This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Jan 30, 2012, 03:00 PM
spog is online now
Find More Posts by spog
Joined Mar 2006
The 460mah rating is the battery capacity. The battery can supply 460 milliamps of current for one hour. (should not drain the battery that low though, 80% is a good point). You are correct in that a 1C charge is 460ma, a 2C charge is 920ma, etc... The battery discharge rate is not a consideration for charging. The thing to be careful with when charging is to not exceed the battery voltage by selecting the wrong number of cells on the charger. Charging a 2S battery with the charger set to 3S will cause problems if the charger allows cell overvoltage. (assume it will)
spog is online now Find More Posts by spog
Old Jan 30, 2012, 03:45 PM
thebuckeye is offline
Find More Posts by thebuckeye
thebuckeye's Avatar
United States, IL, Forest Park
Joined Jul 2011
Thank you for the response. So in general, is it ok to charge a battery at 1C (which I am assuming will take 1 hour)? Also, I know each cell holds 3.7V in a lipo battery. However, when I charge it, my charger says each cell has a higher voltage than that (and I did double check that I charged my 2s battery on the 2s setting).
Thanks!
thebuckeye is offline Find More Posts by thebuckeye
Old Jan 30, 2012, 05:08 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
A fully charged lipo cell is 4.2 volts.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jan 30, 2012, 06:31 PM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
Thanks!
Yes it is perfectly fine to charge at 1C, which in the case of the 460, that would
.46 amps. Like Mark says, 4.2 volts is fully charged, 3.7 volts is the minimum that you do not want to run your battery below. 3.85 volts is about half charged and where your batt should be for storage of longer than about a week.
Keep in mind that a typical 12v car battery, is fully charged at 12.6v, 75% charged at 12.4v, 50% charged at 12.2v, and dead at 12.0v. Somtimes it helps to explain it this way. Some peeps may assume that the batt would have to be at 0 volts to be dead. Not true.
Don't let Spog's post confuse you, I am sure what he means to say is never use more than 80% of your batt, leaving 20% or more at all times.
In theory, 1C should take 1 hour, but they usually charge in a bit less time than that, because remember we are not running them down to a completely dead state.
Some battery makers are claiming a charge rate of up to 5C or 6C, but I don't like it and still charge at 1C.
BattleDude is offline Find More Posts by BattleDude
Old Jan 30, 2012, 06:44 PM
thebuckeye's Avatar
Joined Jul 2011
Ok. That is what I have been doing. How do I know when there is about 20% life left? Just play around with it until I get the timing right and it takes about 45-50 minutes to charge (at 1C)? Would the battery go bad if it dropped below 3.7V? Thanks for all of the help! I really appreciate it.
Old Jan 31, 2012, 09:15 AM
BattleDude's Avatar
Joined Aug 2011
You can't be accurate that way, because you don't know how much is left in the battery you are fixing to charge. What if you have 50% left when you begin to charge? Then it is going to take much less time to charge the batt.
Battery will go bad quicker if you drop the voltage below 3.7v, again and again.
If you have a digital charger, or DVM you can use either one to calculate 80/20%. Here some info that may help you do that:
https://sites.google.com/site/tjingu...the-variable-c
If you don't have anything to measure volts/amps/ohms with, and are using the stock Celectra charger, it would be better to time your flights, when using a fully charged batt. Limit your flight time to 4 minutes, maybe 5 minutes for a stronger batt.
Or, after breaking in your batts with 6 easy 2-3 minute flights, you could time your flight to see how long it takes to reach LVC(not a good thing to do again and again as it will shorten the life of your batt) Say it took 5 minutes to reach LVC, multiply 5 minutes by .8 (80%) to reach a figure of 4 minutes. See?
It is best to have a DVM which can be bought for 5-10 bucks. Let the battery rest 15 minutes after flights, and check the batt voltage. Keep increasing flight time untill resting voltage starts to come down to 3.7v.
Or just get yourself a good digital charger, which takes care of much of this for you:
http://www.amazon.com/Thunder-Balanc...8023428&sr=8-1
Presto! There you have it!
Cheers!
Old Jan 31, 2012, 02:40 PM
thebuckeye's Avatar
Joined Jul 2011
Ok. Perfect! Thank you for all the help!
Old Jan 31, 2012, 06:29 PM
BattleDude's Avatar
Joined Aug 2011
Sure Bud, anytime!
Old Feb 06, 2012, 09:21 PM
Batter is offline
Find More Posts by Batter
Joined Nov 2011
Finally, I find this post was started in 2007, it lasts five years.
Batter is offline Find More Posts by Batter
Old Feb 08, 2012, 07:48 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
question
I usually charge my batts when I get home from flying. then I might not use them for 4 or 5 days , they seem not to have a full load of power,
another thing I do which could be a factor I have a nine eagles charger 3.7 volt from my sp328 instead of charging one battery at a time I made a connector (spider) to charge 3 at a time , I charge them at the lowest rate , could the charger be not charging them to full power along with the downtime between sessions be a factor. may be one at a time is better??
Tonytester
tonytester is offline Find More Posts by tonytester
Old Feb 09, 2012, 09:08 AM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Tonytester
You need to measure the voltage of each lipo after charging ,only way to know dude.
Magic k2 is offline Find More Posts by Magic k2
Old Feb 09, 2012, 12:04 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
your batteries will perform better when you charge then immediately before use.
One obvious reason is that charging warms them up slightly. A couple of degrees can make a huge difference.
gravityKills is offline Find More Posts by gravityKills
Old Feb 09, 2012, 05:56 PM
Yo R Wee Too Lo
Joined Oct 2011
thanks
I did try that today was great
TT
Old Feb 09, 2012, 06:00 PM
Yo R Wee Too Lo
Joined Oct 2011
thanks I also checked all my batts
4.21 when just off the charger. also 3.79 when I quit flying.
one morning it was 19F batteries lasted only a short time I had them sitting on the porch I should put the on my pocket .
thanks
TT
Old Feb 10, 2012, 01:32 AM
like a rock!
Finland
Joined Oct 2007
yea I toast mine under a halogen lamp before flying
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 27 Aug 27, 2014 06:26 AM
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 09:46 PM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 12:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 08:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 10:00 PM
