Old Jul 30, 2007, 08:58 AM
Windsor, Canada, near Detroit
Joined Jul 2007
folding props for a 3mm shaft, and 6 to 10 in.
Thanks for the info. Do you know a source for 25 to 35mm spinners for folding props for a 3mm shaft, and 6 to 10 in. folding props for a 3mm shaft motor to match?
Regards,
Phil
phil alvirez is offline Find More Posts by phil alvirez
Old Jul 30, 2007, 09:39 AM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hi Phil,
You need to indicate your country in your profile so we can give a meaningful response.
Here in the States, Hobby Lobby is good, also North East Sailplane (NSP)
Good luck,
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jul 30, 2007, 01:04 PM
jooNorway's Avatar
Norway
Joined Jul 2005
Yes, to know where people live might help...
An example: http://www.aircraft-world.com/shopdi...ers+%2D+MP+JET
jooNorway is offline Find More Posts by jooNorway
Old Jul 30, 2007, 04:36 PM
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
http://www.bphobbies.com/view.asp?id=V489603 another source
Dylan
Dylwad is offline Find More Posts by Dylwad
Old Jul 30, 2007, 10:46 PM
3rd Rock from the Sun
Joined Apr 2007
The Best Deal Is Unitedhobbies .com You Cann't Beat Thier Deals And If You Can Post I'll Shop There THEY HAVE TWO DIFFERNT ONES FROM $6.99 AMERICAN
milton j fozzmor is offline Find More Posts by milton j fozzmor
Old Jul 31, 2007, 07:40 AM
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
Better only buy the metal hub type and a 3mm reamer as well
olmod is offline Find More Posts by olmod
Latest blog entry: For motor builders
Old Jul 31, 2007, 06:51 PM
Ontario
Joined Aug 2005
In Canada you can try http://www.icare-rc.com/
El Flaco
El flaco is offline Find More Posts by El flaco
Old Jul 31, 2007, 07:07 PM
pilotpete2's Avatar
Joined Jun 2004
I would strongly urge anyone not to consider for a moment buying cheap Chinese folding props, they have been known to shed blades very easily, not worth the risk. You'll shoot yer eye out, kid
Pete
Old Jul 31, 2007, 10:21 PM
Joined Jan 2005
I use these
Air Craft World and Esprit Models...
Good Luck
Rick
Air Head is offline Find More Posts by Air Head
Old Aug 01, 2007, 11:45 AM
Cmiller's Avatar
Las Vegas
Joined May 2002
Good Luck
Rick
Air-Craft-World.com
Cmiller is offline Find More Posts by Cmiller
Old Aug 01, 2007, 07:24 PM
olmod's Avatar
Joined Apr 2004
Pete
I have to agree in part,the plastic hub types are downright dangerous at rpms above 8k as my metal workshop wall will prove .
but in all fairness the newer metal hub type made by Hy and also stocked by United Hobbies are a different animal and have a 2.8mm collet wich i use a 3mm reamer on. cheers. ps they set up good for pushers also by reversing the blades.
Discussion Folding Props for 3mm shaft Outrunners? Rick Hodges Power Systems 9 Feb 07, 2007 11:18 AM
Folding prop for 3mm shaft? Joe_Atlanta Power Systems 6 Jul 03, 2005 07:32 AM
Question Folding prop for 3mm shaft? BrianRickman Power Systems 4 Apr 02, 2005 09:59 AM
Props for 3mm shaft Python 60 Motor William Bosco Power Systems 0 Jul 25, 2004 03:31 PM
Folding props for 4mm shaft? mikeb33 Electric Plane Talk 4 Nov 21, 2001 08:43 AM
