I have a 642 and a 652 and I'm guessing the 662 is not a lot different.
By your servo setup it sounds like you're using the flaperon setup in the radio, right? What you could try (why oh why is this not in the manual???) is to check your flap travel. If you haven't changed it, it's probably +/- 100%. You will probably want +X%/-0% (or vice versa) so that the ailerons are in their neutral position with the flap switch off. If the 662 is the same as the earlier models, adjusting/matching your aileron travel can be a pain too, because the aileron adjustment only affects the servo plugged into the aileron channel. A fellow Ezoner (HarryC) helped me out on this - Use the dual rate adjustment on the aileron channel to get the aileron plugged into the flap channel just right, and then match it using aileron travel adjust. Check this thread http://www.rcgroups.com/forums/showt...threadid=69977 for Harry's explanation about the flap and aileron settings. Good luck - the Mini Flash looks like a lotta fun! Al |
| Thread Tools | |
| Help with flaps on Aileron'd Terry | T-Bo | Beginner Training Area (Aircraft-Electric) | 4 | Jan 22, 2003 10:05 PM |
| Any warmliners with flaps? | Archer | Electric Sailplanes | 11 | Jan 20, 2003 03:23 PM |
| FS: S10 and S11 with flaps | ShredAir | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 05, 2002 05:56 PM |
| DAW 1-26, more lift with flaps? | Tim K | Slope | 0 | Jun 03, 2002 02:30 PM |
| Crazy Max with Flaps | russ6421 | Parkflyers | 2 | May 02, 2002 01:04 PM |
