,the best way is keep your battery full charge before your flying.
for the range test, we follow the traditional way, as you FM Tx.
Failsafe,all channels stay at last position is a failsafe way too.
best regards,
meng
Http://www.assan.cn
MSN&E-MAIL:sales@assan.cn
Old Aug 22, 2007, 06:12 AM
ModelTony's Avatar
Irvine, Scotland
Joined Jun 2004
best regards,
meng
Http://www.assan.cn
There is some concern with 2.4Ghz that low voltage will cause the receiver to stop working until the voltage rises when the receiver will start responding to the transmitter. If your receiver looses power then it will require re-pairng before responding to the transmitter. If there are 2 of your systems in use which transmitter will it pair to?
With 72Mhz systems the antenna is collapsed and then a range check is carried out. What is the equivalent for your system?
An aircraft flying at full power with no control cannot be considered to be Failsafe.
Tony
Old Aug 22, 2007, 09:20 AM
Inciting Riots
Joined Dec 2006
So, since you have an FCC ID, where can we buy them?
Having to bind them each time is kind of a pain, but if the price is good and they work well, something that a lot of people will learn to live with.
Old Aug 22, 2007, 03:29 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
What are the dimensions of the recievers.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Fs:cox Airlifter Complete 2 Channel Radio System{new} classic_742 Aircraft - General - Radio Equipment (FS/W) 0 Apr 17, 2005 07:47 PM
F/S new 2 chnl radio system SMAAAAK! Cars - Cars and Parts (FS/W) 0 May 02, 2004 07:38 PM
new 2 chnl radio system SMAAAAK! Boats (FS/W) 0 May 02, 2004 07:37 PM
F/S new 2 chnl radio system SMAAAAK! Aircraft - Sailplanes (FS/W) 0 May 02, 2004 07:34 PM
