Old Dec 08, 2002, 10:14 PM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
ICe
PVAL,
Glad to see you unscathed!
Mike Parsons is offline Find More Posts by Mike Parsons
Old Dec 09, 2002, 10:57 PM
Midnit is offline
Find More Posts by Midnit
Charlotte, NC
Joined Dec 2002
ice ice baby
I feel your pain Phil, I'm in Charlotte.
Ok, I have never covered before and I need some pointers. I do understand how it works and I have been testing to get a little familiar with the stick and shrink. What I am worried about is which sections to do first. Obviously the tailerons can be done first...but I mean do I do the bottom of the plane first, then tail, then main fuse or what? Should I worry where seams are? The tail section just seems tricky
I am doing a simple yellow on bottom, black on top scheme if that makes any difference how I should start.
Thanks!
Midnit is offline Find More Posts by Midnit
Old Dec 10, 2002, 07:09 PM
drbird is offline
Find More Posts by drbird
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Well covering is purely a matter of personal choice - for this plane I would do the tail first, then the bottom, and then the rest. That way when you go to overlap the top over the bottom you can just set the plane down and cut a nice straight line. I'm still a fan of just painting the wings but to each his own. Of cousre you are asking one of the worst coverers of all times! I can seem to get the covering to go on without wrinkles to save my life!
John
http://www.aerc.biz
http://www.rc-plans.com
drbird is offline Find More Posts by drbird
Old Dec 10, 2002, 09:24 PM
DaleM is offline
Find More Posts by DaleM
Dale Lindsay
Mt Airy, Maryland, United States
Joined Sep 2001
Would sheeting the fuse and tail add too much weight? I would like to achieve that "sheet metal" appearence. Do the ribs/spars show through the fuse when you cover it? It might have the neat "Stearman" look going with monokote only
DaleM is offline Find More Posts by DaleM
Old Dec 10, 2002, 09:46 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
You know thats a very close call. I think the EDF-50's have tremendous power for this plane but again not having done it I can't really give the ok. My only suggestions would be to weigh out all the balsa sheets you plan to use and then do the math from there. I don't want to say either way and I would hate to see you get it done and then it be too heavy. Whether or not the rib spars show through really depends on how tight the covering is and the color you use. I used a greyish/silver and had the covering extrememly tight. As you can see by the picture on the website there are a couple of places where the spars are visible but I think with a color like black or white you may have better luck. One option would be to add small balsa sheet "extenders" from the edges of the spars. This would give you a continous look and elimate the possibility of any showing through. Maybe someone else can shed some light on this subject.
John
http://www.aerc.biz
Old Dec 10, 2002, 10:01 PM
DaleM is offline
Dale Lindsay
Joined Sep 2001
Thanks for the input. I'm by far "expert" when it comes to covering. If I go with this plane and opt'd to cover it with sheeting, it would be the thinnest balsa I could find.
The idea of the sheet extenders is a good idea too.
It's probably listed in this thread, but what's the AUW of the plane again?
Old Dec 10, 2002, 10:13 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Originally posted by drbird
Well I hate to place a number on the weight and speed because they vary so much with equipment used. The AERC prototype came out to a little over 14 oz. and we tried to add some weight just to make sure flying capabilities were same for heavier models.
Again I would say that if you come out to be in the mid to low double digits in oz. (ie. 10 - 15) you should be perfect. If you come out lighter more power to you. If you come out slightly heavier I still think you'll be fine as long as it's not excessive.
John
http://www.aerc.biz
Old Dec 11, 2002, 12:47 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
Help
Ok...maybe I am a little slow..but I am confused. Can someone go through the installation of the Ducts with me? Keep it simple, as in "there are dotted lines on the sheet" Are those to be matched up when glued? And what is the best way to secure those in? How about using a glue stick and rub it on the inside of the balsa formers to secure the ducting? Take a look at the picture as I have layed them out in the order that I think they go....is this correct? Also take a look at the second picture. As you can probably tell, the fan Former is leaning about 4-5 mm towards the front. I thought it had setup enough and when I came in the next morning...I discovered that it hadnt and the weight of the fans had slowly pulled it forward. Is this going to be enough of a lean that I need to fix or do you think because of the ducting it will be ok? If I need to fix it, what will release CA?
FF
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
The leaning tower
Here is the other
Old Dec 11, 2002, 03:57 PM
pval3 is online now
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
covering
Hey folks,
there were two questions that I would like to add my input too:
covering
ducts
Ducts first;
I found that the dotted lines on the duct work get you to the point where the duct is fit perfectly...except for the center duct on the inlet side, extend the ends of the duct so you have room to work. You can cut them down after they are glued into place.
I used simple glue stick to adhere the material together so I could get it in place. Glue stick has about a 10 minute window to get it right before it tears when you try to take it apart. Trial fit everything then tunnel the center duct first then add the outer duct on the front so the seam goes with the flow of air, not against it...
The rear duct is the easiest to work with so get the hang of the duct work from there. This was the only tedious part of the process . . other than watching you tail on the tail assy....nuf said!
