Old Feb 27, 2009, 07:54 PM
AllSpunUp is offline
Find More Posts by AllSpunUp
King of the Yard sale!
AllSpunUp's Avatar
United States, AZ, Surprise
Joined Jan 2009
I'm also doing an e conversion on this plane. I using the turnigy 50-65D 270kv motor wich I think is a lil bigger than needed but I like more power than needed I think a 5S1P 3000-4000mah would be okay on this setup rite? Im looking to be in the ballpark of 1300W. Im waiting on parts at the moment but ill get some pics up as soon as I get it all together!!
AllSpunUp is offline Find More Posts by AllSpunUp
Old Feb 27, 2009, 08:56 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
1300W is plenty. Not insanely overpowered, but definitely plenty of power.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Feb 27, 2009, 09:16 PM
AllSpunUp's Avatar
Joined Jan 2009
Good, that's good to hear. Hey i have a question?? Were can i pickup a spinner for a 8mm motor shaft. I'm looking everywere and it seems like 6mm and below is all I can find??????
Old Feb 28, 2009, 08:28 AM
NFANut is offline
Find More Posts by NFANut
NFANut's Avatar
Noblesville, IN
Joined Mar 2008
Dave Brown Products is one option.
NFANut is offline Find More Posts by NFANut
Old Feb 28, 2009, 05:13 PM
AllSpunUp's Avatar
Joined Jan 2009
Thanks! Heres what i'm thinking for a lipo:
6s1p zippy flightmax 5000mah 20c
On this lipo setup with the stated above turnigy 50-65 270kv outrunner does anyone have a guess as to were i should start with a prop selection?? Im thinking maybe 15x8????? I'm really not sure. Ill be runing a 80 amp ESC. Any input would help! Thanks
-Jeff
Old Mar 19, 2009, 11:35 PM
Downwind3Zero is online now
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Hi
How did you all who use the Robart 654 fasten the wheel pant to the strut? Can't figure out a clever solution for it.
Rehards, Chris G
Downwind3Zero is online now Find More Posts by Downwind3Zero
Old Mar 20, 2009, 10:19 PM
NFANut is offline
NFANut's Avatar
Noblesville, IN
Joined Mar 2008
I used epoxy. After getting the pant drilled out and slots filed in it for the stand offs on the disassembled strut to pass through, I used a small amount of epoxy and "tacked it" in position. I then used more epoxy (small amounts at a time) and filled it in, inside and out until it was solid. A little red and white paint to touch up over the epoxy and there you go.
No it's never coming off, and if I crash it's a goner, but... it's not supposed to crash right?
I tried to think of a way that wouldn't be so permanent, but nothing I came up with would have been very secure. Epoxy worked for me.
Old Mar 21, 2009, 12:08 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
-Jeff
Jeff,
I think your kv is too low for this application with 6 cells and you will need a monster prop to get it to draw the wattage you probably want. I have a 50-65 400kv Turnigy on 6 cells that I run a 16x8 APC -E prop. I also run a 50-65 270kv on 8 cells with a APC-E 18x10 and helped a newbie to test the power draw of his 580kv version on 6 cells this morning!
To get your 270kv motor to draw say 1000 or so watts I reckon the prop diameter will need to be 20 or 21 inches! I suspect the undercarriage on the Cessna isn't long enough!
Could I suggest you work out what diameter prop you can safely run first, then the motor kv selection should be relatively straight forward. On 6 cells, a 580kv Turnigy 50-65 will be limited to either a 12 or 13 inch prop within the peak current limit, 400kv will be 15 or 16 inches and the 270kv version, as I said, much larger again.
I would also suggest that the wing area isn't that big on this model and that if you intend to use a 6 cell pack maybe a 4000mAH (or even smaller!) may be more appropriate for this model.
Hope this helps!
Cheers
Peter
Peter M is offline Find More Posts by Peter M
Old Mar 21, 2009, 01:43 AM
NY, Rochester
Joined Oct 2003
Thanks NFANut!
Chris
Old Mar 21, 2009, 12:16 PM
NFANut is offline
NFANut's Avatar
Noblesville, IN
Joined Mar 2008
Your welcome Chris.
Not sure these pics are worth a 1000 words but I thought you might want a closer look at how mine turned out. I was going to take these last night but it was late.
Regards,
Jeff
Old Mar 22, 2009, 05:09 PM
NY, Rochester
Joined Oct 2003
Now that is sweet Jeff! Thank you very much!
So when it's glued the wheel pant can't rotate?
Regards, Chris
Old Mar 22, 2009, 06:48 PM
NFANut is offline
NFANut's Avatar
Noblesville, IN
Joined Mar 2008
No it won't rotate. It feels quite a bit more solid than the main gear wheel pants.
I reached up inside the wheel pant with a tooth pick on needle nose pliers and applied the epoxy so it could adhere to the rough inner surface of the pant. There is enough on the shaft to keep it from moving.
Old Mar 23, 2009, 02:31 AM
NY, Rochester
Joined Oct 2003
Great!
Chris
Old Mar 23, 2009, 11:49 PM
munz is offline
Find More Posts by munz
Joined Apr 2007
Tracon, I recently bought this airplane and was wondering why you decided to epoxy the two wing halves together? I am thinking of doing this cause th blue retainers that stick out of the center piece always come loose after a week or so. Plz help?!?!
munz is offline Find More Posts by munz
Old Mar 24, 2009, 01:08 AM
Tracon is offline
Find More Posts by Tracon
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
I used epoxy and they've never failed me...
Knock on wood...
I would never trust the stock setup or set screws...
Good luck...
Sam
Tracon is offline Find More Posts by Tracon
New project Cessna Skymaster large size! bruff Scale Kit/Scratch Built 54 Sep 21, 2009 07:03 AM
Help! Needs help on new Wattage Cessna 182... tnsfrk Parkflyers 19 Nov 26, 2004 10:31 PM
New UltraFly Cessna 182 available now Basketcase Parkflyers 2 Aug 22, 2004 10:43 PM
New pilot gives Push E-Cat maiden flight!(long) Markman Foamies (Kits) 6 Jan 27, 2002 02:22 AM
New Zagi almost done! Ready for maiden flight! Crete1 Foamies (Kits) 1 Sep 05, 2001 10:35 AM
