Old Apr 17, 2012, 02:25 PM
forsakenrider is offline
Find More Posts by forsakenrider
Canada, BC, Grand Forks
Joined Aug 2008
looks like the hackmods site is down. I really want to do this with my MLP4DSM!
forsakenrider is offline Find More Posts by forsakenrider
Old Apr 17, 2012, 03:40 PM
Joined Aug 2008
SO I've read 80% of this thread (backwards), we really need the first post edited to have all the most important stuff together! oouf, I still didnt really find out what code to use but I seem to have the schematic stuff figured out.
My plan is to use the module from a MLP4DSM with an arduino mini 8mhz with my Wfly wft09 which uses futaba type modules. Anyone able to point me in the right direction? thanks!
Old Apr 18, 2012, 03:46 PM
wolfmanO is offline
Find More Posts by wolfmanO
Joined Feb 2012
I am using the MLP4DSM Tx module powered by the onboard regulator,
the regulator doesn't even get warm to touch.
I think my sketch is the most recent to work with futaba (one page back).
wolfmanO is offline Find More Posts by wolfmanO
Old Apr 18, 2012, 03:54 PM
Iron Savior is offline
Find More Posts by Iron Savior
ROFLCOPTER
Iron Savior's Avatar
United States, KY, Louisville
Joined Mar 2011
I've got my transmitter working and right now, I'm powering the RF module with the 3.3v regulator on the Uno. The next challenge I'm facing is that I want to be able to reset the RF module without having to remove power from the arduino itself. I'm thinking that I would want to set up a digital output pin to somehow interrupt the ground connection at the module--but I'm not sure how to accomplish this. I don't want the voltage supplied to the RF module to change as a result of varying current loads and I also don't want to reduce the amount of current that it's allowed to draw. I'm thinking that this is a job for a transistor, but maybe I'm also crazy and/or stupid.
I've gone to enormous lengths today to try and learn this (bought and read some books, called some people, made a pilgrimage to an electronics supplier who somehow doesn't stock any transistors what-so-ever), but I think I'm missing something very fundamental here. How do I programatically power-reset the RF module without upsetting its regulated power?
Iron Savior is offline Find More Posts by Iron Savior
Old Apr 19, 2012, 04:31 AM
ROFLCOPTER
Joined Mar 2011
Ok now I'm thinking that in both cases (Uno vs 3.3v pro mini) I should maybe use a PNP transistor since the voltage driving the load will be either lower-than (Uno) or equal-to (pro mini) the switching voltage. Is it appropriate to drive a significantly higher current (like 200 mA supplied by a separate regulator) at the same or lesser voltage than the base via PNP transistor? Should I be looking at a FET instead? I'm so confused--at least my code is in good shape ^_^.
Old Apr 19, 2012, 06:15 AM
wolfmanO is offline
Joined Feb 2012
why would one want to reset the rf module without resetting the arduino?
Old Apr 19, 2012, 06:29 AM
ROFLCOPTER
Joined Mar 2011
The bind function is only available if you use it directly after the RF module powers on. It won't enter bind mode if you have already sent out normal control frames. I'm writing a software library that will support multiple concurrent receivers with a single RF module. Therefore, I will need the arduino's program state to remain intact while resetting the RF module in order to enter bind mode arbitrarily.
I suppose that it might also just have a switch that prevents normal operation until I'm done binding--although I've not tested binding multiple receivers without powering off the RF module. If it is the case that I cannot, then I can still have N bind switches or a multi-position switch that can be keyed during power-on to indicate which receiver to bind.
Even so, I would still like a way to reset the module programatically.
Old Apr 19, 2012, 08:45 AM
hammer22 is offline
Find More Posts by hammer22
United States, NH, Exeter
Joined Oct 2010
Iron Savior,
First, you do not want to control the RF module by switching the ground on and off. That's going to cause all kinds of problems with current flowing in and out of the TTL serial input pin on the module as long as V+ is still on. Using a transistor to control the V+ will induce a voltage drop. The RF module may still work but the CYRF6936 will output reduced RF power. You could use a separate 3.3V regulator with a remote shutdown pin to control the RF module. These are commonly available and can be controlled from an IO pin on the Arduino.. You could also use one of these, which I've used in the past. They work very well, too.
www.fairchildsemi.com/ds/FD/FDC6326L.pdf
hammer22 is offline Find More Posts by hammer22
Old Apr 19, 2012, 08:47 AM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
It's back up now. Sorry about the inconvenience.
