Old Aug 01, 2007, 11:09 PM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
Build Log
Mig-35 Twin EDF w/ Thrust Vectoring
Hi all,
I am building a Mig-35 (Mig-29 w/ all hop-ups) with twin Hyperflow EDF's, ~600 watts, and thrust vectoring. Some of the jet was based on John Bright's Mig-29 plans, but most of it I just scaled off of pictures. It has about a 31" wingspan, and I hope it will weigh less than 30 oz RTF. I plan on glassing the whole thing before paint. It will use 5 channels, 1. THROTTLE 2. ELEVON 3. ELEVON 4. THRUST VECTOR YAW 5. THRUST VECTOR PITCH. Thrust vectoring will only be pitch and yaw, no roll as of now.
The thrust vectoring units are made of carbon and foam. The cone is 3mm depron foam , the outer ring was cut out of an Alpha 60 mm fan unit (finally, I found something this fan is good for ), and all mounting and pivoting hardware is either flat carbon or small carbon rod. This is a rather simple gimbal made with the strongest and lightest material I could find. The entire vectoring unit weighs around 12 grams (plus the weight of 2 servos and 3 push rods).
I hope to have her flying within a week or two, but I definately want to take my time to do it right.
Thrust vectoring demo video here http://www.rcgroups.com/forums/showt...10#post7913311
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Aug 02, 2007, 01:06 AM
BpwrJet is offline
Find More Posts by BpwrJet
my brother's keeper
BpwrJet's Avatar
Joined Dec 2006
nice work man - link to the plans??
BpwrJet is offline Find More Posts by BpwrJet
Old Aug 02, 2007, 01:56 AM
Denver, CO
Joined Jul 2006
Thanks. The plans will be one of the last things I accomplish, after I get her flying and such.
Old Aug 02, 2007, 03:57 AM
Dentar is offline
Find More Posts by Dentar
Joined Apr 2005
That is cool.... Could you post more info/pics/video of the thrust vectoring mechanism? Looks like its your own design, looks great.
DT
Dentar is offline Find More Posts by Dentar
Old Aug 02, 2007, 07:13 AM
Denver, CO
Joined Jul 2006
I have 'remodeled' the rod that connects the two outer gimbal rings w/ a tube that is epoxied into holes drilled in the rings.
Basicly how the gimbal works is the carbon unit moves up and down on a horizontal axis, and the foam cones move side to side on a vertical axis. The pics explain what I mean.
This assembly only weighs 8 grams.
Old Aug 02, 2007, 09:26 AM
FASTBEN is offline
Find More Posts by FASTBEN
Cumulus Altimus
FASTBEN's Avatar
United States, TX, Keller
Joined Feb 2002
cool
ben
FASTBEN is offline Find More Posts by FASTBEN
Old Aug 02, 2007, 01:45 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Very Nice work!!!
RCParkflyer is offline Find More Posts by RCParkflyer
Old Aug 04, 2007, 08:50 AM
Denver, CO
Joined Jul 2006
Here are some updated pics of her right now. She's not too far from her glass job.
Along with the turtledeck(s) being installed, I mounted the elevon servos in the underside of the rear section. I plan on mounting the flying elevators similar to the HET F-16. A brass tube will be glued into the elevator, and it will pivot on the carbon rod, and be secured w/ a wheel collar.
More to come soon....
Old Aug 04, 2007, 09:32 AM
Denver, CO
Joined Jul 2006
Here is a sweet video of a single-seat Mig-29 w/ mostly the same capabilities as a Mig-35. The best part is definately right after the takeoff.
http://www.youtube.com/watch?v=PWLYTAYG-9U
Old Aug 09, 2007, 08:00 AM
Denver, CO
Joined Jul 2006
I took the advice of my LHS owner, and decided to make sure the Mig flies ok before I put too much time into it (glass, fill, etc.). I am going to maiden her this morning. Hopefully, I'll have an opportunity to try out the thrust vectoring too.
Old Aug 09, 2007, 09:59 AM
Denver, CO
Joined Jul 2006
Well, she flew good until I tried using the vectoring. I started with a little left thrust, and she yawed a little, so like an idiot, I jammed it all the way left. She did a funny snap roll, and when I let go of the rudder (left vector), it continued to spiral. I chopped the throttle right away, but it didn't help too much. Straight in nose first.
Once I got her home, I investigated what could have done that, and it turns out that the control horn on the right cone had popped loose, and the cone was stuck in left yaw.
The damage on the fuselage is only from the nose to the aft part of where the canopy sits, so she's definately rebuildable. I didn't like the shape of the nose anyway.
Old Aug 09, 2007, 10:45 AM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Sorry to read about your crash. I'm glad to read it's fixable. I love these kinds of cutting-edge models.
I was just posting a note to say that I don't think that yawing the nozzles will provide the effect you desire.
I know that the full-size Su-37 and F-22, both use elevon mixing on their nozzles. It stands to reason that the full-size MiG-35 uses the same type of mixing as these other two aircraft.
How difficult would it be to change the mixing? Can you easily connect the nozzles to the tail feathers?
DanSavage is offline Find More Posts by DanSavage
Old Aug 09, 2007, 10:59 AM
Denver, CO
Joined Jul 2006
Hi Dan,
It wouldn't be too hard to change the vectoring to being capable of roll. Another servo and another channel would do it, and would make it able to do roll, pitch, and yaw. If I hard mounted the cones to the gimbal rings (took out the yaw capabilities) then I could do roll and pitch using the same servos and same # of channels.
Honestly, I'd like to be able to do what the Mig does in the video I posted earlier. The only way to do that would be w/ some yaw, so I think I'll keep it the same for now.
As far as connecting it to the elevons, it would be somewhat tricky, but I wouldn't want to do that anyway cause I want to be able to turn the vectoring on and off. As of this morning when I flew it, the yaw was controlled by the rudder, so it was always on, but the pitch didn't move until I flipped (what would be) the gear switch on my Tx.
Old Aug 09, 2007, 11:12 AM
Denver, CO
Joined Jul 2006
Here are two pics of what she looks like now. All of the damaged foam was cut away (it was too ugly to take pics of it all dorked up). The turtledeck popped off in the crash, but was undamaged and should be easily reattatched. As you can see, it should be easy enough to splice in some new foam on the front end.
Old Aug 09, 2007, 11:37 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Hi Dan,
I did a quick search online and I'm wrong. The MiG-35 (MiG-29OVT) has 3D nozzles.
Here's a couple of links:
Mikoyan-Gurevich MiG-29OVT promo video (3 min 4 sec)
http://www.airsceneuk.org.uk/airshow...ovsky/maks.htm
At the very beginning of the video, you can see the nozzles yawing from side to side.
Discussion Foamie EDF w/ thrust vectoring? Elvis48 Electric Warbirds 2 May 09, 2007 08:16 PM
Discussion Power System for SU 35 twin EDF 3drc tim Electric Ducted Fan Jet Talk 1 Mar 09, 2006 11:58 AM
Discussion Need help power system SU 35 Twin EDF 3drc tim Foamy EDFs 2 Mar 09, 2006 08:11 AM
Yippee! Su-27 twin EDF and Mig-29 Twin EDF kit release imminent if enough interest? mjblack Electric Ducted Fan Jet Talk 159 Jun 18, 2004 01:29 AM
MIG 29 twin edf 50 darmar Electric Ducted Fan Jet Talk 14 Aug 14, 2002 09:31 AM
