Old Jan 25, 2009, 01:05 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Its the same protocol. The 4th wire is just for the red LED on the front of the LP5DSM near the dip switches.
TheSteve is offline Find More Posts by TheSteve
Old Jan 25, 2009, 04:52 AM
iter is offline
Find More Posts by iter
High-power Rocket Gliders
iter's Avatar
Silicon Valley, Calif
Joined Jan 2005
Thank you Steve! I see now that it's the same exact PCB in your photos and mine.
Now all I need is a 125kbaud USB port, and I can start hacking away.
Ari.
iter is offline Find More Posts by iter
Old Feb 11, 2009, 02:38 AM
iter is offline
iter's Avatar
Joined Jan 2005
I bought an FTDI USB<->serial adapter that can do 125k baud and I can read serial data as Steve describes from my Vapor RTF TX. This TX activates binding mode if you turn it on while pressing in the left stick. I find that in this case the first few hundred packets go out with a different header.
Normally, first two bytes in a packet are 00 00. With the stick pushed in, they are 80 00.
Ari.
Old Feb 11, 2009, 04:19 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
The transmitter is in bind mode every time its turned on. Pushing the stick in may change some data but should have nothing to do with binding as that is handled entirely by the 2.4ghz module.
Old Feb 11, 2009, 05:01 PM
iter is offline
iter's Avatar
Joined Jan 2005
There are two versions out--one that binds every time you turn it on, the other doesn't; the one I tested is the second kind:
Originally Posted by http://www.horizonhobby.com/Products/Support.aspx?ProdID=PKZ3300
Vapor RTF sets using AutoBind (LED on aircraft receiver/ESC unit and transmitter will blink immediately upon powering on):
1. Ensure flight battery is fully charged and transmitter AA batteries have adequate power.
2. Plug the flight battery into the receiver/ESC unit and the LED will begin blinking.
3. Within 5 seconds of powering on the Vapor receiver/ESC, power on the Vapor RTF transmitter (LED on the transmitter will begin blinking) and the bind process will complete within 15 seconds.
Vapor RTF sets without AutoBind (LED on receiver/ESC unit will begin blinking after 5 seconds of being powered on. LED on transmitter remains solid when powered on):
2. Plug the flight battery into the receiver/ESC unit. The LED on the receiver/ESC unit will begin blinking after 5 seconds.
3. Once the LED on the receiver/ESC unit is blinking, push IN on the left control stick while powering on the transmitter. Release the left stick once the transmitter is powered on. The transmitter will beep, signifying the transmitter is in bind mode. The bind process will complete within 15 seconds.
Old Feb 11, 2009, 05:08 PM
iter is offline
iter's Avatar
Joined Jan 2005
The TX I have transmits 6 controllable channels. It has pushbuttons under its sticks. If you press the right stick, the TX toggles channel 5 from a medium-low to a medium-high state. If you press on the left stick, it brings channel 6 high and keep it high as long as you keep pushing on the button. I don't have the actual m=numbers it sends out here. I plan to post them when I get home tonight.
Interestingly enough, when you power on the TX with the left stick depressed and it comes up in binding mode, it sends a low value for channel 6, as if you hadn't pressed the stick.
Ari.
Old Feb 11, 2009, 10:40 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Ahh, thanks for the update. While the left stick binding is a nice feature the autobind sure made it easy to use the tx module with other stuff.
Old Feb 12, 2009, 01:24 AM
iter is offline
iter's Avatar
Joined Jan 2005
I expect that left-stick binding works with other DSM2 receivers as well although I have not tried it. I also expect that if I send a 80 00 header to my RF board at startup (or ever?) it will go into binding mode. I won't have time to test this hunch until the weekend.
Steve, I have a question for you. Both my RS232 USB dongle and my uC run at 5v. The RF device uses 3.3v. I imagine that if I feed 5v to the RF control line I may fry the RF device. How can I prevent that? Is there a resistor I can put between them to limit the voltage?
Ari.
Old Feb 12, 2009, 02:49 AM
iter is offline
iter's Avatar
Joined Jan 2005
Here are the numbers I measure from my RTF TX:
Code:
# function   low   centr high
0 throttle   00AA     *  034F
1 aileron    04AA  05F7  0740
2 elevator   08AA  0A4F  0B54
3 rudder     0CAA  0DFF  0F54
4 r pushbtn  10AA    **  1354
5 l pushbtn  14AA   ***  1754
Notes:
* non-centering throttle stick
** toggles h-l or l-h on every press
*** low normally; high when depressed
This TX seems to limit values it sends out to (decimal) 170..852, with 511 as neutral. Pushbuttons give the same range as full stick swings.
I measure about 45 (14-byte) packets a second.
Ari.
Old Jun 25, 2009, 03:00 PM
iter is offline
iter's Avatar
Joined Jan 2005
Steve, thank you for sharing your reverse-engineering. I successfully fly a number of Vapor brick models using a TX I build following your findings.
http://www.rcgroups.com/forums/showthread.php?t=1069598
http://www.rcgroups.com/forums/showthread.php?t=1069110
Ari.
Old Jun 29, 2009, 06:24 PM
iter is offline
iter's Avatar
Joined Jan 2005
I notice that the RX responds only if I send exactly 6 channels. If I send any other number, it behaves as if it can't hear a TX at all.
Many other DSM2 transmitters have more than 6 channels, like DX7, X9303, etc. I wonder how they can work with this receiver.
Ari.
Old Jul 09, 2009, 11:45 AM
EnjoyPA is offline
Find More Posts by EnjoyPA
can't afford to pay attention.
EnjoyPA's Avatar
Pottstown, PA
Joined May 2009
Ari.
Well, they have to talk both ways to bind, maybe the Rx tells the Tx how many channels it wants and the Tx just sends that many.
EnjoyPA is offline Find More Posts by EnjoyPA
Old Sep 05, 2009, 07:39 PM
Twisted Realm is online now
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Guys can any of the movements on the DSM2 transmitters be reversed? I'm tring to reverse the ailerons but I don't know how if its possible?
Twisted Realm is online now Find More Posts by Twisted Realm
Site Sponsor
Old Sep 05, 2009, 11:38 PM
EnjoyPA is offline
EnjoyPA's Avatar
Pottstown, PA
Joined May 2009
It's easy if you have one of the computer TX's like a DX6i or DX7. With an LP5DSM, it might be a little more tricky - there's a set of DIP switches under the front panel with the LED.
Which TX are you using?
Old Sep 05, 2009, 11:41 PM
EnjoyPA is offline
EnjoyPA's Avatar
Pottstown, PA
Joined May 2009
If it IS an LP5DSM, then you'll find a listing of what the switches are SUPPOSED to be in this thread: http://www.rcgroups.com/forums/showthread.php?t=611167
Anybody ever ask you "Why don't you build your own planes?" juantrinidad Electric Plane Talk 21 Feb 26, 2003 09:34 PM
FS: Build your Own Lithium Packs Cheap jcherry Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2002 08:01 AM
What's A Good Program To Build Your Own Website For A Begginer? Joe Elston Life, The Universe, and Politics 12 Oct 16, 2002 04:29 AM
Sites on how to build your own batt ZAPPER Kevin Graehl Batteries and Chargers 28 Aug 29, 2002 01:53 AM
Build Your Own Defense Budget coastalflyer Life, The Universe, and Politics 6 Jun 02, 2002 03:12 AM
