Old Aug 02, 2007, 12:55 AM
Tracon is online now
Find More Posts by Tracon
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
New CMP Cessna 182 50 Size Maiden Flight !!!
Hi Guys,
Sorry about cutting the build thread short, I got busy with work...
I finally got my Cessna finished tonight and I took her out for the maiden flight.
Power setup:
Motor: AXI 4130/16
ESC: Jeti 77
Battery: Thunder Power Extreme 6s 5000
I had to do many mods and change up a lot of the hardware to feel safe in the air with this plane...( I can explain later if you're building one... )
Here she is sitting pretty waiting for her maiden flight:
In-Flight Shot:
Power off hot landing:
The flight went GREAT !!!
She needed 6 oz of weight to balance, she seemed a little nose heavy..but like someone once said... "I've never seen a plane crash on a maiden flight that was a little nose heavy"
She cruises around at about 1/4 throttle no problem...she does have some tip-stall characteristics at low speeds though....so be careful !!!
Any questions, I'll do my best to answer...
All the best,
Sam
Tracon is online now Find More Posts by Tracon
Old Aug 03, 2007, 07:22 PM
Erwin Z is offline
Find More Posts by Erwin Z
Erwin Z's Avatar
México, Jalisco, Guadalajara
Joined Sep 2006
Hi Sam,
it looks gorgeous, congratulations. what did you do with the nose landing gear, did you use the stock one?
I will build mine glow powered but I will apreciate your comments about the changes you made on the hardware.
Thanks!
Erwin Z is offline Find More Posts by Erwin Z
Old Aug 04, 2007, 12:22 AM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Yes, do please let us know what mods you did.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Aug 04, 2007, 07:04 AM
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
Hi Guys, just running out the door to work...
I put another flight on yesterday, the plane flies awesome , but the nose gear did fail on me yesterday...just after landing I bounced in a small rut and bent the nose wire all to heck and cracked the nose wheel pant up pretty bad..
I'm going to replace the wire and hardware, I should have listen to others about the nose gear issues...
My all up weight is around 9 Lbs 9 oz...
I had to add 6 oz of lead to the nose to get her to balance...
I'll give you more details on the mod tonight when I get home....
Thanks for the nice feed back...
Sam
Old Aug 16, 2007, 01:01 AM
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
Hi Guys,
Finally got a chance to get out tonight to try out my new Robart 654 Nose Strut...
This thing is GREAT !!!
If you build this plane:
Replace the Nose Strut...
Replace all the Servo connectors, don't use the EZ connectors inc in the kit...
Epoxy both wing halfs together...
Goto 2.5" Du-Bro Wheels...
Remove wheel pants for field or flying off grass...
Here's some pictures from the flight:
Rotating on take-off:
First pass:
Coming around up the flight line:
Lining up for a landing:
Coming over the threshold:
Setting down:
Hope you like the pictures,
Sam
Old Aug 16, 2007, 02:56 PM
tommyeflight89 is offline
Find More Posts by tommyeflight89
ARF Hater Club
tommyeflight89's Avatar
Toronto, Ontario
Joined May 2004
That looks amazing! Does it come out of the box lookign that nice?
Excellent pics.
tommyeflight89 is offline Find More Posts by tommyeflight89
Old Aug 16, 2007, 08:59 PM
Joined Jun 2006
My Lancair did, so it's entirely believable the Cessna does.
Axi 4130/16 and 6s 5000... that's a heck of a lot of power. How overpowered is it? I'm starting to wonder if the motor I have in mind isn't enough (Hyperion 3025/10 on 3s2p 3300, or maybe 4s2p A123). Motocalc says it's plausible for a scale model.
Old Aug 16, 2007, 09:08 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
I have seen allot to Cessnas in my life, and yours looks as real as real can be. The pictures are outstanding. The droop wing tips lead me to belive that it could be a STOL airplane with some slats (I forgot, I think they are slats, I am wrong they are called wing fences) ontop of the wings and you can modify it for float flying.
Congrads on the maiden, you have one bitchen airplane, you did a great job with the kit.
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old Aug 16, 2007, 09:10 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Oh my word, that looks amazing. Great photos! I've looked at that plane many times thinking maybe it'd get in the queue. Did you get any video perhaps of it flying? I'd sure like to see what a 4130 would do in a plane like that, especially with those extreme packs. That's a lot of battery to lose if you ever down that baby! Video!
