You're right Boomer. Not much being said about the plane yet despite a thread in the scale forum: http://www.rcgroups.com/forums/showthread.php?t=640472 where a bunch of people got the plane but few have actually built it yet. There was a very small discussion about the E-Flight Power 10 and 15 as well.
I just got started on mine last night and I'm very impressed so far and I don't usually buy bARF's. I'll be using a Hacker A30-16M in mine for around 300 watts. That should haul the bird around just fine. I've already flown this motor 3S1P 2200mah so that will save a lot of weight over a 2P or a large mah pack configuration. I may go ahead and run 3S2P anyway just to have the super long flight times. With my present rate of project completions I should have this done in about two months. Joe |
Joined Jun 2006
Hyperion Cub 25E
I have the Hyperion 25E and the world models 48" cubs. My 25 is using an Eflite power 10, Airbos 35, apc 12X6E, 600ma flight pack and a hyperion 2100 16C lipo. I used cs-12 servos from tower hobbies with a MG on the rudder.
First off let me say this plane is a dream to fly. I never get over 1/2 throttle even on takeoff since it does not suffer from the "cub ground dance" that many other models seem to. I've mixed in down elevator for 50% and 100% flap settings but i've found it easier to land with no flaps. This power setup requires some management as wot static is 42 amps but who wants to 3d a cub I've found that high rates which are close to factory recommended do very well. My low rates at 60% made it harder to fly. The plane flys well in 12 to 15 mph but is much more fun below 10 mph. The landing gear is very well designed which is a nice change from other Hyperion models I've flown and my worst "carrier" landing did nothing more than pop the o rings between the LG braces. Larger main wheels would be better on grass fields.The WM 48" uses an eflite park 450 with a custom made firewall and spacers. Ultrafly 25Amp esc and either hyperion or TP 2100 lipos finish the power train. I've fogotten which apc slow flyer prop i put on it but its a 9" i believe. The WM cub can literally fly 30 min at half throttle in gentle wind which is nice when i'm ribbing the slimers about their dead stick landings when they run out of fuel. Both of these planes need plenty of roll on the alierons and a high deflection on the rudder. I mixed up elevator with rudder on the hyperion and it made it alot easier to fly. I have lots of planes in a mix of electric as well as glow but these 2 are hands down my favorites. I doubt you can go wrong with either one. |
| Thread Tools | |
| Discussion Hyperion 25e J3 Cub Ready to maiden. | boomerace | Parkflyers | 0 | Aug 18, 2007 06:34 PM |
| Question Hyperion 10e piper cub cowl | littleport2003 | Parkflyers | 2 | Jun 24, 2007 12:40 PM |
| Question Hyperion 10e Piper Cub | littleport2003 | Scale Electric Planes | 1 | Jun 05, 2007 06:56 PM |
| Wattage piper cub 400ARF | rcastab | Parkflyers | 43 | Jul 16, 2002 06:26 AM |
| 71" Piper Cub first flight | asperkins | Sport Planes | 2 | Jun 26, 2001 12:58 AM |
