Old Apr 17, 2012, 02:21 PM
Evel Knievel is offline
Find More Posts by Evel Knievel
"Audentes Fortuna Juvat"
Evel Knievel's Avatar
United States, GA, Columbus
Joined Oct 2008
Originally Posted by saffa365 View Post
Cheers guys
I noticed whilst rolling, my nose was dropping a bit , is this because I was flying nose heavy ?
I was flying on low rates as per manual, hopefully I'll get more flights in tomorrow and for rest of the week , weather permitting , so I can play with cg
The nose drops because of the drag the ailerons produce. I would set the CG to the factory recommended position and leave it.
Evel Knievel is offline Find More Posts by Evel Knievel
Old Apr 21, 2012, 10:51 AM
RJJ is offline
RJJ
Find More Posts by RJJ
RJJ
Joined Oct 2011
Hi have purchased one of these in purple from my local hobby shop.
Could somebody please post what the throws & expo should be for high/low rates recommended by precision aerobatics.
Did everybody use precision aerobatic settings or have people found better high/low throws & expo.
Also what's the best way of measuring the throw, I like the hanger 9 anglepro 4 in 1 but it's expensive, any good suggestions so my 1st maiden goes well.
The plane was built up & on display, I don't have the box or instruction manuel.
Does anybody use any mixes etc. I have put my ar8000 with satellite in there and will be using a dx8.
Thanks, can't wait to maiden it, if only it would stop raining.
RJJ is offline Find More Posts by RJJ
Old Apr 27, 2012, 02:27 PM
saffa365 is offline
Find More Posts by saffa365
Proudly South African
saffa365's Avatar
Joined Jan 2012
Here is pic of my bad boy ..
managed to get two batterys through tonight before it got to dark to tell top from bottom
love this plane
here are the throws as per manuall
low rates ail 15-20deg up and down 30% expo
rud 25 deg 35% expo
elev 45 deg 30% expo
High Rates Ail 40-45 deg Up and down Expo 70 %
Rud 45 deg expo 70 %
elev 45 deg expo 70
I just use the supplied deflection gauge
saffa365 is offline Find More Posts by saffa365
Old Apr 27, 2012, 05:35 PM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
What batteries are you using 2200 or 1800? I have flown an Addiction on 2200 but not on 1800.
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Apr 27, 2012, 08:12 PM
four stroke pwr is offline
Find More Posts by four stroke pwr
Sky Pilot
four stroke pwr's Avatar
United States, FL, Orlando
Joined Feb 2004
You've got me fired up to bring my Addy out tomorrow morning. Agreed that the recommended CG is spot on. I can barely fit my 2200, and I think I'll try the 1800 tomorrow. I do not like to give up flight time on this bird, however, with the smaller battery..
four stroke pwr is offline Find More Posts by four stroke pwr
Old Apr 27, 2012, 08:28 PM
ombudsman is offline
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
I use TP ProLite 2100 25C batteries with great success. They're quite light. They're expensive, but well worth the $$ IMHO. They last and last.
ombudsman is offline Find More Posts by ombudsman
Old Apr 28, 2012, 03:51 AM
p91304 is offline
Find More Posts by p91304
Fly Till You Die
p91304's Avatar
United States, WA, Battle Ground
Joined Sep 2009
My favorite battery right now is the Turnigy nano-tech 1800 mah 25-50C from Hobby King USA.
It will run for 9 1/2 minutes I set my timer for 8.
They will not puff up.
They are not expensive 1/2 the price of Thunder Power.
1800 is the perfect size for a balance between flight time and performance.
Those TP ProLite batteries are good, I had a little 1350 mah I used in the Addiction and it was super light.
It did get puffy after a while but still ran great.
I'm using the Castle Creations Phoenix 35 ESC which has been discontinued.
It works best on the 3.28 firmware version.
I have plenty of power with the thrust 20.
p91304 is offline Find More Posts by p91304
Old Apr 28, 2012, 04:08 AM
p91304 is offline
Fly Till You Die
p91304's Avatar
Joined Sep 2009
love this plane
rud 25 deg 35% expo
elev 45 deg expo 70
I like to run 55% expo on the high rate.
Old Apr 28, 2012, 10:36 AM
jgambill is offline
Find More Posts by jgambill
jgambill's Avatar
Joined Oct 2006
I have somewhat of a newbie question. This morning for the 3rd time my prop came off in flight. I have the CF spinner and I tightened the nut while holding back the collet with pliers. I have flown maybe 4 or 5 flights after doing this and off it came. Any suggestions?
jgambill is offline Find More Posts by jgambill
Old Apr 28, 2012, 10:50 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
Make sure the motor shaft and the hole in the collet are clean and free of oil. (use an solvent if need be)
Take a tiny bit of oil/grease (more like a smudge) and lightly lubricate the taper on the collet making sure none gets into the hole.
Refit your prop and go fly.... you should not have to use a pair of pliers to hold the collet, nip it up till the prop doesn't spin, then firmly hold the prop and give it the nut one last tweak.
demonGti is offline Find More Posts by demonGti
Old Apr 29, 2012, 05:08 AM
p91304 is offline
Fly Till You Die
p91304's Avatar
Joined Sep 2009
Video
Belly in hand catch, it gets a little tricky.
http://www.youtube.com/user/johnkdowflyer
Precision Aerobatics Addiction Hand Catch (4 min 38 sec)
Old May 01, 2012, 02:15 AM
saffa365 is offline
saffa365's Avatar
Joined Jan 2012
The only battery's I've flown in the addiction are the turnigy 2200 , nothing special , but seen as I'm not a crazy 3d pilot yet , they seem fine to me
Old May 01, 2012, 06:36 AM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Originally Posted by p91304 View Post
That's so cool. I remember my first attempt at a hand catch, it was with the little addiction. Cowl popped right off in my hand! Scared the cr@p out of me!
Sub
subsonic is online now Find More Posts by subsonic
Old May 01, 2012, 09:40 AM
slo-fly is offline
Find More Posts by slo-fly
certified crash instructor
Scottsdale Arizona
Joined Dec 2009
I just finished my yellow addy, I was able to get 55 degrees throw for elevator, I didn't push the elevator all the way into the fuse, I slid it back about 1/4" in the fuse and glued it. I am using hitec hs5065 servos, thrust 20, quantum 30 esc, and a hyperion 35c 1800mah lipo. The hyperion fits great in the tray, lipo weighs 139 grams with deans connector.
slo-fly is offline Find More Posts by slo-fly
Old May 01, 2012, 11:26 PM
slo-fly is offline
Scottsdale Arizona
Joined Dec 2009
Question about the prop, I plan on slow flying, would prefer more thrust over speed. I have an apc 11x5.5e, 11x3.8 slow fly and a xoar 11x6. I want to try the xoar first, it's 9 grams lighter than the apc 11x5.5e. I guess I'll start with a watt pull on the xoar and see what happens.
Discussion New Video Posted. lorenzo_MiniGP Motorcycles 4 Jun 12, 2007 04:25 PM
Discussion new video posted finallyaheli Motorcycles 3 May 27, 2007 11:14 AM
Discussion Precision Aerobatics Katana Mini video by aerofundan Copperhead South 3D Flying 12 May 29, 2006 11:20 AM
new video posted today ricktkenny Electric Plane Talk 5 Jan 03, 2004 08:29 PM
new Maui slope video posted Brian Courtice Slope 18 Jun 05, 2003 05:37 PM
