Old Dec 04, 2002, 04:07 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
The battery pack used for the prototype was a GWS 6 Cell 7.2 V / 600 mAh NiCad Pack. I placed the access hatch on the bottom for the prototype which gave access to the fan units, although the only time I have ever burned one of these fans out is when I tried to put a 9.6V pack to it. Yes for the prototype the 3-blade fans were used alothough the 6-blade fans could be used very easily.
John
http://www.aerc.biz
http://www.rc-plans.com
drbird is offline Find More Posts by drbird
Old Dec 04, 2002, 04:38 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
Ah, a 6 cell pack does make more sense. I've burned out many a GWS motor on 7 cell packs. 8 cells seemed very high. Thanks for the info about the access hatch.
Looking forward to the Eurofighter reports!
Darren Hintze is offline Find More Posts by Darren Hintze
Old Dec 04, 2002, 06:01 PM
Midnit is offline
Find More Posts by Midnit
Charlotte, NC
Joined Dec 2002
GWS-50
I would imagine there isn't an easy way to change the motor if it burns out. I would have to destroy my duct in order to get to the motor and I would love to see someone re-duct this sucker once its covered!
Now you have me worried though. I have a 7cell pack on the way, and I am using a 6cell for break in and tests. Will the 7cell burn out the motors? I'm not much into electronics but I assumed since it was 2 motors on one pack it would be safe to go over the recommended max voltage. Is this an unsafe assumption?
Midnit is offline Find More Posts by Midnit
Old Dec 04, 2002, 06:18 PM
Tight is Right
Joined Dec 2001
Well let me unworry you just a little.
I've burned out lots of GWS motors in geared applications. I haven't yet run an EDF motor in the fan units. You have a testimonial from an EDF user saying he's not burned one out yet.
That said, I don't know any small brushed that gets 100+ flights reliably -- particularly in an application where cleaning/lubrication is not easy either. Given that the F-4 has two motors cranking away, I know I'd be thinking about how to get them out.
For some fliers, 100 flights is several years. I fly several times a week so 100 flights for me is about two months. I guess it's a matter of perspective as well.
Old Dec 04, 2002, 06:36 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
The ducting should be a snap to get out and then simply replace. One thing you can do if the fan ever burns out is to simply shorten the duct and then add an intermediary ducting peice that seperate the fan unit from the main ducting - this way you just replace the intermediary ducting and the fan unit without ever having to worry about the main ducting. Again I haven't had any problems with the fan units to date other than by my my own vices (ie. overpowering them).
John
http://www.aerc.biz
Old Dec 04, 2002, 07:59 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Fans
The unfortunate scenario is that these lil gws fan do not have mounting `fins', as in no screws to remove the fan anyway! It obviously wasnt designed to replace the motor in a `long duct' EDF. If you can't get at the front mount screws, pull the press on fan, or pull the leads from the rear, you are just kind of SOL.
I myself am working on resolutions to this problem
If I had designed this unit, it would have a short lead plug, flush rear ring, and mtg tabs, ALSO the fan and motor, should not stick out of the assembly!
This plane is not the only one with the same problem. Unless you fly her full throttle continuously, or by overpowering her, you should not need to replace the motor
Its like a cassette player motor, do you ever have to replace it???? And if you did, see how much fun it is
FANMAN is offline Find More Posts by FANMAN
Old Dec 05, 2002, 10:15 AM
Tight is Right
Joined Dec 2001
I hate to disagree but audio equipment motor life is not analagous to DF motor life.
Electric DC motors in DVD's, PC fans, VCR's, Disk Drives, etc are a) usually brushless and b) designed for long life. The motors in the EDF-50 are a)brushed and b) designed for high power-to-weight output.
Motor brushes have a very finite life. Spinning at tens of thousands of RPM's under load is going to wear them down -- thats the equivallent to about 5 years of audio motor wear in every 5 minute flight. The guys I know with experience with these motors are happy to get 50 flights at the upper recommended voltages. At $15 or so, it's not expensive to replace these fans... but it needs to be possible to replace them.
