Old Nov 20, 2002, 05:57 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Thanks John!
Originally posted by drbird
The next kit to be released will most likely be the EuroFighter 2000 that most of you have seen FANMAN (aka. Glenn DelConte) Designing) - Glenn is also the designer of the F-4! If you haven't checked out his site then I reccomend stopping by:
http://www.aircadkits.com
John
http://www.aerc.biz
http://www.rc-plans.com
YEAH.........F-14 (and F-15) for EDF-50????
FANMAN is offline Find More Posts by FANMAN
Old Nov 20, 2002, 06:21 PM
jah is offline
jah
Find More Posts by jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
Great thread, this kit will be on the building board next (as soon as I clean up the mess made foamie bashing the C141B-K)! Might start this weekend!!!
Fanman, my post regarding the photo paper was a question, had not thought about weight of paper as an issue. Look forward to the F15!!!!
How 'bout an advesary for the F4, you think a Mig21 or 23 has enough wing area? Better yet a Mig25, that way when I burn up the little GWS EDF50 up because I used too many cells, the smoke coming out would look "scale"!
jah is offline Find More Posts by jah
Old Nov 20, 2002, 06:30 PM
FANMAN is offline
Always looking UP
FANMAN's Avatar
Joined Nov 2000
Anythings possible
CALL me crazy, but what I want to do (But I cant find them) is to have one of those little toy whistles, we had them as kids, and as you blow thru the tube, a tiny spinning whistler would turn and whistle like mad, well If anyone knows where to find them, let me know, I want to servo activate opening the front of this `whistle' attached to maybe the underside, and during a dive, pop open the front of it for what I think would be a cool as heck fly by
Old Nov 20, 2002, 06:55 PM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
F4
Hey guys,
How about the Mig 15 that some of the folks are working on . . .. I havent seen one fly but Ill bet that would make a great on field warbird fight!
I dont know if you would be able to hear the whistle over these little fans screaming away.
My neighbors had a fit when I went out in my front yard and "lit it up" after dinner" (got home at 11PM from a trip, jad dinner and went flying) . . . how about that - noise complaints from an electric!!
Phil
pval3 is offline Find More Posts by pval3
Old Nov 20, 2002, 06:56 PM
jah is offline
jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
I have seen in the foamie forum guys taking the whistle out of nerf footballs (specfically "vortex nerf footbal"), and putting them on Zagi's. Here is a post showing pics:
http://www.rcgroups.com/forums/showt...=nerf+football
Old Nov 20, 2002, 06:57 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
Control options
Glenn,
Someone was asking earlier what other control options you tried out on the F-4 ??
How do you find the durability of the tailerons and the mounts shown on the plans??
Old Nov 21, 2002, 05:37 PM
Kevin P is offline
Find More Posts by Kevin P
Hoosier Hobby Hangar
Kevin P's Avatar
Cicero, Indiana
Joined Oct 2002
FANMAN: I have a novelty catalogue around here somewhere that I will find that sells "Whizzers" Little plastic whistle like the ones you are talking about.
Kevin
The probability of survival is equal to the angle of arrival.
Kevin P is offline Find More Posts by Kevin P
Old Nov 21, 2002, 05:48 PM
FANMAN is offline
Always looking UP
FANMAN's Avatar
Joined Nov 2000
Yes please!
Kevin
Let me know what you find........
Old Nov 21, 2002, 05:54 PM
FANMAN is offline
Always looking UP
FANMAN's Avatar
Joined Nov 2000
Re: Control options
Originally posted by pval3
Glenn,
The controls should be set to Dual Rate, with mixing, and you shouldnt have any problems, the original F-4 style wing would force somewhat small ailerons, though options are always possible. The amount of force on the tail surfaces can only be dictated by the amount of throw you place upon them, hope the opinions help? The servo arm to the elevator should be epoxied, with small screws inserted as well.
Its not easy cramming a servo in between 2 fans
Old Nov 22, 2002, 01:39 PM
Nowell York is offline
Find More Posts by Nowell York
Nowell York's Avatar
Columbus, Ohio
Joined Nov 2001
Changing the engines
Are the GWS fan engines accessible when they burn up and need to be replaced?
Nowell York is offline Find More Posts by Nowell York
Old Nov 22, 2002, 02:52 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
It depends on where you place the hatch - the hatch for the prototype is on the bottom of the aircraft which gives you accesibility to the fan units.
John
http://www.aerc.biz
drbird is offline Find More Posts by drbird
Old Nov 22, 2002, 03:36 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
replacement motors
Hey there,
from my perspective - they are - -with a little work
The fan ducting is paper that is glued using CA to the fan, there are several pieces of ducting that can be removed and reinstalled without much of a headache.
Several of the folks on the forum have talked about sheeting the bottom of the fuselage as the battery area.. this can be set to allow access as needed to the fan unit.
I have been using a GWS fan in a Bonez for a while and have not burned a mtor yet. I have been running it on 8 cells - no problem so far like the DX drive motors have proven to be on 8 cells . . maybe ive been lucky but . . . .
FWIW
Old Nov 22, 2002, 03:38 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Yeah I have several EDF-50's I have had for quite some time with no damage - in fact the only ones I have burned up are from doing explicitly what they tell you not to do!
John
http://www.aerc.biz
Old Nov 22, 2002, 08:21 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
Next step - ducting
Backto the grind stone, got a few hrs of building time before the festivities this evening!
I started on the duct work. This is a tedious job in that the former walls are very thin and very delicate before you install all of the stringers. The ducting is a tight fit and front ducts are not just tubes - they conform to the front of the inlets to make it look better and allow clearance for the fuselage. Sounds simple until you try to work your way around the formers and adjust the ducting to fit tight.
Earlier in the thread the material for the duct was discussed. As I went into my favorite office supply store to get copies of the duct paper on 24# stock, I was met by the sales guy who I talked to last week trying to figure out what other options were out there. I expressed that the transparency would not work because of the heat and he explained that the laser copy transparency film is designed to take heat (from the projectors). I decided to try it and believe it or not, it took a direct hit from the heat gun for more than 5 seconds at 2" before it started to even slightly become effected. After the frustration of trying to get the paper to fit, I canged my mind and decided to try 1/2 ofthe duct material with the transparency material...more to come on that.....
It is a ton easier to use than the paper, stays where you put it and does not move once you get it in place because it is more rigid than the paper yet flexible to conform to the inlet.
Old Nov 22, 2002, 08:32 PM
pval3 is offline
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
Ducting
So, the first 1/2 of the ducting wa a learning experience, the second side went smoothly with the addition of the laser copy transparency maerial for the duct in the front end of the aircraft.. This went 90% better as it is just rigir enough to make life easier in setting up the forms.
I recommend leaving a little material on the front side of the foreward most duct to allow "working room" while you are maneuvering it in plane. The right side I cut it right on the line and I needed to be an OB-GYN to make it work right . . . .If I had little petite fingers Id be fine -- but I don's. Leave yourself some material to play the fit right. You can trim it away once you get it glued in the former.
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
Painting the Aerc F-4 Phantom Brill 1 Electric Ducted Fan Jet Talk 1 Dec 27, 2002 09:32 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New Kits AERC F-4 PHANTOM gbagley Aircraft - Electric - Airplanes (FS/W) 0 Oct 30, 2002 09:07 PM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
