Old Aug 03, 2007, 10:10 AM
kakao is offline
Find More Posts by kakao
Fly cheap-gliders arr :)
kakao's Avatar
Bratislava - Europe
Joined May 2007
Trim your glider like PRO!
Hi!
I want to start a theread about trimming of your plane.
This means - what exactly (in steps) would you do if you have a new scratch build glider and you would like to response it to your control inputs as best as possible ?
Meaning -
1) CG setup
2) Basic throws
3) Improve Glide ratio
4) Roll/Pitch/Yaw stability, Steering - Airlon diferential, Coordinated turns
5) Rolling + upside down fly ( if possible ) - how to make them as smooth as possible
6) Other Mixes
7) Landing configurations
8) Other
If you write some advise - write first to which cathegory (the number) it falls
ONLY POSTS CONCERNING SAILPLANES
I want to create some HOW TO and post it here to the RC Groups
PS: Try not to use slang words, images help alot!
PS2: Links to other sources are welcome but they should be as informative as possible - please no references like - buy this book/video etc.
In reference to the terms that should be used .. this link might be helpfull
http://en.wikipedia.org/wiki/Flight_controls
kakao is offline Find More Posts by kakao
Old Aug 03, 2007, 10:38 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
http://polecataero.com/articles/cg-location
http://www.nesail.com/articles.php?P...3318f58f28bc1a
11/06/2003 Trimming Your Model Sailplane Sherman Knight
Ollie is offline Find More Posts by Ollie
Old Aug 03, 2007, 01:25 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
That just about covers it, although I also recommend: http://radiocarbonart.com/Pages/perftunemain.html
..a
Old Aug 03, 2007, 05:49 PM
histarter is offline
Find More Posts by histarter
Permanently Banned
Dallas TX
Mission impossible. LD is a characteristic of design, so one should just build something better!
Tripping a wing is truly an art since no two pilots have the same desires relative to airspeed performance. When unilateral designs for trips are originated, the majority cannot accept the fact that there is a speed range consideration involved. They, on the other hand, simply seek an open-ended system [that will never exist]! I grade trips on LD Velocity and 2 times LD Velocity for an identifiable range, and enjoy their positive enlightenment over that region. Others attempt to grade them as turbulators at minimum airspeed, and never comprehend their advantage. Open-ended speed is a shabby way to evaluate them, but is done by the majority. [Stick to CL 1.0 and CL 0.2 as a realistic speed range, and they become suprisingly effective]
histarter is offline Find More Posts by histarter
Old Aug 07, 2007, 06:05 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
Found something interesting
In optic6 manual on page 41/42 is Aircraft Flight triming chart
http://www.modelflight.com.au/manual...tic_Manual.pdf
Old Aug 07, 2007, 09:08 AM
thelocust is offline
Find More Posts by thelocust
aka ben wilson
thelocust's Avatar
louisville, ky, usa
Joined Mar 2001
A post on the RCSE from Marcus Stent discussing launch setup, which should apply to all winch-launched planes...
Analysing Martin Weberschock's Launch setup.
A theory by Marcus Stent
This is basically my opinion on how Martin Weberschocks sets up the Launch Mode of his F3B glider. This was deduced by listening to his lecture in 2000 and applying my learnings from the XFoil program (Profili 2). Please feel free to make comment on my observations…
Step 1.
The towhook for Launch Mode is not dependent on where the C.G. is, but rather where the Aerodynamic Centre of the model is located. This is because during launch we add an external force to the model (the winch) which adds probably 50Kg of force to the Model. This force needs to balanced with the Lift force of the Wing, so we get a smooth launch, and this Lift force is generated at the Aerodynamic Centre of the model. The fact that there is a 2Kg model stuck in between these two huge forces is just about irrelevant, and weather the 2Kg mass is 5mm forward or back is going to have even les effect.. The mass of the model is just along for the ride. As you can see the relationship between the line tension (set by the towhook) and the lift of the model ( located at the Aerodynamic Centre) are the most important factors.
Step 2.
