Yes, you can use your receiver.
The stock graupner speed 400 motor is made for 7 volts. 12 volts may be too much. My advice, build the plane, install your electronics. Balance at the CG using a wad of clay in place of the battery. Weigh the clay. Get a 2S battery that weighs close. I needed 104 grams to balance my ES (brushless motor). This battery weighs 102 grams. http://www.aircraft-world.com/shopexd.asp?id=3791 Here is a data sheet http://www.aircraft-world.com/prod_d...cl-lithium.htm Regards Rick |
Saint Clair Shores , MI
Joined Sep 2006
I fly my ES with the stock motor and 9.6v 8cell radio shack 1600mah Nimh's.
My CoG is actually right on , and it flies very well. Granted I only get about 9 minutes of full throttle , but I can keep it up there much longer by gliding it , which is what it was designed for. I use a Castle Creations 20a esc and a Spektrum BR-6000 reciever. It flies so well for me that I have no intention of going brushless with it , I'll save that for my Space Scooter. Hope the info helps , happy flying! |
Ta2d is right that 8 cell (9.6v) NiMhs seem to be the best choice for the stock motor, providing decent performance and reasonable life. And the motors are CHEAP and easy to replace. Eric |
| Thread Tools | |
| Help! Newbie with an Easy Star question... -- Answered | Omelets | Electric Plane Talk | 7 | Jan 14, 2007 10:17 AM |
| Can I use these electronics on a Multiplex Easy star ARF? | Kg4ceo | The Builders Workshop | 1 | Aug 24, 2005 11:59 AM |
| where can I get new wing for an Easy Star? | STaNgXs | Foamies (Kits) | 3 | Sep 29, 2004 01:21 AM |
| Can I use these caps on a motor? | tinsink | Power Systems | 6 | Mar 19, 2002 09:05 AM |
| Can I use 5 cells in an Rx pack? | Ben74 | Power Systems | 19 | Sep 21, 2001 03:57 PM |
