Joined Aug 2007
here are 2 photos of the twist grip throttle, one shows the output of 3 wires and the other shows the mechanism (metal plate inside moves with grip). I hope this will help explain the device and allow someone to suggest a method of essentialy using it as a transmitter. Many thanks for your ongoing support
Joined Jun 2007
Not wanting to step on your toes, but your questions lead me to believe that you should look for some local help. You obviously don't have the foggiest idea how these things work, and if you have to consult an online forum for every step you take things are bound to get tedious.
As for your latest question: set the multimeter to Ohms and measure the resistance between the red and the black lead. If it is 5 k you are lucky and can use the grip as direct input to a standrad transmitter, replacing one of the pots of the sticks. At the same time you can check for which connetction of the multimeter the reading changes with position of the throttle grip. If Mike's assumption is right (very likely), thats white to black and white to red; black to red being constant. The lead that's involved in each combination that gives varying resistance is the one connected to the wiper, i.e. the one carrying the input signal to the Tx. |
Joined Aug 2007
You are right MarcusN I really dont have the foggiest idea about building my own rc project, I am an engineer at heart and have delayed this part of the project's electronics until now, but I had to ask someone and there dont seem to be very many people who are accessible for advice in my area so I thought the forum would be a good place to seek help. I really don't want to be irritating and I do very much appreciate all the help I have been given. I will test the pot with a multimeter, thanks
UK
Joined Oct 2003
I think the point Markus is trying to make is that if you have little or no understanding of how a simple pot works then what hope do you have if you need to troubleshoot your project when it has problems. Its not a case of asking on forums or local contacts, basic electronics guides, how to's and general "how things work" can be found on the net, and a few hours research might help you undrstan how these things work
Just to help, if you don't have access to a meter, often the value of the pot is marked on the can. I would susspect that the value may be 10K or 100K. |
| Thread Tools | |
| 1st RC Car recommendation- [need help] | Wishi | Off-road Cars | 18 | Dec 27, 2004 11:48 AM |
| Focke-Wulf FW-190 Project...Need Help | kennypinkerton | Indoor and Micro Models | 38 | May 17, 2004 03:50 PM |
| hand me down wing project need help please | relaxnfly | Slope | 36 | Feb 04, 2004 08:02 PM |
| Cartoon project, need help and ideas | Seastar | Foamies (Kits) | 13 | Dec 25, 2003 08:35 PM |
