Hoofddorp, Netherlands
Joined Sep 2004
Here's more info on the Spektrum system:
* http://www.anderswallin.net/2005/05/...he-dsm-system/ * http://spektrumrc.net/default.aspx * http://spektrumdx6.com/default.aspx * http://www.rcgroups.com/forums/showthread.php?t=540007 * http://www.cypress.com/portal/server...rpn=CYWUSB6953 The link between Rx and Tx is all done by some commercially available transceiver chips on the 2.4GHz. Unless I-m mistaken the link between Rx chips and microprocessor is and I2C link, otherwise a simple direct one wire serial link. The processor must contain firmware to compare the two sets of data received and determine which is best. There is NO PPM output out of the receiver at any point as far as I have been able to determine. I-m actually trying to regenerate a PPM signal by recombining the separate channel PWM outputs (http://www.rc-cam.com/forum/index.ph...ic=2064&st=20). And special thanks here to Mr. RC-Cam for providing a circuit which hopefully will solve my problem. Instead of fully copying the Spektrum DX system you could also go complete homebrew, e.g. http://webx.dk/rc/uhf-link2/uhf-link2.htm |
There are many options out there, I haven't tried them myself though. If you're into micro flight then perhaps using the DSM2 module out of LP5DSM with your favorite transmitter and the new AR6300(I think thats the model) micro receiver would be a nice option. I pondered using the DSM2 module with a 3 channel car radio so that I could use the insanely small/light Spektrum receiver but my two 1/36th scale micro RC trucks already have xbee based receivers in them.(receivers are down to 7 grams or so and could be a little lighter still) I am running my xbee based system every weekend along side other 2.4Ghz radios with flawless performance. Anyway it will probably take a week or two but the PPM to serial converter to use my Futaba 9CAP with the DSM2 module is going to be written. Now I need another empty Futaba transmitter module case... |
, I wasn't thinking about prototype materials at that time
Maryland, USA
Joined May 2004
http://www.rcgroups.com/forums/showthread.php?t=708854 Anyways, I have a unused LP5DSM sitting here, so it will be interesting what you come up with. -Kwok |
USA, CA, San Diego
Joined Jun 2007
There are apparently some pads inside that might switch to idle-up, but I'll let that wait. Thanks! |
| Thread Tools | |
| Anybody ever ask you "Why don't you build your own planes?" | juantrinidad | Electric Plane Talk | 21 | Feb 26, 2003 09:34 PM |
| FS: Build your Own Lithium Packs Cheap | jcherry | Aircraft - Electric - Airplanes (FS/W) | 0 | Dec 15, 2002 08:01 AM |
| What's A Good Program To Build Your Own Website For A Begginer? | Joe Elston | Life, The Universe, and Politics | 12 | Oct 16, 2002 04:29 AM |
| Sites on how to build your own batt ZAPPER | Kevin Graehl | Batteries and Chargers | 28 | Aug 29, 2002 01:53 AM |
| Build Your Own Defense Budget | CoastalFlyer | Life, The Universe, and Politics | 6 | Jun 02, 2002 03:12 AM |
