Old Dec 19, 2011, 03:07 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
You guys are doing awesome work!
Let me get this straight on which modules work:
LP5DSM
DX5e
DX4e
Play station style controllers from RTF micros
Am I right on these all working with this trick?
karl k is offline Find More Posts by karl k
Old Dec 20, 2011, 01:08 AM
daniel_arg is offline
Find More Posts by daniel_arg
daniel_arg's Avatar
France, Īle-de-France, Paris
Joined Jun 2007
Originally Posted by Bseudonym View Post
Hey
Since the Arduino mini Board contains just a few parts, I left it away and took a single Atmega 328P. Finally I designed a PCB which a friend of mine made, and it now sticks all together in the size and at the back of the AMTX11 TX Module.
My only problem now is, that I can't find such a small case.
Thanks a lot to all who made this possible.
Cyrill
Wow! I'm impressed!
I want one of these boards now! How much it costs? How do you program the Atmega?
daniel_arg is offline Find More Posts by daniel_arg
Old Dec 20, 2011, 05:37 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Originally Posted by daniel_arg View Post
Wow! I'm impressed!
Hi. If I remember right you have an FG12 tx? 9
Well you may not know a Walkera module fits FG perfect!
I have a spare and willing to make PCB and fit mcu.
Just need size of rf module and pin sizes and where they are.
If your lucky my all just fit in Walkera case.
Pm details if your interested?
Phil
SadSack is offline Find More Posts by SadSack
Old Dec 20, 2011, 11:56 AM
mha1 is offline
Find More Posts by mha1
Joined Dec 2011
@all: great work presented here
@bseudonym: nice work but I think you reinvented the arduino board.
I learnt a lot following this thread. So I tried builing one too.
My changes:
1. The pullup resistor for the bind button is not necessary. The Atmel controller has built in pullups which can be activated by software:
pinMode(BINDING_PIN, INPUT); // set binding pin
digitalWrite(BINDING_PIN, HIGH); // turn on internal pullup resistor on binding switch
2. Omitted the pullup resistor on PPM input (8) as I had to shape the PPM signal for my transmitter. JR transmitters should require the same inverter. Just try and see if omitting the external pullup is required.
3. Too many LEDs. The Arduino Mini Pro has one onboard LED (green) which should be enough to signal the different operating modes. Changed the software to:
- PPM ok, i.e. normal operation: LED flashes slowly
- PPM not ok, i.e. fail safe: LED flashes with high frequency
- bind mode: LED steady
4. Changed the bind switch to a bind jumper:
- jumper on: normal operation
- jumper off: bind mode
5. Changed bind mode initiation. I can now enter bind mode at any time, not only on startup. Don't know if that is a good feature. Doesn't hurt so far.
6. Shortend the Spektrum antenna. Make sure that after cutting the antenna you strip the insulation for approx. 32mm length to get a full 2.4GHz antenna again.
The servo lead is connected to GND/RX/TX for programming. Without all the external LEDs, resistors and buttons I was also heading for a sandwich. In my case I ended up with a Spektrum burger (Inverter, Arduino, AMTX11)
It is all working and tested with one Blade MSR and one MCPx.
Thanks again
Michael
mha1 is offline Find More Posts by mha1
Old Dec 20, 2011, 11:59 AM
Bseudonym is offline
Find More Posts by Bseudonym
Joined Jul 2009
It took me hours to solder this together. Cause it was my first SMT project.
I attached the board layout from Eagle and hex file for the Atmega. Btw I only changed the pins for the 3 led's, it is programmed from c2po (Thanks).
It would be a great idea to ad programming pads. I realized this afterwards
Cyrill
Bseudonym is offline Find More Posts by Bseudonym
Old Dec 21, 2011, 09:48 AM
nenno is offline
Find More Posts by nenno
Joined Jan 2011
@mha1: Thanks!!! You really helped me out!!!!
LP5DSM
DX5e
DX4e
Hi there...
I' am using the DSM2-Modul from a MLP4DSM... It's working great and I have 6 channels. the Range is ok... ca. 50-60m I think...
So I think these Moduls are working:
MLP4DSM
LP5DSM
DX5e
DX4e
The DX4e and DX5e are Full-Range...
Is the LP5DSM Full-Range too?
Nenno...
nenno is offline Find More Posts by nenno
Old Dec 21, 2011, 01:51 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Nenno...
Not full range with the LP5DSM
Old Dec 21, 2011, 02:34 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
The "LP" in LP5dSM stands for Low Power. The "5" stands for 5channels. And the DSM is the protocol.
Daryoon is offline Find More Posts by Daryoon
Old Dec 21, 2011, 06:10 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Also both the Lp4 and Lp5 modules can actually do 6 channels.
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 21, 2011, 09:11 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Actually, it's possible that they may do more? I believe the tester only has a six channel rx to test with.
Old Dec 22, 2011, 11:38 AM
nenno is offline
Joined Jan 2011
You're right... i only have a 6-Channel rx and a Blade MCPX for testing the MLP4DSM with my Graupner MX16 HoTT...
Old Dec 27, 2011, 12:58 AM
nenno is offline
Joined Jan 2011
Hallo...
... my DIY module dosn't work together with my blade MCPX V2.
I use the TX-Modul of a MLP4DSM. The problem:
- I bind the Blade
- Blade stops to flicker blue (looks good so far)
- As soon as I release the bindbutton of my DIY module, the engine starts to run (luckily not at full throttle)
- The engine is running about 5-10sec. - Then the helicopter flashing blue
I use the module on my MX16-Hott. I adjusted the channel order in the sketch ([6,2,3,4,5,1]).
My DIY-Modul works great with a blade MCPX V1!!
For useful tips I would be grateful ...
Nenno
Old Dec 27, 2011, 03:09 PM
Uwe Steller is offline
Find More Posts by Uwe Steller
Uwe Steller's Avatar
Karlsruhe, Germany
Joined Jan 2004
A friend of mine flies mCPx V2 with a module I built according to the infos here. Are you sure, that your mCPx is ok ? Does it bind correctly with a different Spektrum Tx ?
Uwe Steller is offline Find More Posts by Uwe Steller
Old Dec 27, 2011, 05:32 PM
pmackenzie's Avatar
Joined Dec 2002
Any chance it is binding in "non computer radio" mode?
Also that channel order does not look right, should be throttle, aileron, elevator, rudder, gear, collective.
Make sure the radio is in non-CCPM mode.
Pat MacKenzie
Old Dec 27, 2011, 06:18 PM
clivew is offline
Find More Posts by clivew
Joined Aug 2010
Hmmm.
The dx5e, at least in the UK is not "full range" 12dbm only
Strange thing is, the dx4e is, 19dbm
Wierd or what?
Hi there...
MLP4DSM
LP5DSM
DX5e
DX4e
Nenno...
clivew is offline Find More Posts by clivew
Anybody ever ask you "Why don't you build your own planes?" juantrinidad Electric Plane Talk 21 Feb 26, 2003 09:34 PM
FS: Build your Own Lithium Packs Cheap jcherry Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2002 08:01 AM
What's A Good Program To Build Your Own Website For A Begginer? Joe Elston Life, The Universe, and Politics 12 Oct 16, 2002 04:29 AM
Sites on how to build your own batt ZAPPER Kevin Graehl Batteries and Chargers 28 Aug 29, 2002 01:53 AM
Build Your Own Defense Budget coastalflyer Life, The Universe, and Politics 6 Jun 02, 2002 03:12 AM
