This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Jan 20, 2012, 09:09 PM
Chocks is offline
Find More Posts by Chocks
Chocks's Avatar
United States, CA, Vacaville
Joined May 2008
Ok guys.( not to sure about the ok part) I haven't been on this forum in a while and I see your still arguing about storage of lipos. Has anyone of you given any thought about how they are stored at the factory, LHS, and even shipping???? If any of your wild imaginations had any substance, we would have explosions all over the world every day. Or at least fires. People say (including me) that all you need is common sense to take care of your lipos. Obviously there is a lot of that missing on this subject.
Chocks is offline Find More Posts by Chocks
Old Jan 21, 2012, 08:03 AM
BattleDude is offline
Find More Posts by BattleDude
High Plains Drifter...
BattleDude's Avatar
United States, WY, Crowheart
Joined Aug 2011
There is difference between brand new Lipo's on the shelf, and one's that have been beat around in aircraft. Impacted batts require more attention be payed to them.
Can't figure out why you think people wanting to be 100% safe with Lipo's, are just imaginations running wild? Strange indeed?
It is a discussion, but some see it as an argument.
BattleDude is offline Find More Posts by BattleDude
Old Jan 21, 2012, 08:10 AM
BattleDude's Avatar
Joined Aug 2011
Originally Posted by hidaven View Post
One thing about the flue without the exaust fan. Like a fireplace chimney, the flue needs to be primed to get the heated smoke to rise. In cold weather that smoke may resist and spill out if the seal fails.
My thought was to use a radon balanced centrifical fan at 400 CFM into a 4 inch PVC pipe. Those fans are more than enough to evacute the smoke. I just cant figure out how to tripthe fan with the smoke detector : (
I would build the box so that there is no chance of gasket failure, and seal it up 100% so the smoke/gas/fumes will be forced up the flue, without the complicated exhaust fan setup, IMHO.
It doesn't need to be "primed" if pressure is forcing the fumes out does it?
Old Jan 21, 2012, 04:58 PM
Chocks is offline
Chocks's Avatar
Joined May 2008
Because I have been doing electrics since it started in the 80's. Me nor anyone that I have been around including racing and flying with nicads and graduating to lipos when they first came out have ever had any problems with lipos in storage. Charging and misuse , yes. Plenty of times. Storage no. I'm sorry if you think I am being to negative about this. I just think if a person uses his/hers common sense they'll be fine.
Old Jan 21, 2012, 05:42 PM
BattleDude's Avatar
Joined Aug 2011
OK, I have no troubles with promoting common sense, that is a very good idea. But youngsters are using these batts and they are hard to teach common sense to. It is the in-experinced Lipo user that concerns me.
How do we deal with that?
There are very few posts here about Lipo storage, mostly talking about charging and misuse. So I am not real sure why you speak of plenty of issues with charging and misuse and then discount it at the same time?
Old Jan 22, 2012, 08:02 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
This is part of the natual selection process. Mother Nature will take its course with the youngsters who can't realize that these lipos are practically C4 packets
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Jan 22, 2012, 08:20 AM
Papangue is offline
Find More Posts by Papangue
Reunion
Joined Nov 2010
Hi LiPo users friends.
I discovered this tread and my questions have perhaps been answered, but 114 pages are too much to read.
So, my questions :
- what kind of fire extinguisher must be used for a LiPo fire?
- can a LiPo battery burn "alone", by itself, spontaneously, not when charging? I can watch non-stop a charging battery, but after charging I must work, sleep, drive, eat, etc..
Thanks for answer or for indicating the answering posts.
Papangue is offline Find More Posts by Papangue
Old Jan 22, 2012, 08:36 AM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
get a fire blanket. It does the least damage to your home.
