Old Aug 02, 2007, 01:46 PM
Scott_RC-TEK's Avatar
California
Joined Jun 2006
The Offical SJM430 (500 Class/430mm Blades) Thread
************** Please see POST #1059 for updated info *************
The new SJM500 has been born. You saw it here first.
Regards,
Scott
Weight: Approx. 1400g
Main gear: 125T M0.6
Motor: 1100KV
Motor gear: 13T,14T
Airframe Dimensions (no canopy): 760mm x 170mm x 260mm
Tail rotor diameter: 150mm
Tail rotor gear ratio: 1:4.8
Main rotor diameter: 870mm
Main shaft: 6mm x 175mm
Scott_RC-TEK is offline Find More Posts by Scott_RC-TEK
Old Aug 02, 2007, 02:02 PM
Bunyan's Avatar
Alexandria, VA
Joined Mar 2006
Scott,
Good looking bird! I like the three bearings on the main shaft to keep it tight. I wonder how it will hold up on a hard skid landing with the motor exposed like that. You'll almost need a wrap around canopy like the MP-e with those landing skids!! Although it's almost too genuine to cover up.
I'm imagining this one with a some sort of v-staby device option and the option to get rid of the flybar.
I've subscribed to the post and am looking forward to hear more about this one and your other RCT 500 design!
Best of luck!
Paul
Bunyan is offline Find More Posts by Bunyan
Old Aug 02, 2007, 02:12 PM
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
IMO they have just about everything right...the weight is at 3lbs, the gear ratio is where it needs to be....the only sucky thing is the 6mm main shaft...it really needs to be 8mm IMO...But we'll see....
when are they coming to market?
Geneween
geneween is offline Find More Posts by geneween
Old Aug 02, 2007, 02:29 PM
Cape Town, South Africa
Joined Jan 2005
Looks nice. Interesting MFS head design...
What length blades does it run front and back?
Can you post some closeup photos of the swash servo setup, and other main frame bits?
aragon is offline Find More Posts by aragon
Old Aug 02, 2007, 02:50 PM
Joined Jan 2006
Looks sweet. More pics would be cool. Let the battle of the 500s begin lol.
tcfrum323 is offline Find More Posts by tcfrum323
Old Aug 02, 2007, 03:45 PM
Fly-Bar? What Fly-Bar?
blade strike's Avatar
Big Bear Ca.
Joined Jan 2006
If its the same as the smaller sjm ... you should be able to mount that motor on top... Can you confrim for us scott?
blade strike is offline Find More Posts by blade strike
Old Aug 02, 2007, 03:59 PM
Take it easy
SlowRide's Avatar
Tampa, Florida USA
Joined May 2007
I asked this question at the 'other' forum so I guess I must bring it here now.
I noticed that the flybar is above the main blades on this heli. Most 'larger' helis, that I seen, have the flybar under mains. Mostly the 'smaller' helis, I have seen, have the flybar above the main blades. Would this factor into anything about this heli or it doesn't matter if the flybar is either above or below.
Rich
SlowRide is offline Find More Posts by SlowRide
Old Aug 02, 2007, 04:22 PM
California
Joined Jun 2006
I will post a few more shots shortly and get some more info after our next meeting with SJM engineering later tonight. The feedback recieved so far is appreciated.
Scott
Old Aug 02, 2007, 04:25 PM
California
Joined Jun 2006
Rich
Rich, the floating upper flybar design in a heli this big should prove interesting as we have found the upper flybars can offer a better roll rate. Plus, this design is typical for the smaller SJM exotics and since this is a blown up version of the SJM400 PRO, it makes sense they are keeping things somewhat the same.
Scott-
Old Aug 02, 2007, 05:29 PM
Joined Jan 2006
Rich
There are actually a few larger helis with overslung flybars, the Raptors 30-90, Helenseit 3dnt-3dmp, and some Logos.
Old Aug 02, 2007, 05:41 PM
California
Joined Jun 2006
Yes, this is true, but I am not aware of any that have floating upper flybar systems... Maybe someone can chime in if they know.
Scott
Old Aug 02, 2007, 05:45 PM
Take it easy
SlowRide's Avatar
Tampa, Florida USA
Joined May 2007
Thanks Scott for the reply. That is a very interesting head setup for sure. I'll keep my eye out for the future flight videos and the announcement of the 600 size of that heli.
tcfrum323, You notice I said "that I seen" and as you can tell, I haven't seen much.
Rich
Old Aug 02, 2007, 05:48 PM
California
Joined Jun 2006
Geneween
Hiya Gene,
Well, this was a question I had based on what you and I have discussed in the past privately, but due to the size of frame (or the lack thereof) and the low weight, they feel confident 6mm is good to go. I am going to get more clarification on a few topics tonight. We still need to help finalize the canopy design, which I will post in a sec.
Target release is in 3 weeks.
Regards,
Scott
Old Aug 02, 2007, 05:55 PM
California
Joined Jun 2006
OK, here is candidate #1 for the canopy. If anyone has canopy design experience and is also proficient in CAD design, we can talk about a mutually beneficial venture (hint hint)...
Scott-
Old Aug 02, 2007, 06:17 PM
California
Joined Jun 2006
Here are a few more shots of the top side and how easy it will be to stack popular lower cost 3S batteries.
Regards,
Scott
Discussion The SJM500 Thread Scott_RC-TEK Mini Helis 20 Aug 08, 2007 12:23 PM
