Old Jul 30, 2007, 03:23 PM
Valid8r is offline
Find More Posts by Valid8r
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Basics of BEC's External vs. ESC based? Education needed please!
So I'm trying to understand the basics of external (switching and without an external battery) BEC's and how they work with respect to the resistance based ESC in a speed controller.
One of my questions is simply related to the general laws of physics which would be conservation of energy. If a switching BEC is not generating as much heat (as the one built into my CC ESC for example), it should be using less energy and therefore my battery should therefore have more energy to fly my plane - right? If so, why doesn't everyone use one?
Jon
Valid8r is offline Find More Posts by Valid8r
Old Jul 30, 2007, 05:16 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Standard BECs are not "resistance based" and not all ESCs use linear regulator BECs. Some ESC have switching BECs anyway.
A switching BEC does save some power and you do have more to fly the plane...but the total power wasted in a standard BEC is only a tiny fraction of the amount used by the motor so you'll never notice the difference. Say a typical flight motor is using 100-250W. A typical linear BEC wastes on average about 2-3W so even if you could save all of with a switching BEC you'd only have around 1% extra for the motor. That might explain why not everyone thinks it's worth paying extra for .
Steve
slipstick is online now Find More Posts by slipstick
Old Jul 30, 2007, 07:55 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
Switching BECs aren't about longer runtime, they're about less heat generated. The 1-2% difference in runtime is trivial, but if you overheat the BEC, the 100% difference in flight time is rather important.
The circuitry to make a switching BEC is approximately 8x more expensive than to make a linear BEC. This, and the complexity inherent in doing one well (ultra low EMI, good transient response, wide input range), is why they're not built into all ESCs.
If you're getting one to get more flight time, spend the same 6 or 12 grams on a slightly bigger battery. If you're using a 6V one to get faster servo response, then that's valuable in some applications. If you're running anywhere near overheating the linear BEC, then they'll save your plane.
A foamy running three HS-55s from a 2s pack doesn't need a switching BEC. A 4s T-trex does.
Comatose is offline Find More Posts by Comatose
Old Jul 31, 2007, 12:16 AM
Valid8r is offline
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Ok, thanks guys that's helpful information. If I may, another question.
I have read here (in other forums) that switching BEC's are "prone" to producing radio interference. Comatose, you reference EMI above, so is this a real problem for switching BEC's or is that a function of the design and if so, which switching BEC's are known to be 'good' from that perspective.
Also, can anyone tell me what type switching or other does CC use?
My questions are out of curiosity mainly. I have always used CC ESC's but recently someone suggested I may want to go to an independent BEC which I don't really understand, hence the questions. I wasn't necessarily trying to save power, just trying to understand the why's and why not's of using dedicated BEC's vs ESC BEC's and also relating all of this to the RX low voltage issues talked about with the Spectrum RX's.
Thanks again,
Jon
Old Jul 31, 2007, 07:55 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
All the Castles I have seen have LDO regulators in them. Some have split supplies.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jul 31, 2007, 05:49 PM
Comatose is offline
Akron, Ohio
Joined Jan 2002
Its a gigantic problem for switching BEC design - our requirements in terms of EMI are much much more stringent than most applications. Its overcomable by very careful design, but its extremely nontrivial to do. For example, ParkBEC has literally 500 hours of engineering time in it just tweaking the EMI ever lower. We've got half a dozen aborted designs that just couldn't be massaged low enough to be releasable. FWIW, the abandoned designs radiated less than some on the market, but I'm not naming names.
All switching BECs will generate some amount of EMI, just like all speed controls will. A really good one will be below the noise floor of the ambient environment and not reduce range. A really bad one can cut your range in half, or worse.
I'll let others chime in with which BECs they're had good success with, because I make a living making them so I'm ever so slightly biased.
