Old Mar 16, 2011, 10:46 AM
Nelapaty is offline
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Originally Posted by alex26i View Post
Has Anyone Put a gyro on this plane?? Nelapaty, I pretty much just found a few people online who had them, that never built them. Maybe they just got foam fliers.. Up and flying in minutes instead of days.
GyroNow that's something that I have not thought of yet That would definitely make things interesting and it's possible all your worries would be gone Try it and let us know
I definetly understand the setup part
Nelapaty is offline Find More Posts by Nelapaty
Old Mar 16, 2011, 03:03 PM
Ryleh is offline
Find More Posts by Ryleh
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
As far as Gyro's go I've got them on most of my RTF/ARTF foamies (cheap'o gain e-sky gyro for 8gbp).
However I would never put it on any of my balsa/composite models? 600-700gbp in the air all dependant on cheap 5-8gbp component - thanks but no thanks! Probably the most stupid thing you can do!
I've used gyros for smaller lighter models to stabilize them in windy weather - bigger birds like this can handle that kind of wind much easier and if the wind is too big and you need a gyro - I don't think you should take off in the 1st place!
General question however - did any one ever try using a good heading lock gyro for ailerons like this futaba one? http://www.sussex-model-centre.co.uk...xd.asp?id=1847
Ryleh is offline Find More Posts by Ryleh
Old Mar 16, 2011, 04:56 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Um, if you're coming from helicopter land you'd have no hesitation about the reliability of a good gyro. There is zero to worry about on that front, and the helis are far more expensive than this Cessna.
But gyro setup... oh boy, that could be painful.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Mar 17, 2011, 08:13 AM
alex26i is offline
Find More Posts by alex26i
United States, MI, Portage
Joined Oct 2010
Well that is why we have forums, To ask questions and get feedback from people with experience. SO If I understand the logic. Cheap planes fly better with a gyro? And a plane that should be more responsive don't work well with a gyro?? Isn't the idea the gyro would just help compensate for maybe the Torque? I have not tried it, Just have read about it on gliders and other planes. Didn't know it was a bad idea for something like this.
New Walkera H100D01 Mini Plane with a 3-Axis Gyro Stabilizer Overview (5 min 8 sec)
Radio Control Plane (6 min 30 sec)
alex26i is offline Find More Posts by alex26i
Old Mar 21, 2011, 03:25 AM
fazcoitia is offline
Find More Posts by fazcoitia
Joined Mar 2011
CG balance
Hallo, I'm finishing the CMPro Cessna 182 40 and is the most tail-heavy I've never built-up; some 9.5 oz. unbalanced with the CG 70 mm. from the root leading edge wing as stated in the instruction book (68-73 mm.). Saito 50 engine
What should I do?
Thanks in advanced
fazcoitia is offline Find More Posts by fazcoitia
Last edited by fazcoitia; Mar 21, 2011 at 03:49 AM. Reason: forgot the engine mounted and mm. instead cm.
Old Mar 21, 2011, 07:40 AM
toddsl is offline
Find More Posts by toddsl
toddsl's Avatar
Connecticut, USA
Joined Oct 2008
What should I do?
Thanks in advanced
Here was my solution. I added 7 oz. in self sticking tire balance weights to the engine mount. Don't buy these in the small hobby packs. It's a rip-off. Go to a tire store and see if they'll sell you some. They are dirt cheap. The store I went to actually gave me a pound for free when I told them what they were for.
It doesn't really help to add weight to a plane that is already heavy but there really isn't any way I saw to reduce weight back by the tail.
Oh and notice the missing nose gear on mine. That robart strut is very strong. Had a hard landing and the gear ripped out of the firewall with no damage to the nose strut. So that brings me to my question. Anybody done a taildragger conversion? I am planning to fix the nose gear but recently considered a conversion since I mostly fly off grass.
toddsl is offline Find More Posts by toddsl
Old Mar 21, 2011, 11:18 AM
BennettOZ84 is offline
Find More Posts by BennettOZ84
Swinger. Heli and planks!
BennettOZ84's Avatar
United States, OR, Foster
Joined Mar 2007
That looks like it would be a pretty easy fix on that firewall. I think fiberglass is easier to work with then balsa. Just a lot more messy!
BennettOZ84 is offline Find More Posts by BennettOZ84
Old Mar 22, 2011, 10:55 AM
Joined Mar 2011
CG and nose gear CMP Cessna 182 50
First of all many thanks and I'll add the tire balance weights. See the nose gear installed in my plane. Do you think it could be enough to resist hard landings?
Old Mar 27, 2011, 03:22 PM
kw5368 is offline
Find More Posts by kw5368
United States, WV, Beverly
Joined Mar 2004
I ran across this thread and wanted to let anyone know who is looking for one of these can purchase it here:
http://ak-models.com/mm5/merchant.mv...egory_Code=CMP
Ken
kw5368 is offline Find More Posts by kw5368
Old Apr 03, 2011, 06:33 AM
Ryleh is offline
Black Box hogger
Ryleh's Avatar
London
Joined May 2009
If anyone of you guys is doing an electric conversion and using an custom motor mount like me and Andrew here - I wrote the steps here for calculating the offset of the motor mount to get the right down thrust and left thrust angles right and still get the shaft coming out of the middle:
http://www.rcgroups.com/forums/showt...3#post17864923
Old Apr 03, 2011, 07:02 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Impressive Ryleh!!
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Apr 10, 2011, 12:29 PM
alex26i is offline
Joined Oct 2010
So I have looked through the tread.. The robart Strut keeps comming up. I know a few other guys have found different options.. Anyone else feel there are better cost effective places to get this??
Old Apr 10, 2011, 01:00 PM
alex26i is offline
Joined Oct 2010
Anyone else seen an motor mount that looks like this??
Old Apr 11, 2011, 12:29 AM
Visor is offline
Find More Posts by Visor
Visor's Avatar
Canada, BC, Langley
Joined Aug 2008
This is my setup - I made a motor mount out of 1/4" steel plate and placed the battery as far forward as possible. All this weight in front is needed for the proper CG.
Description: Name: PICT4076.jpg
Description:
This is modification to cowling for easy battery access:
Description: Name: PICT4083.jpg
Description:
One of the first flights
CMPCessna182.m4v (1 min 40 sec)
Visor is offline Find More Posts by Visor
Old Apr 11, 2011, 08:06 AM
Nelapaty is offline
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Very nice...
New project Cessna Skymaster large size! bruff Scale Kit/Scratch Built 54 Sep 21, 2009 07:03 AM
Help! Needs help on new Wattage Cessna 182... tnsfrk Parkflyers 19 Nov 26, 2004 10:31 PM
New UltraFly Cessna 182 available now Basketcase Parkflyers 2 Aug 22, 2004 10:43 PM
New pilot gives Push E-Cat maiden flight!(long) Markman Foamies (Kits) 6 Jan 27, 2002 02:22 AM
New Zagi almost done! Ready for maiden flight! Crete1 Foamies (Kits) 1 Sep 05, 2001 10:35 AM
