Old Nov 13, 2002, 09:38 PM
FlycastSeven is offline
Find More Posts by FlycastSeven
Notorious Battery Abuser
FlycastSeven's Avatar
United States, MA, Cambridge
Joined Jul 2002
Velkom/Model Motors Brushed Motor Info
I think this should be a thread where people post any data and uses for the relatively inexpensive, brushed ferrite and neodymium motors that are sold by Model Motors.
Recommendations for planes for these motors are welcome.
I don't have any personal experience with them, but would like to know how they can be used (cough E3D? cough cough ), as, I suspect, other people do.
Brushless is not the only solution, methinks.
George
FlycastSeven is offline Find More Posts by FlycastSeven
Old Nov 14, 2002, 06:19 AM
Bob P is offline
Find More Posts by Bob P
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
George
I have recently replaced the Plettenberg HP 200-20-6 EDF motor in my Glockner F-86 sabre with a Model Motors VM 2020/20. Both motors are on 10 CP1700 cells in WeMoTec 480 Minifans.
I collected some data on both set-ups as follows:
Both motors are about the same length and diameter, but the VM weighs10 grammes less than the HP. The brushes are the same cross section.
Average Power/current/time for a run at full throttle down to tail off (@150 watts): HP 239 watts/18.3 Amps/240 secs; VM 241 watts/18.4 Amps/220 secs.
Power/current initially and at 30 secs: HP 299 watts/26 Amps; VM 330 watts/30 Amps and HP 264 watts/23.4 Amps; VM 274 watts/26 Amps.
I have flown the Sabre a number of times and the performance appears the same for both motors. The Model Motors 2020/20 cost about 2/3 the Plettenberg 200-20-6.
Bob
Bob P is offline Find More Posts by Bob P
Old Nov 14, 2002, 05:23 PM
John E is offline
Find More Posts by John E
Bristol, England
Joined Aug 2000
George,
The larger neodym motors were recently discontinued (replaced by the AXIs), but you are right, all of the 20 series neodyms and the 24 series ferrites live on.
I have flown the 24/10, 24/12, and 24/16 in the same ElectroStreak. My favourite of the setups was the 24/16 with 10 RC1600 and a 9x7 giving good flights of over 7 minutes.
The furthest I pushed them was to use a 24/12 with the 10 cells and a 7x5 direct drive. The model did go well with around 380W, and there was no sign that the motor had been involved in anything out of the ordinary.
More recently we have used a 24/16 with a VMG 3:1 gearbox to turn a 14x7 on 16 cells in a model weighing about 6.5lb.
John E is offline Find More Posts by John E
Old Nov 15, 2002, 03:04 AM
electricrcflyer is offline
Find More Posts by electricrcflyer
Corvallis, OR
Joined Mar 2000
Electroscreamer sp400 EDF (201 sq in Wing area, weight 24-25oz)
Velkom 2014/27, MF480, 8 800ARs/CP1300s
14-15 oz thrust, 18-20 amps, 165 watts (full throttle)
The 2014/27 is a very good sp400-480 upgrade for EDFs. I have logged many flights on 8 cells with little brush wear. Very durable. Can probably be pushed to 9 cells.
Ron
electricrcflyer is offline Find More Posts by electricrcflyer
Old Nov 15, 2002, 03:50 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
glad to hear good things... scrounged on ezone to get a cheap brushed system to put in a goldberg electra I was given (built and everything! in perfect shape!)
I got a...
velkom 24/10, Dymond D50 50A ESC, 8x1700aup, ernie thorpe inline 2.85:1 geabox (all metal, ~2oz!), and freudenthaler 14x10 folder. motocalc says ~34oz of thrust, on a 40oz AUW glider. 35 degree climbout, ~25A. This is all simulation, I hope to try it out this weekend or worst case in a week...
opualuan is offline Find More Posts by opualuan
For Sale Velkom (Model Motors) 4 motors NIB aze Aircraft - Electric - Power Systems (FS/W) 5 Nov 12, 2005 06:08 AM
Speed 400 brushed motor info ElSeeker Power Systems 3 Oct 31, 2005 11:07 AM
Question U-Can-Do 3D Flex Foam model stock brushed motor??? p51flyer 3D Flying 7 Oct 23, 2005 12:05 PM
High Power brushed motor info needed Bret Power Systems 3 Jan 08, 2005 04:20 AM
FS: Velkom/Model Motors 2:1 gearbox Lance Aircraft - Electric - Airplanes (FS/W) 0 Dec 01, 2003 12:33 AM