What the C.G. does do to the launch is to change the elevator trim position that you fly with. e.g. Lets assume that you are flying in Thermal Mode and you have two identical models with a fixed towhook and flap settings. Then you set up Model 1 in Thermal Mode to have a forward CG of 30% and therefore some up trim (e.g. +2%) is required in the elevator to compensate for the forward CG. Model 2 is set up with a rearward CG of 40% and therefore you have some down trim (e.g. -2%) to compensate for the rearward CG. Both models fly around in Thermal Mode very nicely `balanced'. So then what happens during Launch mode is this: Model 1 with its up trim (+2% from the Thermal Mode) during launch (because we use the same elevator settings for our Thermal Mode as we do for the Launch Mode, don't we!) so the plane pulls hard and wants to tip stall and every one yells "move the towhook forward!!". Model 2 is exactly the opposite and the down trim in the elevator (-2% from Thermal mode) causes the plane to launch very flat and every one shouts "move the towhook back!" What this shows is that two identical planes can end up with two different towhook positions depending on where you set the CG, but what we learnt from the Step 1 is that the Towhook should be set relative to the Aerodynamic Centre of the model and not the CG. So how do we fix this? I am glad you asked.....
Step 3.
What we need is an independent elevator setting that gives us the best balance for Launch irrespective of where your elevator trim is during Thermal mode. We start by looking at the theoretical polar of an airfoil with a high flap deflection (15 degrees) and you will see there is only one optimal Lift position and this corresponds to a specific angle of attack. Too much angle of attack or too little angle of attack and the Airfoil generates lots and lots of drag. So if we can find the optimal angle of attack (elevator pre set) for this flap setting, then we will have the optimal launch. To do this, fly around on the slope with your model in Launch Mode (Launch flap set at say 15 degrees) and adjust your Launch Mode elevator preset (or anlgle of attack) until the model flys around without stalling or diving. By doing this you have found the best angle of attack for the airfoil with 15 degrees of Flap. This new elevator setting you have discovered is making the wing work at its optimal angle of attack. What you are doing is matching the practical behaviour of the model to the theoretical polar. eg Because you have found the best angle of attack (elevator preset) by flying around, you must have found the best angle of attack on the theoretical polar. Too much angle of attack and the plane gets draggy and stalls, too low an angle of attack and the plane dives and loses height, just like the theoretical polar. You can then play with different flap settings and find the optimal elevator preset for each one. Then you will have a table of Flap settings with their corresponding optimum elevator presets.
Step 4.
Now you can take a model that you know has the best setup for that particular flap setting (Flap and elevator setting from Step 3) and apply the 50 Kg of Launch loads to the system. Now, it is a matter of matching the towhook position to the Aerodynamic centre of the model (remember Step 1) by moving the towhook back. As you move the owhook back you will eventually find the spot that lies under the Aerodynamic Centre and the model will be balanced and you will get a smooth launch. What you also know is that this combination of the Flap and the elevator preset that you discovered in Step 3 is giving you the most efficient Lift and this should result in the best launch.
In Conclusion:
We are using the same principle here as we do when we change into camber mode when we are thermal flying. e.g. You are flying around with a nicely trimmed model and then you 'flick' into Camber mode which gives you 2mm of thermal flap. What happens? The model pitches up, stalls and comes down quicker, until we add a little down elevator pre-set and find the new 'optimum point' between the flaps and the elevator.
In a nutshell: "Finding the optimal Launch setup is like finding the optimal thermal setting, the only difference is there is 50Kg of concrete hanging off the bottom of the plane in Launch mode"
In both cases you want the best combination of flap and elevator setting to keep you up the longest.
All the best with your launch setup.
Marcus
thelocust is offline Find More Posts by thelocust
Old Aug 07, 2007, 10:18 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
A nice article ;)
Originally Posted by thelocust
Now this is something i was talking about.. lot's of informations!
THX
Old Aug 07, 2007, 02:25 PM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
Very good approach, very practical oriented, love that
Thx !
Jurgen is offline Find More Posts by Jurgen
Old Sep 11, 2007, 09:34 AM
kakao is offline
kakao's Avatar
Bratislava - Europe
Joined May 2007
(4) Some new info
look here for airlon diferential and snap flap (4)
http://www.knewt.com/planes/setup.htm
Make your HBIRD 3D PRO Smooooth mnowell129 Micro Helis 7 May 13, 2005 09:01 AM
Your input Tower Pro Servo Milton Radios 0 Apr 08, 2005 11:42 AM
Glider-Like with Ailerons?? DaGuy Beginner Training Area (Aircraft-Electric) 13 Oct 05, 2004 08:38 AM
Do not store your planes like this. kennyc Beginner Training Area (Aircraft-Electric) 22 Oct 03, 2004 02:22 AM
why you should gear your glider and played with the cg location... Magna Electric Sailplanes 0 Oct 27, 2002 07:52 PM
