Go Back   RC Groups > Aircraft - Electric - General > Batteries and Chargers
This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Aug 04, 2007, 04:15 PM   #46
Probedude's Avatar
Originally Posted by Fedor
Thanks a lot .I got my self the UH lipoguard.Yeah it also seemed to me littlebit bizzare that you should use some lipoguard and on same time ventilate.Because the lipogurad blocs tha gases.
Thanx
No it doesn't. These bags are meant to contain the heat and flame but they need to vent. Pressure build up is not a good thing.
Probedude is offline Find More Posts by Probedude   Reply With Quote
Old Aug 04, 2007, 05:16 PM   #47
characters welcome
Mark Wood's Avatar
The vent on our LipoSack is designed to vent smoke and gases but prevent flaming debris from being thrown about ground zero.
Is there a vent on the UH copy? I haven't seen one.
mw
Mark Wood is online now Find More Posts by Mark Wood   Reply With Quote
Old Aug 04, 2007, 05:34 PM   #48
Probedude's Avatar
mw
My comment was about lipo sacks in general and his misunderstanding of what they are supposed to accomplish. They all vent because none are gas tight.
Where is the vent designed into your sack? Somewhere other than the flap region?
Old Aug 05, 2007, 11:30 PM   #49
No Guts, No Glory
flyin C's Avatar
Eventually it will, though mine really settles around 1.2C. How long do you let it charge for before stopping it from the charge being too high?
What capacity was the last lipo you charged to completion on the Cellpro?
Dave
i was charging a 3s 2100 battery before at 2 amps, unplugged the charger to reset the settings, and started charging my 2s 900. It was on the charger for 4-5 min. It went from 31% to 64% in that time!!!
flyin C is offline Find More Posts by flyin C   Reply With Quote
Old Aug 06, 2007, 12:03 AM   #50
characters welcome
Mark Wood's Avatar
That's where the two 2" vents are. I've seen copies without a vent. Probably pretty hard on the closure system in an ignition.
mw
Old Aug 06, 2007, 12:20 AM   #51
Probedude's Avatar
Ahhh! That's why! The Cellpro remembers the last pack you charged to completion and starts the next pack off at that value. Again it should only do this for the first few minutes, maybe up to 5 - I don't know for sure, before figuring out "Hey, that's too much!" and start lowering the charge current.
Old Aug 06, 2007, 09:28 PM   #52
Mark, maybe the geniuses who copied your design figured your safety vent was a flaw that needed to be corrected.
Dave Hederich is offline Find More Posts by Dave Hederich   Reply With Quote
Old Aug 06, 2007, 10:18 PM   #53
characters welcome
Mark Wood's Avatar
Darned seamsters. I'm gonna have to talk to them about those missing seams.
mw
Old Aug 06, 2007, 11:13 PM   #54
No Guts, No Glory
flyin C's Avatar
I charged the same battery last time and today. I put it at 1C, so it should be charging at .90amps, since its a 2s 900mah battery, but it charges at .99-1amp?? Am I going to harm my battery?
It was not a full charge, just from 83% so it only charged at that rate for a few minutes, until the low amp, ''balancing cells'' charge starts.
Old Aug 07, 2007, 12:48 AM   #55
Frankenstein Packs
rampman's Avatar
.99-1A is fine. Only 10% over what the standard is at 1C but many charge at 2C with newer pack technology.
Rick
www.CommonSenseRC.com
rampman is offline Find More Posts by rampman   Reply With Quote
Old Aug 07, 2007, 12:54 AM   #56
Probedude's Avatar
As Rick said, you're fine.
The Cellpro doesn't know what capacity battery you hooked up (it can't read the label). It can only calculate what the capacity should be based on the rate of voltage rise over time and at a given current. Mine overall at the 1.0C charge setting settles in at about 1.2C.
Don't worry about it!
Old Aug 07, 2007, 09:02 AM   #57
pilotpete2's Avatar
As Probedude said, the Cellpro uses a "dynamic" charge rate.
The last time I checked out those stone tablets that some guy with a white beard carried down from the mountain, there was no entry that stated "Thou shalt not charge lipos at over 1C"
Pete
pilotpete2 is offline Find More Posts by pilotpete2   Reply With Quote
Old Aug 07, 2007, 11:50 AM   #58
Probedude's Avatar
Pete
It was on the 3rd tablet that he dropped one the way down from the mountain! (Moses looked suspiciously like Mel Brooks. . . .)
Old Aug 11, 2007, 06:00 PM   #59
No Guts, No Glory
flyin C's Avatar
Cellpro 4s....
I charged at 1c on my 2s 900mah battery, but it only charges at around .50-.60 amps?? Am I doing something wrong??
Old Aug 11, 2007, 06:01 PM   #60
Probedude's Avatar
Cellpro 4s....
All the way to the end of the charge it only did 0.5-0.6?
What was the state of charge of the pack when you first put it on?
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 10:46 PM
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 7 Sep 30, 2003 02:07 AM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 01:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 09:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 11:00 PM
Bored? Want to fight?
Join the RCGroups clan!
