| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
Insane Plane Killer
The reason they have that statement on their website regarding the CellPro charger is because they know what their charger can and will do. It may not be something to write home about when it comes to looks, but it does the job it was designed to.
Curious that an inexpensive charger as FMA's sell for such a reasonable price; while OTOH, brands costing more than twice what a CellPro can be had for have to daisy chain gadgets to them in order to balance the packs they are charging.
#32 |
No Guts, No Glory
Wow, know I now the real danger of a lipo catching fire ,thanks For my first charger, I thought I would invest in a good, safe charger, so got the Cellpro 4s. It is a great charger, but I thought that it would change settings as ''fast charging'' and charge according to what it calculates. So after unplugging it after charging my 3s 2100 batt, I plugged in my 2s 900 lipo thinking it would change modes. It charged my 2s 900mah battery at 2amps!! I luckily caught it in a few minutes though.
#33 | ||
I've been told (and I think it is written on their website now somewhere) that no damage will occur to the pack during this time. What I'd like to try just to see what happens is to charge a pack with the input voltage to the Cellpro at say 11.5V, and then during the charge rapidly bump the input voltage up to say 15V and see what happens (simulate an engine starting). The control loop for current adjustment on the Cellpro isn't very fast and bench testing has shown the charge current to spike up with an increase of the input voltage for a few seconds until the control loop starts to kick in. This may be common for other chargers too that use the MCU as the switching regulator controller vs having a dedicated power supply IC perform the regulation. Quote:
Edit: just remembered there would need to be 2 points of failure to short the lipo to the input power supply. There is the step down FET on the switching power supply, but also the N-channel FET on the negative side of the pack that would need to either be shorted or driven into conduction to allow this failure mode to be a problem. Either way, a fuse should be added and if UL approved would likely be needed. Dave Last edited by Probedude; Aug 01, 2007 at 06:17 PM. Reason: added disclaimer on other chargers. |
#34 | |
Trexazoid
#35 |
Sushiholic
I'm new to LiPos. Those are some scary looking pics and I'm wondering if I should even keep them in the house. Should I be worried about storing my LiPos when they are not connected to the charger? Will the charge drop to a risky level if I don't use them or check them for a while? I may only get to use mine once or twice a month. I have two chargers, a Cellpro 4s and a MRC 977. If I can't store them in the house, where/how do I store them?
Thanks for any advice. |
#36 |
Frequent Flyer
Hi AsahiToro,
I'm guessing that most of us store our lipos in the house. It is extremely unlikely that an undamaged stored lipo is going to spontaneously ignite. Even so, I store mine in an ammo can away from flammables so if there is an incident it will be confined to smoke damage. Lipos do not lose much if any voltage when stored. To prolong their life, store them at around 3.85v/cell unless you are flying regularly. Regards, Brian |
#37 |
Trexazoid
AsahiToro,
I store and charge mine in my fireplace. With the metal grating pulled and the glass doors (if they really are glass) mostly closed. I also leave the flue open for the magic smoke to go up instead of into my living room. I fly regularily (try to fly everyday weather permitting) so I leave mine fully charged. However, since I live in the north I will be charging them to the reccomended storage voltage, sealing them up in zip lock bags and placing them in my refridgerator (not the freezer) for the winter months after my last flight of the season. |
#38 |
No Guts, No Glory
Using my Cellpro 4s
I put it on 1C, but its charging my 2s 900mah battery at 1.2 to 2.4amps??? I don't understand? Shouldn't it charge at .90amps.. |
#39 | |
What capacity was the last lipo you charged to completion on the Cellpro? Dave |
#40 |
4% balsa 90% glue 6% luck
fyi: the big box was a power supply, the charger is small and sitting on top of it I think it was an older astro flight.
Thanks everyone for making this an informative read. I like the fireplace idea... I have three ammo cans - one for charging, one for seldom used packs, and one for currently used packs. good luck and happy flying! |
#41 |
Vampowered!
My condolences to you for your damage. It is a hard lesson and one I have learned myself. It also takes guts to admit the mistake and more to share the images with others. Some folks dont really realize the potential of a 3S pack much less the destructive power unleashed by a 5S5000. Let me tell you it is unreal. Even in a controlled environment it is a scary event.
I prefer the Lipo Sack for containment. I know there is a knock off but I like to give credit where it is due....To Mark Wood. He is a former moderator here and contributes much to the hobby. Be safe and charge safer. Peace bro Vammy |
#42 |
Hu guys im just a lipo beginner so i wanted to ask you if lipos should be discharged before charging and if yes should they be discharged threw the balancer or i can plug it directly to the charger?And i also heard that they should be ventilated during charge because they release some sort of gas?Is it trew?
Thanx |
#43 | |
Tree? That's a Tx weed!
Lipos do not "vent" during charge unless you encounter a catastrophic failure. Lead-acid wet cells are open cells becuase they vent hydrogen during charge and need to be vented out of living space but lipos are sealed packages. You are doubtlessly hearing hearing stories of lipo's "venting" - they can and when they do, it is majorily unpleasant. This is why I charge all lipo's in a small fire proof safe (Sentry 1100, was $19 at WalMart). And I store them in there also. Also, never discharge a lipo below 3V/cell - this will damage/destroy it. Nickel cells should be discharged occasionally but not lipos. Please read the sticky here: http://www.rcgroups.com/forums/showthread.php?t=209187 It has much very good info you need. I have had lipos since late 2003. Becuase I follow the rules for handling and using lipos I have never had a "vent-with-flame" incident, nor have I had any puff up on me. Almost had an incident once (IR thermometer caught the temp RISING fast!) but it was a direct result of a very hard crash. So use the right equipment (lipo charger, lipo balancer, fire proof container), the right procedures (never leave unattended while charging, etc), don't overload (run at burst discharge rate for minutes at a time) and life will be good. Enjoy, Crash
#44 |
1. Do not discharge before charging. Lipos are harmed by low voltages which may be obtained by a deliberate discharge.
2. If you have the balance plug, use it. If packs are not discharged to more than 80% of capacity they will usually stay in balance. 3. Charging a lipo does NOT release gases nor should they get warm. If the packs are puffing and/or the getting warm, the packs are defective. 4. IMO, lipo's should be charged in a fire safe container and away from flamables. I use a tabletop BBQ. Others use Lipo Sacks, cinder blocks, etc etc. |
#45 |
Thanks a lot .I got my self the UH lipoguard.Yeah it also seemed to me littlebit bizzare that you should use some lipoguard and on same time ventilate.Because the lipogurad blocs tha gases.
Thanx |
| Thread Tools | |
| How Prevalent Are Lipo Fires? | DLC | Batteries and Chargers | 32 | Sep 27, 2009 10:46 PM |
| Can Triton temp. sensor prevent Lipo fires?? | duganderson | Batteries and Chargers | 7 | Sep 30, 2003 02:07 AM |
| Lipo Test are in | tallflyer | Parkflyers | 0 | Aug 26, 2003 01:09 PM |
| Question How Lipo's are rated | electron_head | Batteries and Chargers | 6 | Jun 30, 2003 09:58 PM |
| UK E Zoners are real people.... | tim hooper | Electric Plane Talk | 13 | May 01, 2001 11:00 PM |