HacksMODS DSM2
Daryoon is online now Find More Posts by Daryoon
Old Apr 19, 2012, 01:50 PM
ROFLCOPTER
Joined Mar 2011
Originally Posted by hammer22 View Post
Iron Savior,
Considering that the serial comm to the RF module can also be programatically halted, would it not make sense to simply do that prior to interrupting its ground connection with a transistor?
What about using a transistor to shut off power to a separate voltage regulator that powers only the RF module?
Old Apr 27, 2012, 12:23 AM
ROFLCOPTER
Joined Mar 2011
Alright, after a week of study and experimentation, I think I have designed a circuit that will allow me to shut off the power supply to the RF module. In the attached schematic, I'm using Pin-X (any digital output from the arduino) to signal a transistor that shorts the ADJ pin on the LM317 to ground, which reduces its output to the lowest voltage (1.2v). I've built and tested this circuit and it seems to work--that is it seems to work based on the feedback from the LED on the RF module itself. I haven't tested whether or not I can re-enter bind mode using this method yet. I will report my findings when I do.
I've never designed any circuits before and I would welcome comments.
Old May 06, 2012, 06:12 PM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
A Little/Lot of Help needed LOL
First off thanks to all that have made this thread come alive. Great work here.
I've been working this now for aquite a few days with no success. Using Cs original post: http://www.rcgroups.com/forums/showp...&postcount=237
I've had no luck at all. My changes are as follows.
5V UBEC in line after TX 9.6v power to a 3.3v reg (removed from DX4E) 5V to raw and to 3.3v reg.
No changes to code at all. Futaba 7U (shows RF signal on display) or my trusty 7C that I already use with a chainlink LRS.
I have 2 DX4E modules available and both do the same. I am able to rehook to DX4E Tx and verify working with a AR6400 brick/rx.
In bind mode I get the red 4/sec flashes and normal I get the green 1/sec flashes.
I am able to get a serial monitor screenshot but thats greek to me, no offense to any greeks LOL
Any and all hel;p greatly appreciated
mrfliboy is offline Find More Posts by mrfliboy
Old May 07, 2012, 10:50 AM
ROFLCOPTER
Joined Mar 2011
Thanks for the inspiration. I've found the hardware discussion here very relevant to my own project and I'd like to offer my contribution.
I've decided to release my code. This thread seems to be centered on the idea of using non-dsm2 transmitters to control dsm2 receivers using the arduino as a PPM decoder and translator. My code could certainly help such efforts, but I'm going in a more general-purpose direction. I don't want to be a distraction/source of confusion for people working on transmitter-translator projects, so I created a thread for a more general-purpose hardware/software discussion.
If you want to read about it, take a look over here.
Old May 07, 2012, 04:17 PM
Joined Aug 2008
Hey, I cant figure out how to get it working 100% first off I cant figure out what pins you use for LED, and second I cant get the bind function working. It ALWAYS goes into bind mode whether I press the button or not. The bind pin should be shorted to ground for bind mode at power on and then connected to VCC through a 10k resistor for regular mode?
Old May 07, 2012, 09:55 PM
Joined Aug 2008
Ignore that! it automatically goes into bind mode if no previous successful bind was made on the last attempt! duh! soo cool! I'm so happy! this is awesome!
Anybody ever ask you "Why don't you build your own planes?" juantrinidad Electric Plane Talk 21 Feb 26, 2003 09:34 PM
FS: Build your Own Lithium Packs Cheap jcherry Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2002 08:01 AM
What's A Good Program To Build Your Own Website For A Begginer? Joe Elston Life, The Universe, and Politics 12 Oct 16, 2002 04:29 AM
Sites on how to build your own batt ZAPPER Kevin Graehl Batteries and Chargers 28 Aug 29, 2002 01:53 AM
Build Your Own Defense Budget coastalflyer Life, The Universe, and Politics 6 Jun 02, 2002 03:12 AM
