Old Jan 29, 2010, 01:57 PM
Aros.MotionRC is offline
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
Thanks for the tips Sam...So trim the elevator to about 1/4-1/3 down? My buddy also said he felt like the wings were way off (it wanted to keep tipping to the right and trimming helped but he said he felt like he still had to fight it throughout the short flight).
He said the CG was dead on per the instructions but something just felt way off he said.
Aros.MotionRC is offline Find More Posts by Aros.MotionRC
Site Sponsor
Old Jan 29, 2010, 08:42 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Probably rudder trim... that rudder is pretty darn aggressive (just like the real thing).
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jan 29, 2010, 10:14 PM
Maple Valley, WA
Joined Apr 2006
So by rudder trim do you mean making sure it's dead center to the vertical stab or are we talking limiting the throws?
Site Sponsor
Old Jan 30, 2010, 01:12 AM
Joined Jun 2006
We're talking making sure the plane is flying exactly coordinated, so the loading on both wings is the same. That may mean that the rudder is quite some distance off center parked on the ground.
This plane has such a strong torque reaction that a throttle to rudder mix may be needed to keep it trimmed all the way from glide to full throttle.
It does not fly like a model, it flies exactly like the real thing, and in a real 182 you need to move the rudder about half its travel between glide and full throttle, or you WILL spin it. The CMP is just the same.
Old Jan 30, 2010, 01:52 AM
Maple Valley, WA
Joined Apr 2006
Wow. I did not know that. This is vital info for sure. Thank you.
Site Sponsor
Old Jan 30, 2010, 11:34 PM
Tracon is offline
Find More Posts by Tracon
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
At my field, the guys told me that my CMP Cessna didn't stand for "China Model Products" by actually "Cement Model Products"
Sam
Tracon is offline Find More Posts by Tracon
Old Feb 01, 2010, 03:05 PM
rawdealad is offline
Find More Posts by rawdealad
Joined Nov 2008
Hey all,
Still got my eyes on this beast. Can buy it for 120, so not a bad price at he moment.
I have my faith in e flite hardware, was hoping that you may be able to help me out. Could I get away with the power 46, or is a power 60 a must? And what batt 4/5/6s ahh!! The endless choices.
Help.
rawdealad is offline Find More Posts by rawdealad
Old Feb 02, 2010, 12:26 AM
BennettOZ84 is offline
Find More Posts by BennettOZ84
Swinger. Heli and planks!
BennettOZ84's Avatar
United States, OR, Foster
Joined Mar 2007
I am going with the power 46 with a 5s 5000mAh battery and a 100 amp ESC. I have not been able to start the project, but that's the setup I am going with.
BennettOZ84 is offline Find More Posts by BennettOZ84
Old Feb 02, 2010, 11:10 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Could you explain that a little more? How much mix? I've got this plane on the workbench about 90% complete. I haven't touched it in months due to other planes, but I'm feeling the need to finish it now. I was thinking about setting up the ailerons with a little reflex to help with the tip stall.
SteveC68 is offline Find More Posts by SteveC68
Old Feb 02, 2010, 02:35 PM
Maple Valley, WA
Joined Apr 2006
I've decided to sell mine. I don't want a Cessna that wants to snap and tip stall at the drop of a hat.
Site Sponsor
Old Feb 02, 2010, 05:18 PM
Joined Jun 2006
That's a shame... it isn't that hard to deal with, you just HAVE to do the rudder trim bit.
The mix is unfortunately going to depend on what prop you're using and how much power your motor develops with that prop, so I can't tell you.
So, the trim trick:
Tape about a meter of string to each wingtip. Both strings should be the same length or their drag won't balance and it won't work.
Always, always fly this plane being careful to keep it coordinated in turns. You can tell if it is coordinated because the tail should fly centered between the strings at all times.
Now take off, get it up high, and trim for level flight at about 40% throttle or so. Trim elevator first, then rudder, then ailerons. You can tell when the rudder trim is right when the tail flies centered between the strings. It's safe to land now, but DO NOT close the throttle on approach until the wheels are a few inches from the runway. Before you do land it, you can also get a feel for how much stick or how many clicks of trim it requires to keep the tail centered throughout the throttle range.
Land it, set up a mix that does that rudder movement with throttle automatically, and then make a few more flights to practice your turn coordination with the strings on.
This will work with any fussy scale model. Fullsize airplanes do, of course, have instruments to help you keep it coordinated (and they're much snappier than even this model).
Old Apr 22, 2010, 02:05 AM
Cathurga is offline
Find More Posts by Cathurga
teamwork, do it my way!
Dubai, UAE
Joined Jun 2007
Hey all,
I know that the CMPro Cessna seems to have been discontinued for some time now, and is not available through the normal agents like Raidentech and Nitroplanes...
I have however, stumbled across the following from AMD Hobby....it looks the same, can anyone shed some light on this?
http://www.amdhobby.com/product_info...roducts_id=376
If you have problems getting through to that link, try the www.amdhobby.com and browse through the nitroplanes..
Cathurga is offline Find More Posts by Cathurga
Old May 30, 2010, 10:27 PM
Miksuka is offline
Find More Posts by Miksuka
Joined May 2010
Where is the C.G. point ?
I bought used CMPro Cessna 182 Skylane 50-size, but didn't get the manual. I have been trying to contact CMPro, but no answer.
I need to know where is the C.G. point, could someone help me ?
Miksuka is offline Find More Posts by Miksuka
Old Jun 01, 2010, 08:12 AM
Joined Mar 2007
I wouldn't rely on the mentioned CG of the instructions anyways. Get your self a CG machine or build one as they are pretty simply to do. Load it up with all your gear and start finding it your self.
It has been a pretty common occurrence for the CG to be way off between different models with this bird. Look over the thread a bit and you might find your answer already, or at least a good starting reference point.!!
Old Jun 08, 2010, 06:10 PM
Nelapaty is offline
Find More Posts by Nelapaty
KK4NZS
Nelapaty's Avatar
Virginia
Joined Sep 2006
Cg is 68-73mm from leading edge of the wing according to the manual.
Nelapaty is offline Find More Posts by Nelapaty
New project Cessna Skymaster large size! bruff Scale Kit/Scratch Built 54 Sep 21, 2009 07:03 AM
Help! Needs help on new Wattage Cessna 182... tnsfrk Parkflyers 19 Nov 26, 2004 10:31 PM
New UltraFly Cessna 182 available now Basketcase Parkflyers 2 Aug 22, 2004 10:43 PM
New pilot gives Push E-Cat maiden flight!(long) Markman Foamies (Kits) 6 Jan 27, 2002 02:22 AM
New Zagi almost done! Ready for maiden flight! Crete1 Foamies (Kits) 1 Sep 05, 2001 10:35 AM