After running the motors up and playing with it, I am of the firm belief that the ONLY material to use with these fans is the LASER compatible transparency material. Go to your local office supply store, copy the ducting onto the sheet and go to town... there are three reasons I suggest this:
1) the ducting is increadibly smooth
2) the material is FAR easier to work with than that paper - even the 24# stuff
3) The duct does not change when the motors start running, my paper ducts flex under the vaccum like crazy when I punch the fans to full thrust! I glued them down well and even secured them to the fan units and they still flex, the HP transparency film does not!.
Covering:
I used Hobby Lobby Litespan in black to cover my model.
I like the litespan for two reasons, it is the lightest thing out there and it does not stick to itself as you try to work with it putting it on the plane like the light weight film does!
I covered the wings, it worked great until I got overzealous with the sealing gun and started to melt the foam on one of the tips.... you can get the stuff tight - just take your time!
The fuselage was tough because it has many compound curves and few places to adhere the covering.
I added a few 1/32 X 1/16 stringers where I thought I would need it to ge the form right . . like on the front of F2 where the ducts meet the front of the fuselage and on the back at F5 (I think) where the exhaust comes out and the tail begins. I made a triangle of "tack points" with the stick...you need someplace to connect to for this part of the model. You could get regualr covering to stick . . but I am using lite span and I like it to stay where I put it . . mainly cosmetic though with minimal weight gain.
I split the fuselage into front side and botttom then did one sheet on each side from front to back. These two sheets went clear from nose to tail, draping over the ducts and coming to the stringer where the wing connects.
The bottom is covered in one sheet too from the intakes back to the exhausts with overhang on the wings by 2" to add to the strength of the wing assy..
The peach is shrinking the sheet over the fans, it leaves a lot of heat gun and iron work but should look best when finished.
Hope that answers some of the questions.
pval3 is online now Find More Posts by pval3
Old Dec 11, 2002, 04:01 PM
pval3 is online now
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
All Dressed Up with no place to go!
Awaiting a break in the weather for the video . . rained all day today and too windy yesterday . .
Mother Nature is a )(*&^%$$^%$&(*^
I have no phone lines yet but have power, finishing items done and ready to go .
Pray for a break in the weather all!
Phil
Old Dec 12, 2002, 06:07 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
Check Your CG!
Ok a few builders have e-mailed with questions regarding the CG on the F-4. The F-4 has a very "hair-trigger" CG - meaning that like most planes there is one and only one place for the CG given a certain equipment setup. For future kits we are removing the suggested location of equipment for this express reason. There are just to many different setups to try and accurtely guess any one persons CG. I would strongly recommend going to this site:
http://www.geocities.com/flyawaysrc/cg.html
Use this site to get the correct CG for any and all kits you build and you can't go wrong. You can also use the most common method which is balancing the plane in the center of the wings by moving equip. around. Most of the e-mails w have received have been in regards to the plane being tail heavy. If you use a small battery pack and heavier radio gear this will do it everytime. In other words the CG is correct for most planes on the plans but more often then not the radio equipmet is not, don't just assume the plans for the CG are fool proof on any kit! If anyone has any questions please feel free to e-mail me:
johnp@aerc.biz
John
http://www.aerc.biz
Old Dec 12, 2002, 07:21 PM
Kwesdog is offline
Find More Posts by Kwesdog
I fly Army UAVs!
Kwesdog's Avatar
West Saint Paul, MN
Joined Aug 2002
I did the exact same thing you did foam. I let it sit without bracing the former and when I returned later it was tilted forward as your is.
All I did was carefully break the former loose again from the sticks and do it the correct way.
I dont know how much glue you used and if it will be possible for you but on mine the sticks didnt break and you cant tell I ever had a problem.
I would think that if you left it the way you have it now you would lose some thrust because the airflow from the fan will be pointing towards the duct and deflect some air off the top of it.
Harry
Kwesdog is offline Find More Posts by Kwesdog
Old Dec 12, 2002, 07:25 PM
drbird is offline
Http://www.aerc.biz
drbird's Avatar
Los Angeles
Joined Jan 2002
You can use a CA debonder - I'm sure Hobby Lobby has it - I know Tower does - however I have never actually bought a debonder that actually debonded - maybe someone else has had luck with a certain brand??
John
http://www.aerc.biz
Old Dec 12, 2002, 08:34 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
debonding
Thanks Kwesdog and Dbird. I am going to attempt it as is. I used a very good CA as I dont waste money in that department. A little of this CA goes a LOOONNNNGGG way and I too have never seen a debonder that actually holds up to its name. I measured the lean and it turned out to be 5.5 MM. I will be the beta tester to see if this actually causes a problem with thrust. I have already installed the rear ducting (what a Pain installing the ducting is!!) so it is too late to turn back now. Here is a questions though. Is it me or does the balsa on the elevons seem that they would snap under pressure? I understand that when they are covered, that will lend some strength to it, but I was thinking of a couple of pieces of packing tape? What do you think?
Anyone build/fly AERC F-4 Phantom War Bird Radio Parkflyers 3 May 11, 2003 06:19 PM
Painting the Aerc F-4 Phantom Brill 1 Electric Ducted Fan Jet Talk 1 Dec 27, 2002 09:32 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New Kits AERC F-4 PHANTOM gbagley Aircraft - Electric - Airplanes (FS/W) 0 Oct 30, 2002 09:07 PM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
