Old Nov 18, 2002, 09:50 AM
devmonkey is offline
Find More Posts by devmonkey
United Kingdom, England, Surrey
Joined Aug 2002
That looks great, i'm going to build one of these.
How do you keep the windings from touching the rotor, or are they completely solid after you have CA'd them together? If so how do you get the kitchen wrap out after building the windings?
I'm interested to know how your sensorless controller senses, since I can't see when the coil would not be energised during a single rotation, and being single phase you do not have a spare phase for feedback.
Stu:
Where did you see that magnet? i'd like order some of them.
This is very exciting for a lightweight ultra high kv edf motor. And the controller is very simple and cheap.
btw, do any of you guys know how to build a switched reluctance motor. It is supposed to be fairly simple, but i've found no diy pages on the subject.
Cheers
Joe
devmonkey is offline Find More Posts by devmonkey
Old Nov 18, 2002, 04:10 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally posted by stumax
... I found a source of 12mm dia x 32 mm long with 5mm hole, polarised across the diameter, quite inexpensive, but not high temp grade NdFeB ...
Hi Stu, where do you get your magnets from?
Met vriendelijke groet Ron van Sommeren
homebuilt e-motor discussion group.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Nov 18, 2002, 04:43 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Joe and Ron, I found a company called Dexter Magnetic Technologies www.dextermag.com . The part number is PN36A1284B, you'll find it if you click on "permanent magnets" then "neodymium iron boron" the scroll down until you find "rings". The part is listed there. Joe, as far as switched reluctance motors go you'll be on your own. I intend to make one as I believe the they will replace our permanent magnet motors one day. They offer significant benefits in terms of power density due to the rotor being made with teeth rather than solid (even though iron is more dense then NdFeB) but the most significant thing for all of us tinkerers is that there are no magnets to buy and fry when things get too hot. The down side is the horrible noise they make and the vibration (allegedly). You won't be able to use a brushless controller so there's another project in it's own right. They are gaining poularity in industry so it wont be long until there are driver chips available, but I think most of them will be for 5 or six poles. When I do my 2 pole single phase brushless I shall be trying a two pole switched reluctance rotor as well, I'll keep you posted if you like. cheers, Stu.
stumax is offline Find More Posts by stumax
Old Nov 19, 2002, 08:12 AM
Joined Aug 2002
I'd be really interested in how your switched reluctance motor turns out, I think you could use the same sensored controller you build for the single phase brushless.
I've thought about using the armature minus its windings (with a suitable number of poles) from a brushed dc motor for the rotor. However I think you also need to have iron in the windings to get any efficiency out of the design.
I really like the simplicity of the slotless design being described here. Just wish there was an 'idiots guide' to putting one together.
Joe
Old Nov 19, 2002, 09:02 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Wow takao!
Thanks alot for the schematics, it was exactly what I needed. I will be trying this soon. You are obviously very smart, jeez, that is incredible for someone only working on thier hobby. I can't imagine what you design at your job!
Again Thanks!
zagisrule! is offline Find More Posts by zagisrule!
Old Dec 30, 2002, 12:03 PM
Takao Shimizu is online now
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Experimentation.
I tested this system.
Efficiency ups about 30%.
The problem is Cx=1000uF($600). I need inexpensive small ceramic high cap.
Takao Shimizu is online now Find More Posts by Takao Shimizu
Old Jan 02, 2003, 08:45 PM
Tokyo, Japan
Joined Nov 2002
Simplest motor
You need very low internal resistance battery to drive this.
Because ...
Old Jan 02, 2003, 08:46 PM
Tokyo, Japan
Joined Nov 2002
system works under 50% duty
You must apply the power in short period into the single phase motor.
Old Jan 03, 2003, 06:21 AM
Tokyo, Japan
Joined Nov 2002
Brushless/Sensorless/Coreless driver
You need the crank up for starting.
Old Jan 03, 2003, 06:35 AM
Tokyo, Japan
Joined Nov 2002
Here is the source code.
Old Mar 11, 2005, 05:38 PM
tbitz is offline
Find More Posts by tbitz
Ottawa
Joined Oct 2003
Any new developments on these single phase brushless motors? Last post was over 2 years ago....
tbitz is offline Find More Posts by tbitz
Old Oct 10, 2006, 08:30 AM
aboobacker is offline
Find More Posts by aboobacker
Joined Jan 2005
Takao Shimizu wich web address for you
why dont post simple cdrom motor speed controller without micro controller
market meny ic availabe why dont try
aboobacker is offline Find More Posts by aboobacker
Discussion The case for a single phase brushless jfrickmann Electric Motor Design and Construction 0 Mar 09, 2006 10:02 PM
More power: two controllers driving a single brushless motor Ron van Sommeren Power Systems 9 Aug 02, 2004 07:05 AM
Cool Brushless motor and single conversion Rx dru Power Systems 9 Dec 28, 2003 06:35 PM
