Old Aug 04, 2007, 02:32 PM
vhoward1122 is offline
Find More Posts by vhoward1122
AMA # L576
vhoward1122's Avatar
United States, OR, North Bend
Joined Sep 2006
Question
Check valve for uniflow fuel system?
I am wanting to try the uniflow fuel system. However I don't have a check valve to use and the closest hobby shop is 75 miles away. Don't really want to pay $4 s&h for one item either.
Would a one way check valve for an aquarium work? I have one of those sitting around.
vhoward1122 is offline Find More Posts by vhoward1122
Old Aug 05, 2007, 04:57 AM
Artisan is offline
Find More Posts by Artisan
NM2K
Ringgold, GA, USA
Joined Jan 2006
Yes, most times they will work just fine. Just keep an eye on any plastic parts that may melt or the o-rings. I will be surprised if you have a problem.
If only the o-rings melt, you can find other o-rings locally that will not melt.
Let us know how you fare. I've been using aquarium plumbing parts on various models for years. I particularly like the brass tee fittings. Good luck.
Ed Cregger
Artisan is offline Find More Posts by Artisan
Old Aug 05, 2007, 02:23 PM
AMA # L576
Joined Sep 2006
Thanks.
Old Aug 05, 2007, 07:40 PM
wylieruneyjr is offline
Find More Posts by wylieruneyjr
Joined Nov 2006
I have seen in a book of 400 plus tips that a check valve can be obtained from a pump spray bottle, such as insect repellant, 409, greased lighting ect. I,ve never tried this, but more than likely you have some of these type valves around.
wylieruneyjr is offline Find More Posts by wylieruneyjr
Question required conversions for gasoline fuel system? fullscalepilot87 Fuel Plane Talk 2 Feb 05, 2007 11:23 AM
For Sale Conley Glow Fuel Check Valve rino Aircraft - Fuel - Engines and Accessories (FS/W) 0 Feb 05, 2006 03:05 AM
power system need someone to check it out for me will it work as a hot wire? gazza2003au Foamies (Kits) 7 Sep 06, 2003 04:36 AM
Help for SF power system? hardlock Parkflyers 3 Jan 03, 2002 10:52 PM