There are a few reliably documented cases, where LiPos started to burn spontaneously. So don't store them next to the nitro fuel.
gravityKills is offline Find More Posts by gravityKills
Old Jan 22, 2012, 10:16 AM
hidaven is offline
Find More Posts by hidaven
United States, NJ, Roseland
Joined Apr 2009
God gave you eyes so you can read 100 pages....lol Read!!! Hey its better than watching Americal Idol : )
hidaven is offline Find More Posts by hidaven
Old Jan 22, 2012, 10:44 AM
wjbender is offline
Find More Posts by wjbender
Learnin mo ever day
United States, NJ, Tinton Falls
Joined Jul 2007
Well after some additional research online and at the local Lowes I have come to the conclusion that a fan is too expensive if you want one that mounts outside the house and can exhaust hot gasses. The best solution IMHO is a sealed box with a fireproof gasket, and a pair of 2" EMT conduits vented to outside. This is sturdy and most of the pressurized gasses will quickly be forced out the conduits. As a secondary precaution I plan to add a shop exhaust fan that can be triggered by a smoke detector or manual switch. I need to vent my shop anyway. This is far far better than just charging inside the house with a lipo sack. I'll post some pictures as I build this. I have parts on order.
wjbender is offline Find More Posts by wjbender
Old Jan 22, 2012, 11:27 AM
Joined Apr 2011
i store mine next to tanks of liquid oxygen. so far no explosions!
Old Jan 22, 2012, 04:09 PM
like a rock!
Finland
Joined Oct 2007
I'd have thought it sounds dangerous. But if you say "no explosions", I guess it must be safe
Old Jan 23, 2012, 03:27 PM
wjbender is offline
Learnin mo ever day
Joined Jul 2007
OK making progress on my charging enclosure. I got this on ebay for $60 with shipping
Cooper B-Line 24208-1 NEMA 1 Steel Hinged Enclosure Electric Box 24" x 20" x 9"
I'll change the door gasket and install a latch the pulls the door tightly closed against the seal. Pics to come
Old Jan 25, 2012, 09:48 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Those videos are impressive. The one major difference, after the size, is the larger pack appeared to be sealed.
Anyone here burn black gunpowder and modern smokeless powders? The black powder burns fairly quickly and the modern powder much slower. The modern powder creates a HUGE difference in pressure and velocity.
What most call an explosion is often the result of expanding gasses breaking a containment vessel. This is why cartridges in a fire rarely produce major velocity and are rarely deadly. Clearly a substance butning extremely quickly is an exceptions. but modern powders burn at a similar rate as some of these fires.
I hypothesize (avoiding the request for evidence) that the second video with no pressure relief was more dramatic. Was it more deadly? Don't know. Relief holes seem to be a good way to avoid an explosion. If the gasses can be contained without rupture then the sealed container seems less toxic. I would be concerned about being to near a rupturing ammo can. How much? A drywall layer would likely suffice. Maybe....
Rickflaguy is offline Find More Posts by Rickflaguy
Old Jan 30, 2012, 02:29 PM
thebuckeye is offline
Find More Posts by thebuckeye
thebuckeye's Avatar
United States, IL, Forest Park
Joined Jul 2011
Charging Question
Hey guys, I am relatively new to RC (or at least lipos) and I was reading through this thread and it really made me away of the potential risks. When first starting out I only had 1s batteries and charged them with the celectra 4 port charger. Now I have some 2s and 3s batteries and am charging them with a venom pro charger. I have searched everywhere and I think I am starting to understand things but I wanted to type up a brief summary of what I know to make sure I am not doing anything horribly wrong and am gonna cause an explosion or a fire. Right now I am primarily using a foamy that uses 2s 460mah batteries with a 25-40c discharge rate. I know the 460mah is a unit of charge and I know 2s is 7.4V and I have read that the C rating is essentially the charge/1000? I have heard it is best to charge batteries at 1C which in this case would be between .4 and .5 amps. Is this correct? Or am I completely off? I don't need too technical of explanations, I just want to make sure I am practicing safe lipo charging.
Thanks everyone!
thebuckeye is offline Find More Posts by thebuckeye
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 27 Aug 27, 2014 06:26 AM
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 09:46 PM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 12:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 08:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 10:00 PM
