This thread is privately moderated by roballoba, who may elect to delete unwanted replies.
Old Feb 23, 2008, 04:23 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
I am so glad I haven't had a lipo fire. Seeing all those ruined planes almost makes me want to go out and buy a clay pot an fill it with sand. Right now, I only have 1 910 mah lipo that I'm using in my foamie. I monitor that thing like a security camera watches its post.
I have had a 2100 have to many amps drawn out of it. It just quit on me, and decided to puff up. Another 2100 had the corner smashed in when a flight didn't go as expected. Nothing major happened, like puffing up, or even getting warm.
Xpress.. is offline Find More Posts by Xpress..
Old Feb 27, 2008, 07:07 AM
Bogomir67 is offline
Find More Posts by Bogomir67
I'll frame U!
Bogomir67's Avatar
Joined Aug 2006
When you say "see all those ruined planes", consider if there are all that many. A lot more other (destructive) things happen to planes, like bad servo plugs, loose motor mounts, etc. I am sure that a lot more planes went up in smoke from spilled nitromethane than from lipo fires.
Bogomir67 is offline Find More Posts by Bogomir67
Old Feb 27, 2008, 10:03 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
loss of a glow powered model to fire is so rare I have never seen it happen and I have flown RC for over twenty years. Have I seen a fire in an E-powered model , as the wattage goes up, so do the risks of fire
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 02, 2008, 10:21 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Glow aircraft fires are exceedingly rare, like the previous poster mentioned.
I have seen exactly two in 40 years of extensive modeling. I had a small control line model catch on fire while starting and burn the covering off, in the 1960s.
I have seen one R/C glow model burn after a crash...the alcohol fires are nearly invisible, but the smoke is not.. (RX battery was undamaged and ejected from the crash, so it was not battery induced)
Lipos have, by far, the greated possibility of a fire happening during use, except for a good turbine jet crash.....
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Mar 03, 2008, 12:51 PM
shane55 is offline
Find More Posts by shane55
Ireland
Lipo storage (1 min 34 sec)
I found this video on you tube. Not being able to leave these batteries unattended while charging is a nuisance. is anyone of the opinion that if they are being charged in a fireproof container it is ok to leave them unattended?
shane55 is offline Find More Posts by shane55
Old Mar 03, 2008, 04:51 PM
Rob_G is offline
Find More Posts by Rob_G
Regina, SK
Joined Nov 2006
Pete
How about this one? Make sure you have your sound turned on.
http://www.youtube.com/watch?v=OeTDaWf6fps
Rob
Rob_G is offline Find More Posts by Rob_G
Old Mar 03, 2008, 04:55 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Bad link....
hoppy is offline Find More Posts by hoppy
Old Mar 03, 2008, 04:57 PM
Rob_G is offline
Regina, SK
Joined Nov 2006
Originally Posted by hoppy
Bad link....
It's not bad, it's just that youtube won't allow it to be embedded/linked for some reason.
Rob
Fuegodeth is offline
Find More Posts by Fuegodeth
Go ahead... Build it to crash!
Fuegodeth's Avatar
Conroe, TX
Joined Apr 2007
Here's my take on it, and mine alone. Do what you will, but I'm not responsible.