Old Jul 31, 2007, 05:52 PM
Afroman is offline
Find More Posts by Afroman
Cat lover
Joined Mar 2005
Hi Jon,
The amount of radio interference a switching BEC will produce is pretty much a function of how good a design it is. Any teenage undergraduate can throw together a switching BEC design in an afternoon that will power servos. To get a design that won't radiate takes months...
I can show you some $9.99 'UBEC' clones that put HORRIFIC amounts of radiation out, and will knock your range down to 10% of what it normally is. On the other hand, Kool Flight System's UBEC is a great product and it puts out almost zero interference.
All of Dimension Engineering's switching BECs put out almost zero interference and will not affect your range. Zero range reduction is the #1 design criteria in all DE BECs. (Keep in mind that I designed some of these, so I will inherently be biased.)
External switching BECs also generally have more output capacitance on them, which usually means they have better load transient response, which means they will be better at dealing with sudden servo load changes.
CC uses linear BECs on all of their speed controls at this time, which puts out zero interference. They will be coming out with an external switching BEC very soon I hear.
If you are running a Spektrum 2.4ghz radio system then the radio interference isn't a big deal. Just make sure that you have the latest firmware on your receiver and that is supposed to help the low voltage issue a lot.
Afroman is offline Find More Posts by Afroman
Old Aug 01, 2007, 02:42 AM
hul is offline
hul
Find More Posts by hul
hul
hul's Avatar
Switzerland
Joined Mar 2003
I have used these:
SBEC (not available any more ?)
UBEC http://www.koolflightsystems.com/ultimatebec.htm
SportBec http://www.dimensionengineering.com/SportBEC.htm
Jazz 80-6-18 with switching BEC http://www.kontronik.com/index2e.htm
of these the SportBec and Kontronik are best, SBEC worst for EMI.
I'll get another SportBec when I need another BEC. Small, light, works well and cheap shipping even to Europe.
Hans
hul is offline Find More Posts by hul
Old Aug 08, 2007, 10:21 AM
MedicWill is offline
Find More Posts by MedicWill
Joined Jan 2007
How about the XBEC by common sense RC?
http://www.commonsenserc.com/product...roducts_id=323
Seems to have all the features, and only 19.99.
But I am getting some glitching, even with my DX6. Not exactly sure its the BEC as I having ruled anything out yet.
Anyone else have any experience with this BEC?
Could I be getting interfierence if the ESC im using has a BEC built in?
The reason I used it was cause my ESC couldnt handle the 5 servos I threw at it.
I also like being able to power up my reciever without the motor. This BEC runs off the balancing tap of my batts.
MedicWill is offline Find More Posts by MedicWill
Old Feb 10, 2009, 02:44 PM
Joe_Curd is offline
Find More Posts by Joe_Curd
CSRC Service and Support
Joe_Curd's Avatar
Erlanger, KY
Joined Nov 2006
I've got a little bit of experience with it
You may experience some frequency interference if the XBEC is too close to the RX. Also, make sure that your Spektrum RX antenna are at 890 degree angles (perpendicular to each other).
You want it as far away from the RX as possible. I also try to isolate mine from the ESC just to make sure any possible feedback from the XBEC doesn't affect the timing.
Joe Curd
www.CommonSenseRC.com
http://www.youtube.com/user/CommonSenseRC
Joe_Curd is offline Find More Posts by Joe_Curd
Help! Use both Bec's with 2 esc's and 2 fans? czechyour6 Electric Ducted Fan Jet Talk 14 Mar 15, 2007 09:09 PM
Twin Engines/ESC - ? 2 BEC's needed? JamesC Electric Plane Talk 4 Jul 15, 2004 04:56 PM
Servo's vs. ESC vs. Cells ? bnl2001 Parkflyers 2 Aug 27, 2003 11:05 PM
CGR18650H 's needed, please help! eparkflyer Batteries and Chargers 2 Oct 16, 2002 05:27 AM
F/S Master Hacker ESC 70-3P Bec NIB RCFLYER0001 Aircraft - Electric - Airplanes (FS/W) 2 Apr 15, 2002 11:46 PM
