Old Jul 11, 2008, 03:28 PM
JimNM is offline
Find More Posts by JimNM
WAA-08 THANK FRANK!
JimNM's Avatar
Las Cruces, New Mexico, United States
Joined Jun 2002
OK - I just dropped the order. Thanks for the info.
JimNM is offline Find More Posts by JimNM
Old Jul 11, 2008, 03:34 PM
aeajr is online now
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Originally Posted by vhoward1122
Of course, some people might want to be able to buy $20 rx's instead of $99 rx's.
Good point!
Does the standard Futaba 2.4 antenna work with the Assan module or do you have mount and unmount antenna when switching on the 10C?
aeajr is online now Find More Posts by aeajr
Old Jul 11, 2008, 05:10 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
the module has sticker that say v2.0 and it fits hitec eclipse like a glove (where it did not before) receiver is not v2.0 (but not critical for me at this point) I have 3 receiver (7 channels) and will need to pick up a few more. if things are good, I may eventually convert my evo7 to 2.4 when the proper module comes out.
I have it installed in my slow stick and 3d foamy(hobby loggy yak) and so far so good. I will flight/range test tomorrow. easy binding. easy fail safe (both work well)
I am happy camper.
askman is offline Find More Posts by askman
Old Jul 11, 2008, 06:13 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Rather than the exposed wire, which is a weak point with the Spektrum add on modules, why not just redesign the case to be more like this...
GBR2 is offline Find More Posts by GBR2
Old Jul 11, 2008, 08:29 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
problem with xps type is that it may get into the metal handle. have to make sure it does not. otherwise, don't mind cable setup on top.
Old Jul 12, 2008, 05:57 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
ok. I did some flight testing. wind gusting to 15mph left the foamy on the ground, but I did take up my slow stick. (clipped wing) it is my test bed plane. hitec eclipse never felt so connected. I flew it as high as I could see and fairly far (school parking lot, so far is not too far, but I did get lot of altitude) man, not having to mess with frequency is nice. change model, turn on and you are ready. My guess is that binding information is stored on receiver (transmitter id) so that you only need to bind once. tried failsafe and that worked also.
so far so good.
Old Jul 12, 2008, 07:38 PM
GBR2 is offline
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
That design fits the antenna between the metal handle and the radio case. No problems at all. Same sort of configuration as used in the FASST module, TM14 I believe, and the module the new JR 12X is using.
Old Jul 13, 2008, 01:43 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
One problem is that the module would be upside down in some cases, like the F module in a Hitec Eclipse. I would rather have modules with a pigtail coming out of the module, creating a low profile so that a Tx tray might be used.
Fred
flarssen is offline Find More Posts by flarssen
Old Jul 13, 2008, 01:56 AM
flarssen is offline
Son, Norway
Joined Sep 2004
That's correct unless you have mixed use of Rx's of different versions (pre february 08, post february 08, V2).
This is my biggest concern regarding this system at the moment. Having to disconnect channel 1-3 servos and inserting the binding plug when switching models is no good . (Am I the only one having an issue with this?) I will stay with my current version for this reason.
Fred
Old Jul 13, 2008, 02:50 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
not sure what you mean. I only bind it once to each receiver to transmitter. once it is bound to a transmitter, I don't have to worry about it again. it stay bound. I went from one model to another without having to rebind. now, if youi have several transmitter, it could be painful.
Old Jul 13, 2008, 03:12 AM
flarssen is offline
Son, Norway
Joined Sep 2004
If you later buy V2 Rx's, you will have to rebind every time you switch between current and V2 Rx's. As long as all Rx's are of same version there is no need to rebind when changing Rx's.
Fred
Old Jul 13, 2008, 03:29 AM
supershuey is offline
Find More Posts by supershuey
damn gravity again
supershuey's Avatar
trowbridge, Great Britain (UK)
Joined Jan 2004
hi all
i hope assan keep making both versions then,
my edf rx are hidden well deep
Dylan
supershuey is offline Find More Posts by supershuey
Old Jul 13, 2008, 03:33 AM
damn gravity again
supershuey's Avatar
Joined Jan 2004
oops
Old Jul 13, 2008, 11:12 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
now that seems strange as well. if tx data is stored on rx for binding, why would it need to be rebound? if it is the case, that would be painful. hopefully, Assan will make it user friendly. they have so far been responsive to our need. it may be true with v1.0 module and v2.0 rx. I remember reading something about that. I have v2.0 module though.
Old Jul 13, 2008, 02:30 PM
flarssen is offline
Son, Norway
Joined Sep 2004
February version:
http://www.rcgroups.com/forums/showp...&postcount=709
V2:
http://www.rcgroups.com/forums/showp...postcount=1183
http://www.rcgroups.com/forums/showp...postcount=1460
Fred
Fs:cox Airlifter Complete 2 Channel Radio System{new} classic_742 Aircraft - General - Radio Equipment (FS/W) 0 Apr 17, 2005 07:47 PM
F/S new 2 chnl radio system SMAAAAK! Cars - Cars and Parts (FS/W) 0 May 02, 2004 07:38 PM
new 2 chnl radio system SMAAAAK! Boats (FS/W) 0 May 02, 2004 07:37 PM
F/S new 2 chnl radio system SMAAAAK! Aircraft - Sailplanes (FS/W) 0 May 02, 2004 07:34 PM