If the lipo goes off, there is nothing you can do to stop it. So, whether you are there or not is actually not going to matter much, unless you are there with the right kind of fire extinguisher in your hands. So, you might as well always charge in a fireproof container whether you are going to stand around and observe it or not. Just because you are there, don't assume you can charge without any fire protection, as they tend to move around shooting flames out, so anything flammable nearby is going to be messed up. So, no matter what, fire proof container unless you charge outside in the desert or something. The other thing is that the smoke is horrible and very corrosive. If it is in your house or garage, then you will suffer much smoke damage even if you are there with a fire extinguisher to put it out. You are better off making sure that you are able to charge safely if you are there or not. Especially since according the murphys law, the thing will only ignite when you are called inside to answer the phone or do something for the wife. You can sit around and charge all day, and the 1 minute you leave is when the fire will happen. So, you might as well secure your charging area pretty well, and not have anything in the area that you care too much about, except of course for the charger. I think that just like forest fires, STD's and teen pregnancy, the best bet is prevention. Make sure your cells are well taken care of. Know your charger, and never assume anything about the settings. I use a cellpro 4s, because I can't screw it up. I charge in a large clay flower pot, sitting on a clay base, and then I have a base from a larger flower pot to sit on top. It will contain fire very nicely. There's nothing I've seen yet to stop the smoke. What I would really like to do would be to build a small brick or cinder block bunker to charge in, so everything is protected from rain and all that, but no smoke or fire can possibly damage the house. or have a small fire proof enclosure in the garage than vents out to the outside by a fan with a duct, so no smoke can damage anything. That's an expensive and cumbersome way to go, and not likely to happen, unless I win the lottery and build a mega-house. Then I would have a workshop with one of those vent hoods for doing nasty chemical reactions in, like in chem class. Lots of ventilation. Sealed in cabinet with plexiglass windows, with the thick gloves mounted in them.
That's probably about the only thing that could ever truly be considered safe. Just having them in the house or car is a risk. However, life is not without risks. We are probably much more likely to slip in the tub and die than to ever experience a lipo fire firsthand.
Fuegodeth is offline Find More Posts by Fuegodeth
Old Mar 04, 2008, 08:10 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Very well stated. That sums it up very nicely.
I think I'll add it to my list of Informational Threads if you don't mind. http://www.rcgroups.com/forums/showp...06&postcount=8
Old Mar 04, 2008, 09:06 AM
Fuegodeth's Avatar
Conroe, TX
Joined Apr 2007
Certainly fine with me
Old Mar 05, 2008, 12:27 PM
I'll frame U!
Bogomir67's Avatar
Joined Aug 2006
@Fuegodeth:
The only thing I don't understand in your post ist the acronym "STD", but anything else is a big thumbs up from me.
As with motorcycle accidents, most lipo fires are due to missuse, like wrong charger settings etc.
As for nitro fires... I fly models for about 30 years now and have seen at least 10 of those. Mostly they came from refueling while the motor was running, probably spilleage on the manifold and then som cause of ignition (I never saw one in theair, though). I never was anywhere near the fires. And again: It's not the nitro that's dangerous - its the careless people handling it.
Now what is STD, anyway? I know one horrible thing always to avoid, but that's called "Ford LTD"
Old Mar 05, 2008, 01:27 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
@Fuegodeth:
http://www.google.com/search?q=acron...ient=firefox-a
Old Mar 05, 2008, 02:54 PM
Fuegodeth's Avatar
Conroe, TX
Joined Apr 2007
@Fuegodeth:
I see hoppy already covered that. Thanks much. I didn't want to have to get into a detailed explanation. From what the news is saying, with the advent of viagra and such, they are now a rampant problem for elderly nursing home populations. Much scarier than a mere lipo fire, or at least that aspect is. wouldn't want to be a doctor in one of those places.
Old Mar 05, 2008, 08:56 PM
Allenkolo is offline
Find More Posts by Allenkolo
Kindly for the power
Joined Mar 2008
I guess may be you friend overcharged the battery!!!
just possible!!
Allenkolo is offline Find More Posts by Allenkolo
Can Triton temp. sensor prevent Lipo fires?? duganderson Batteries and Chargers 27 Aug 27, 2014 06:26 AM
How Prevalent Are Lipo Fires? DLC Batteries and Chargers 32 Sep 27, 2009 09:46 PM
Lipo Test are in tallflyer Parkflyers 0 Aug 26, 2003 12:09 PM
Question How Lipo's are rated electron_head Batteries and Chargers 6 Jun 30, 2003 08:58 PM
UK E Zoners are real people.... tim hooper Electric Plane Talk 13 May 01, 2001 10:00 PM