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Aug 16, 2007, 09:12 PM
Joined Jun 2006
Yep, it looks just like a fullsize machine (ZK-JPN) that belongs to a friend of mine... his is STOL-kitted.
Old Aug 16, 2007, 09:46 PM
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
Hi Guys,
Thanks for all the nice comments....
I can't take any credit for all of our pictures, that's the work of my better half "Mrs. Tracon"
I got in from two more flights tonight, I did a couple of tests tonight:
1. Stall test (About 8 mistakes high)
Result: Nose came up slow...the plane stopped flying and she did a very gentle pitch down with a slight roll to the right...
She regained speed and with a little power was back flying...
2. Take off from rough soccer field grass
Result: She took a bit to get rolling once up to speed she lifted off the grass ok, but in an instant not quit having enough power on she rolled to the right sharply and just about scared a turd out of me...
I thought.."Oh boy here comes the cart wheel the guys with the 83" version were talking about..."
I poured on the power and she righted herself and was flying fine !
3. Take off from blacktop with the flaps down...
Result: I usually only take off at about half to two thirds throttle, with the flaps down she got up to speed and in half the length of a normal take off she jumped into the air and was flying awesome !!!
So things I learned tonight about my new bird, she likes to be flown a little fast, she likes to have a little rudder added to her turns and pulling her nose up into a stall isn't too scary as long as you have enough altitude to get her back flying again..
As for your questions about the AXI 4130/16, I went with this setup because this is a good match for a .60 size glow plane...
I plan to add floats to this plane, so the extra power will be needed for that application later...
My rule of thumb is.....you can never have too much power...it's what you do with the power that determines whether your plane flies or dies !!!
Is it too much power ??? Yes if you fly it wide open and do aerobatics with it...is that what this plane was designed for ??? NO !!!, so fly it for what it was designed for and it'll stay in one piece...
With my AXI 4130/16 with the Thunder Power 6s 5000 I'm not really sure how long I can fly, I'm setting my timer for 12 minutes now, but still have lots of juice left over...
A full charge on this battery is about 25.0 to 25.4 volts, after 12 minutes of gentle 1/4 to 1/3 throttle fly I have about 23.5 volts left on the battery...
I take off at about 1/3 to 2/3s throttle, she climbs out nice and flies quite stable and scale at about 1/4 to 1/3 throttle...
I highly recommend this setup for this plane...
All the best,
Sam
For pictures of our other planes,
To visit our personal site, please go to: www.teamtracon.com
Old Aug 16, 2007, 11:58 PM
papasmurf is offline
Find More Posts by papasmurf
"I passed on the kool-aid"
Waco, TX
Joined Jan 2004
Looks AWESOME!. CMP has really brought this kit a long way it seems. It now looks better than the great planes version I think.
papasmurf is offline Find More Posts by papasmurf
Old Aug 17, 2007, 12:41 PM
Team Tracon!
Tracon's Avatar
Canada, BC, Gibsons
Joined Jan 2003
Went out this morning and got a couple more flights on her...
I'm getting a more and more relaxed with this bird...
Flew around with full flaps down...nice and stable....
Awesome for landings...
How are you guys making out ???
I see that a guy posted a picture of his Robart strut in the stock wheel pant..
Here's a link:
(Hope he doesn't mind us borrowing it )
See, it does fit in there...
Sam
Old Aug 19, 2007, 08:25 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
Got to say that is one sweet looking plane. Good luck with her, she's a beauty.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Aug 23, 2007, 10:17 PM
golddigger is offline
Find More Posts by golddigger
Do not go gentle
golddigger's Avatar
Black Hills of South Dakota
Joined Mar 2004
You sure did a nice job on that plane Sam and Beverly once again nailed the pictures. Sweet!!
I wish you many many enjoyable flights with her. Hi to Beverly for me.
golddigger
golddigger is offline Find More Posts by golddigger
New project Cessna Skymaster large size! bruff Scale Kit/Scratch Built 54 Sep 21, 2009 07:03 AM
Help! Needs help on new Wattage Cessna 182... tnsfrk Parkflyers 19 Nov 26, 2004 10:31 PM
New UltraFly Cessna 182 available now Basketcase Parkflyers 2 Aug 22, 2004 10:43 PM
New pilot gives Push E-Cat maiden flight!(long) Markman Foamies (Kits) 6 Jan 27, 2002 02:22 AM
New Zagi almost done! Ready for maiden flight! Crete1 Foamies (Kits) 1 Sep 05, 2001 10:35 AM
