This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Dec 21, 2011, 09:33 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Just talked with a friend who has been using lipos for years. Charging it on a plastic table in his garage with a four port charger and $2000 worth of gear. Lost it all.
Familiarity breeds contempt.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Dec 21, 2011, 11:27 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Very true.
Any details? Didn't see it in the local paper but that's not unusual.
hoppy is offline Find More Posts by hoppy
Old Dec 22, 2011, 08:04 AM
spog is online now
Find More Posts by spog
Joined Mar 2006
Good video bzfrank. It makes me laugh when people think they're safe and sound by simply being in attendance while charging. Assuming you're sitting right beside your charging LIPO's and watching them the whole time and wearing your fireproof suit and gas mask, you might be able to get it outside in time to avoid 20% of the toxic smoke in the house.
spog is online now Find More Posts by spog
Old Dec 22, 2011, 08:51 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by spog View Post
Good video bzfrank. It makes me laugh when people think they're safe and sound by simply being in attendance while charging. Assuming you're sitting right beside your charging LIPO's and watching them the whole time.
Actually people watching batteries charging are quite safe IMO. What you didn't see in the picture is the usually long time period between the application of overvoltage and the eventual ignition. The Utah Flyers reported that it took between 4-7 minutes for there overcurrent/overvoltage ignitions to occur. Lipos just don't go from normal to a flaming inferno in microseconds, it goes through several stages, the most notable being the ballooning of the pack which is very obvious to a "watcher" at which time the charging can be stopped and the battery safely disposed of.
Perhaps bzfrank would like to comment on what happened between starting the test and the ignition in terms of time and physical changes that occurred.
Old Dec 22, 2011, 12:22 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
the reason is that fires tend to grow exponentially. If you react immediately, you will be able to handle it. If you are out of the room for a minute, by the time you're back the curtains will be on fire and all you can do is run.
gravityKills is offline Find More Posts by gravityKills
Old Dec 22, 2011, 01:34 PM
bzfrank is offline
Find More Posts by bzfrank
4.2V of pure Kraut power
bzfrank's Avatar
Germany
Joined Nov 2006
Actually not very much. The temperature did start to rise steadily after 4.6V/cell was reached and slight puffing occurred over 4.8V/cell. However quite late in the process. The charge current did drop from 6A to 200mA in the last minutes as the internal resistance increased due to the decomposition of the electrolyte and cathode - Thermal runaway was well underway then and even if you would have disconnected the cell it still would have blown.
So if the cell already reached >80 degree celsius (180F) it will very likely go up in flames regardless of what you do or disconnect. The only safe handling is to put it in a place where it cannot start a fire and the toxic smoke cannot damage your lungs (contains hydrofluoric acid) and move out of the way fast. BTW flame length in my test reached more than 3 ft.
Regarding time: About 25 minutes from a fully charged 4.2V/Cell to the start of the fire. More than I thought it would. But it would not count that its always this long, it certainly depends on the make of the cell.
bzfrank is offline Find More Posts by bzfrank
Old Dec 22, 2011, 01:49 PM
JWilliams2 is offline
Find More Posts by JWilliams2
JWilliams2's Avatar
NY State
Joined Jan 2007
Last two years I've had my lipos and cells kicking it in my basement just chilling out. I have been meaning, more recently, to do something about that and I think I will finally put them at the least in some fireproof safe or similar.
The odds of a lipo fire ARE fairly small, otherwise we'd all be hearing regularly about fires, but they are not minute, and certainly the chances of house fire are increased if you're storing these things in the house, plus many of us have had crashes and have bent cells or whatever.
I did buy a fire extinguisher a while back and it is within easy reach.
Closest I ever came to a fire was a couple years back very stupidly and totally out of character for me (since when I do this I always set my watch count-down timer to remind me) I came down one day and realized the soldering iron had been put back on the shelf _plugged in_. It had melted a bunch of plastic and some netting but thank God nothing flamed up.
JWilliams2 is offline Find More Posts by JWilliams2
Old Dec 22, 2011, 02:28 PM
UlteriorModem is offline
Find More Posts by UlteriorModem
UlteriorModem's Avatar
Joined Aug 2011
Heh... I cant tell you the number of times I have picked up a soldering iron by the wrong end
UlteriorModem is offline Find More Posts by UlteriorModem
Old Dec 22, 2011, 07:58 PM
Joined May 2011
Very true.
Just took out some gear. No structural issues. Knowing him he dealt with it. Amazing kind man. He took my Park 400 with a ripped lead so short you couldn't get them to touch much less solder. He built a bridge of solder and called me to pick it up. do you want to fly at KMS with us?
Old Dec 23, 2011, 12:27 PM View Post
jiaren963
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Dec 23, 2011, 01:54 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by jiaren963 View Post
wonderful christmas gift, they are a lot of small gifts on the battery, you do not miss this opportunity.
We are 30 per cent discount, take a look at our discount arrangements and products. Time is running out.http://yi.si/167
Non RC
Old Dec 23, 2011, 09:45 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I popped a cell today
Yulp. I always say to S L O W L Y discharge an old lipo before tossing it away. I was in a rush to discard close to 20 packs today so I had a bunch of light bulbs connected to one pack at a time as I worked in the shop on other projects.
My wife came out and we were talking and POP . What the???? There was a bunch of debris spread around the lipo I was discharging.
One cell had gotten so much pressure that it popped. Some may argue that it exploded but to me an explosion would have been coupled with fire; this was not.
So, always remember, when discharging a pack to zero, do it S L O W L Y.
Anyhow, here is a couple pictures I took. First one was the one that popped, the second one was the next pack venting.
Rick
rampman is offline Find More Posts by rampman
Old Dec 23, 2011, 10:30 PM
WadesRC is offline
Find More Posts by WadesRC
Got Another Prop?
WadesRC's Avatar
United States, VA, Hampton
Joined Aug 2006
Rick
Yulp, I’m scared to asked. . . . .
“SLOWLY discharge an old lipo” “On a good pack this strip will discharge at >32 amps. WHOOPPPIIIEEEEE”
WadesRC is offline Find More Posts by WadesRC
Old Dec 26, 2011, 09:19 PM
Joined May 2011
Rick
The definition of an explosion is the release of built up gas pressure. The best way to do that is with the conversion of a solid or liquid into a gas. Fire works well. Try pool acid and aluminum in a 2 liter bottle and you have a dangerous explosion with no fire. BURN GUNPOWDER IN THE OPEN AND YOU HAVE A RELATIVELY SLOW FIRE. Put it in a chamber and you have an explosion. C4 was used by special forces for heating food. You did have an explosion.
Old Dec 27, 2011, 05:32 PM
like a rock!
Finland
Joined Oct 2007
erm...
When dealing with gunpowder etc, you draw the line between deflagration and detonation. The latter is when the process propagages through the shock wave. Also on the Wikipedia page for "explosion", the words "shock wave" and "extreme manner" appear in the first paragraph.
All this has no connection whatsoever with LiPos. There is no shock wave, no rapid propagation of a flame front etc. I don't think mixing gunpowder and LiPos as an example will help anybody. They have very little in common.
Well, if the LiPo goes "pop" and you don't call it an "explosion", you'll have at least my vote for sure.
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 27 Aug 27, 2014 06:26 AM
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 09:46 PM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 12:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 08:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 10:00 PM