But like I said, it's also a matter of perspective. If 50 flights lasts you 2 years, great. I wouldn't care either. I know I'll be building my AERC Eurofighter or F-22 with motor changing in mind because I plan to fly my plane 50 times a month.
Can't wait for a flight report!
Melf
Old Dec 05, 2002, 05:52 PM
FANMAN is offline
Always looking UP
FANMAN's Avatar
Joined Nov 2000
You are correct
One possibility is to sheet the bottom, and if you need to change out motors, worst case would be cutting out the sheet, pulling out the fans, then recovering that area when finished
Old Dec 06, 2002, 01:21 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
I think when I build my AERC F-4, and the F-22, I'm going to work a hatch into the bottom of it. Think that would work. I don't know how the battery mounts in the F-4 (I haven't ordered one yet) but I might try to work this hatch to double as battery access.
--Paul
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Dec 06, 2002, 02:02 AM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Thats exactly how the protoype was build Paul - one large hatch on the bottom to access eveything all at once.
John
http://www.aerc.biz
Old Dec 08, 2002, 09:06 AM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
Video
Drbird (John),
I thought some time ago you said you had Video of this bird in flight. Have you posted that somewhere so we can see it? You site has had "video coming soon" forever and a day. I am not building as quick as I would like and wouldn't mind some video of the F-4 to motivate me to complete it this week. How about it?
Foamflyer
Mike Parsons is offline Find More Posts by Mike Parsons
Old Dec 08, 2002, 01:28 PM
DaleM is offline
Find More Posts by DaleM
Dale Lindsay
Mt Airy, Maryland, United States
Joined Sep 2001
I'd like to see/hear this in flight too. I'm trying to hint to the fact that this kit would make me a really nice Christmas gift. I need ammo - and the video would help!
DaleM is offline Find More Posts by DaleM
Old Dec 08, 2002, 04:23 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Phil (pval3) has agreed to shoot the video for us - he should get it done any day now and as soon as he does we will put it up. We also sent a kit off to Extreme Team in Sweden who has agreed to shoot a video for us. I honestly get quite a few e-mails daily from people who are waiting for the video so I am anxious as well! The only video footage to date is basically my camera on a tripod and a blur so I won't post that but I assure you video is on the way though!
John
http://www.aerc.biz
Old Dec 08, 2002, 06:27 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
blurry Video
Post it blurry or not. Something is better than nothing. Hell I am a little concerened that there is not proven photo's or video to date since this thing has been out showing that it fly's. Kind of like a UFO at this point. Now I don't doubt Glenn's designs but come on, don't tell me there is nothing out there captured digitally since this bird has been out three months or so. I don't doubt that phil will get it in the air, but at least give me a teaser for what I am building. If you don't want to post it then email it to me. Foamflyer@bellsouth.net
FF
Old Dec 08, 2002, 10:09 PM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
PROGRESS??
Well folks,
the video was due to be shot this past week, fininshing touches were suppose to be finished on tuesday night.
Unfortunately - or fortunately depending on your perspective, I live in NC and we received the worst ice storm I have seen in 10 years. I have been without power for almost a week now and am only able to post this update because - - im on the road at a hotel computer.
The plane is fine as is my family and home - - but no power means it is goingto take a little more time to get things done and charged.
Planning on video toward the end of the week now depending on which day the power comes back on.
I will post the video to the aerc site and let you know about it asap
Phil
pval3 is offline Find More Posts by pval3
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
Painting the Aerc F-4 Phantom Brill 1 Electric Ducted Fan Jet Talk 1 Dec 27, 2002 09:32 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New Kits AERC F-4 PHANTOM gbagley Aircraft - Electric - Airplanes (FS/W) 0 Oct 30, 2002 09:07 PM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
