Joined Jun 2008
Hi all
seems the Graupner mc32 directly supports the serial protocol for modules connected to ext ppm. The only thing needed is a voltage converter to bring it down to 3.3V. I have an mc32 and an lp4dsm2 module, will test it and report back the results as soon as I get the voltage regulator. However, to select the correct regulator, I should know the current the DSM module draws is 50 mA enough? greez chris PS: I am thinking of this converter: http://uk.farnell.com/xp-power/ik120...0?Ntt=IK1203SA It seems to provide 75 mA @ 3.3V, I guess this should be fine? |
Still trying to get it to work here. I've now swapped in a MLP4DSM module, Still a no go. The led does light on the tx module, I'm still getting the 4/sec flash in bind mode. Not sure where to look now. I'm running C2PO's code only no changes or anything else on the arduino. Any and all ideas greatly appreciated. WOOHOO!!!!!!!!! We have success. After hours of troubleshooting and trying a total of 3 different modules (2 DX4E and 1 MLP4DSM) we have fully working spektrum module with the DX4E. All my mistake..... I had forgotten the TX pin on the Arduino, when I first soldered the arduino to the PCBoard. So I added the pin from the top and thought my connection to the PCBoard was fine. I just now soldered directly to the top pin of the arduino and waaalaaa SUCCESS. Thanks to al that have thrown out the ideas. Great Project I just finished flying my MQX with my old Futaba Conquest Radio (my first radio) THanks all. |
There is no irony. You take out the DSM2 rf module and use it with something that ISN'T a DSM2 transmitter.
See the first page of the thread for the answer to #2.. I think the channel values can be zero or the centermost value--this might not be the same for all receivers. |
I tried sending more than 6 to the DX4e and LP modules when working on the ER9X/DSM2 firmware and was unable to get it to work.
ER9X uses actual channel outputs when binding, which sets the correct turn on defaults. Pat MacKenzie |
Latest blog entry: er9x heli 450 heli set up (flybar)
| Thread Tools | |
| Anybody ever ask you "Why don't you build your own planes?" | juantrinidad | Electric Plane Talk | 21 | Feb 26, 2003 09:34 PM |
| FS: Build your Own Lithium Packs Cheap | jcherry | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 15, 2002 08:01 AM |
| What's A Good Program To Build Your Own Website For A Begginer? | Joe Elston | Life, The Universe, and Politics | 12 | Oct 16, 2002 04:29 AM |
| Sites on how to build your own batt ZAPPER | Kevin Graehl | Batteries and Chargers | 28 | Aug 29, 2002 01:53 AM |
| Build Your Own Defense Budget | CoastalFlyer | Life, The Universe, and Politics | 6 | Jun 02, 2002 03:12 AM |
