Old Nov 02, 2011, 09:44 PM
TjW is offline
TjW
Find More Posts by TjW
TjW
USA, CA, Riverside
Joined Mar 2006
Originally Posted by Daryoon View Post
Hehe...thanks for the clarification. I did understand they are two different firmware. (You may have missed my third sentence that attempted to switch subject to the th9x)
I will have to test it out myself and report back once my programmer arrives.
Thanks for the replies though.
-Daryoon
Okay, looking at their code, the comments point back to this thread post 237.
TjW is offline Find More Posts by TjW
Old Nov 03, 2011, 04:42 PM
Daryoon is online now
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Looks like erezraviv saw the enhancement request and made the changes.
R590 changelog: http://code.google.com/p/er9x/source...c=svn590&r=590
Just gotta check if it works. Don't have my programmer yet...but I'll do the mod as soon as it arrives.
Daryoon is online now Find More Posts by Daryoon
Old Nov 05, 2011, 12:11 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Success in getting it to bind and was able to control my mSR. So easy! But just awaiting verifications on whethered I properly wired things up. But at least it's working. yay!
See more here: http://www.rcgroups.com/forums/showp...ostcount=12616
Old Nov 05, 2011, 01:51 PM
franckh is offline
Find More Posts by franckh
Hondschoote (France)
Joined Jan 2003
I have made one like a first post with a 2313, it run fine in my old FF8
http://img510.imageshack.us/img510/2332/ff8spektrum.jpg
http://img443.imageshack.us/img443/461/ff8spektrum2.jpg
i have a problem with one bad 2313, but now with another one it's good!
thank for all
franckh is offline Find More Posts by franckh
Old Nov 08, 2011, 01:26 PM
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Update...
I made a post with image on the location of the 3.3v connection point on the Turnigy 9x' mainboard. So you can now tap into that to power the DSM2 module.
http://www.hacksmods.com/2011/11/tur...3-3v-location/
Old Nov 14, 2011, 02:01 PM
carlosadc is offline
Find More Posts by carlosadc
Joined Apr 2011
Trying to put a AMTX11 from my DX5e on th9x
Originally Posted by rbellanc View Post
Hi,
i have changed the schematic for use with AMTX11 RF module and use it with T10 Futaba transmiter (with training square connector).
The AMTX11 is the RF module of the DX4e Spektrum transmitter (included in RTF kit of MCPx helicopter for example). This module is full Range.
You can find the special Futaba square connector from simulator dongle (7$)
http://www.dealextreme.com/p/usb-fms...trollers-11996
becarefull, it's hard to soldering the wires on this, before, you can add Epoxy glue behind the connector.
I use LE33CZ (warning => 1 -> Vout, 2 -> GND, 3 -> Vin) regulator and I glued a heatsink on it, and Vin Max for T10 transmitter is 8,4v.
You can find below the new schematic (based on the schematif of c2po) and some photos of the assembly
Hi, I want to try using my AMTX11 from my DX5e on my Turnigy 9x but I have a very newbie question Based on your schematic for the AMTX11 that would mean that if I want to use the AMTX11 with the th9x that supports dsm2 the pin you labeled TX could go straight from the AMTX11 to the Turnigy 9x TX pinout? and of course connecting the Vin and Vout accordingly? Thank you in advance!
carlosadc is offline Find More Posts by carlosadc
Old Nov 14, 2011, 02:05 PM
bigtruck169 is offline
Find More Posts by bigtruck169
United States, NY, New York
Joined Dec 2009
finally someone open up the dsm secret. Even this is more than 1 semester course to most of us. keep the discussion going. i want to learn, too.
bigtruck169 is offline Find More Posts by bigtruck169
Old Nov 17, 2011, 05:41 PM
mr..speed is offline
Find More Posts by mr..speed
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
Hello, just found this thread.
Are there any instructions to run with the XBEE ?
Thanks Volker
mr..speed is offline Find More Posts by mr..speed
Old Nov 18, 2011, 12:57 AM
franckh is offline
Joined Jan 2003
@volker: you can find some information for use X-bee in tx-rx here http://www.o24rcp.org/ but it's not Dsm2, i use o24rcp on my quadricopter.
a+franck
Old Nov 18, 2011, 03:27 AM
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
a+franck
Thanks, unfortunately not in English, will try a translator later
Old Nov 21, 2011, 11:35 AM
franckh is offline
Joined Jan 2003
thank for all
Hello,
now i have a probleme, i can't bind my new mcpx; is somebody try this with first hack ?
with my msr all is good.
may be not same binding protocol?
thank for feedback
edit: maybe time of bind to short?
Old Dec 05, 2011, 07:58 PM
Dev5994 is offline
Find More Posts by Dev5994
Joined Dec 2011
What's the minimum required amount of data that has to be sent to the module and at what interval for the module to connect correctly to my micro heli. The module is already bound to the heli and i'm currently sending this via arduino
{0x00,0xAA,0x05,0xFF,0x09,0xFF,0x0D,0xFF,0x13,0x54 ,0x14,0xAA}
every 22 microseconds with no success. I'm trying to build a diy remote to control my various micro helis. Can anyone give me suggestions?
Dev5994 is offline Find More Posts by Dev5994
Old Dec 05, 2011, 09:42 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
That does not look quite right. I think you are missing a "0x00 0x00" at the beginning.
http://www.rcgroups.com/forums/showp...33&postcount=8
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 06, 2011, 11:42 AM
Dev5994 is offline
Joined Dec 2011
My mistake. I'm send the 0x00, 0x00 header as well but it's still not connecting to the heli
Old Dec 06, 2011, 12:02 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
have read this? http://www.rcgroups.com/forums/showp...&postcount=225
read from..."For the binding procedure, the packet is the same, but the header is 0x80,0x00 instead of 0x00,0x00. That's why I said that I'm afraid that the default package is maybe associated to the radio."
SadSack is offline Find More Posts by SadSack
Anybody ever ask you "Why don't you build your own planes?" juantrinidad Electric Plane Talk 21 Feb 26, 2003 09:34 PM
FS: Build your Own Lithium Packs Cheap jcherry Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2002 08:01 AM
What's A Good Program To Build Your Own Website For A Begginer? Joe Elston Life, The Universe, and Politics 12 Oct 16, 2002 04:29 AM
Sites on how to build your own batt ZAPPER Kevin Graehl Batteries and Chargers 28 Aug 29, 2002 01:53 AM
Build Your Own Defense Budget coastalflyer Life, The Universe, and Politics 6 Jun 02, 2002 03:12 AM
