Old Nov 14, 2002, 09:54 AM
Lapsed Non Modeller
Andycart's Avatar
West Yorkshire, UK
Joined Sep 2002
Right & Down Thrust on Pusher Wing ?
Hi Guys
Can anyoe help me out? I understand that in some models it's desirable to have right thrust and downthrust on the motor to counteract torque & stuff. That's on a conventional 'puller' prop set up.
I have just built a foam wing with a speed 300 DD pusher with a Gunther prop. It flies great, except ...
When I come out of a turn it pitches up, and I mean right up. Once I correctthe pitch up it seems to fly straight and level O.K. It looks like it's speed related somehow.
I also have full right aileron trim dialled in so I thought torque was a problem too.
On a 'pusher' set up do I still need down and right thrust on the motor? Or should I say would down and/or right thrust solve the problems I have.
Andy
Andycart is offline Find More Posts by Andycart
Old Nov 14, 2002, 01:36 PM
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Andy,
I would think that you need "up-thrust" on your motor (shaft pointing downward). That could be the reason your plane is pitching up. Try about 5 degrees down to start.
VP
Viper Pilot is offline Find More Posts by Viper Pilot
Old Nov 15, 2002, 06:44 AM
Lapsed Non Modeller
Andycart's Avatar
West Yorkshire, UK
Joined Sep 2002
Thanks VP
That is what I meant I thoght if the prop was pointing down that was downthrust, my mistake. What about left and right thrust to counter the prop torque?
Andy
Old Nov 15, 2002, 07:44 AM
God is good
Banjul
Joined Jan 2001
I'd try manually adjusting the elevons first to see if that helps. I've never heard of using right/left thrust on a pusher, but someone else could amybe help on this.
VP
Old Nov 15, 2002, 09:43 AM
God is good
Banjul
Joined Jan 2001
Originally posted by Andycart
. . . . I thought if the prop was pointing down that was downthrust, . . . .
If the prop is up front, it is.
VP
Old Nov 25, 2002, 09:17 PM
Guest
California
Joined Jan 2002
i fly the deltawing pusher mirage 2000 and the manual stated that i need 2mm up elevator and 2 degree of that "up thrust" on the motor. but i do not know the conventional wisdom on this matter.
Tim2000 is offline Find More Posts by Tim2000
Motor down thrust on a pusher set-up? CactusJackSlade Modeling Science 5 Jun 16, 2005 05:25 AM
motor down-thrust on a pusher set-up? CactusJackSlade Electric Plane Talk 5 Jun 13, 2005 10:51 AM
Angelis 400 - how to mount AXI with right & down thrust? Basketcase Sport Planes 3 Jun 24, 2004 04:27 PM
Motor down thrust on flying wing? TNTRC Foamies (Kits) 1 Nov 21, 2003 10:00 PM
How much right & down thrust? tempest411 Electric Plane Talk 8 Sep 27, 2002 04:12 PM
