Old Nov 13, 2002, 04:33 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
single phase brushless motor?
For all the motor gurus out there - why hasn't anyone made a single phase brushless motor for models? By single phase, I mean it has a rotor with a north and south pole and just 2 coils diametrically opposed for the stator. For most uses it would not be suitable due to high torque ripple, but for high rpm (such as ducted fan or pylon) I would think it has a lot going for it:
1. All of the coils are energised nearly all of the time, they just reverse polarity as the rotors' pole passes, which means that there is no wasted weight in copper.
2. Stator construction would be a doddle, as there are just two independant coils to wind.
3. The controller only needs to be an H-bridge (two less fets, and correspondingly less gate drive circuitry).
4. One less connector as the motor will now only have two wires coming out of it.
For me, the tricky part would be a reliable starting algorithm in the controller to make sure the thing gets going in the right direction every time (that is if you run it sensorless). Any ideas guys?
regards, Stu.
stumax is offline Find More Posts by stumax
Old Nov 13, 2002, 04:54 PM
jparisse is offline
Find More Posts by jparisse
jparisse's Avatar
Torrance, CA USA
Joined Jan 2001
I believe you hit the nail on the head. With the symmetry of single phase, one must be very creative in the microcontroller / sensor methodology to figure where the magnet is and which coil to pulse and when... It’s probably easier (hence cheaper) to go three phase the way Nikola Tesla intended...
Jeff
jparisse is offline Find More Posts by jparisse
Old Nov 13, 2002, 07:07 PM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Actually, thinking about the starting methods, you could put two hall effect sensors close to each other on the same radius, give the coils a kick and see from the hall sensors which direction the rotor is going (one of them will latch first, triggering an interrupt on the micro), the keep kicking it in the same direction or kick it out of phase to reverse it, then once it's up to speed just run it sensorless
Old Nov 15, 2002, 08:13 PM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Re: single phase brushless motor?
Hi stumax,
This may be yours.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Nov 15, 2002, 08:15 PM
Tokyo, Japan
Joined Nov 2002
This is under development and already flying every Sunday.
Old Nov 15, 2002, 08:17 PM
Tokyo, Japan
Joined Nov 2002
My coil construction. But ....
Old Nov 15, 2002, 08:24 PM
Tokyo, Japan
Joined Nov 2002
over 12kv motor brakes my motor!(80k rpm testing)
Also, the max rpm of my 2mm phi shield bearing is 60krpm.
Old Nov 15, 2002, 08:34 PM
Tokyo, Japan
Joined Nov 2002
Basic driver circuit is here.
http://www.cityfujisawa.ne.jp/~iijima-p/BRA2.htm
shows everthing RC controller(sorry, only Japanese).
Mine is sensorless. But, cannot use folding prop.. Because, never start by itself.
Old Nov 15, 2002, 08:36 PM
Tokyo, Japan
Joined Nov 2002
And Peak current is quite high to drive this.
I am testing Ni-Cd + Li+ hybrid battery since 2 weeks ago.
Old Nov 17, 2002, 06:15 PM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Hi Takao,
great minds think alike! Do you have any test data you would like to share? I'm curious about the efficiency - I think at high speed we should be aiming for around 95% with a slotless stator. I think at high speeds the size of the air gap between rotor and stator may be critical (may have to open it up a bit). What do you use for a rotor magnet? I found a source of 12mm dia x 32 mm long with 5mm hole, polarised across the diameter, quite inexpensive, but not high temp grade NdFeB, and was going to cut the length down to suit. May even cut the magnet into slices and laminate the rotor as per Lehner rotors. I'm currently designing a motor to use in 55mm EDF (my own design, similar to Vasa), hoping to use 3 LiPoly cells and keep the current below 6A. I gather from your info that your motor needs to be pre spun to get running? I've thought of that as an easy way to get developing - hard to get fingers inside an EDF model, though! Keep up the great work, and keep us posted! cheers,
Stu.
Old Nov 17, 2002, 08:57 PM
zagisrule! is offline
Find More Posts by zagisrule!
Senior Member
zagisrule!'s Avatar
Edgewood, NM
Joined Jan 2002
Takao,
What Hall Effect sensor, and transistors are you using ( I would like to know the company that makes them and the part number please)? I am thinking about trying this as well.
Thanks Alot!
zagisrule! is offline Find More Posts by zagisrule!
Old Nov 17, 2002, 10:59 PM
Tokyo, Japan
Joined Nov 2002
Hi stumax,
As you know, the single pole motor needs very low internal resistance battery, because there is only two times to feed the energy in a round.
I am developing the new method for this motor to increase the efficiency(with same prop., 30% up!).
(But, I have no measuring system for output power?!)
I used the kitchen wrapping rotor magnet for CA glue coil before wind. You can wind it in 5 min.
I got it from broken small brush coreless motor, NdFeB.
Sounds great! Get it ASAP. You can enjoy your design.
Open case makes no trouble for heat-up with prop.
There are a lot of ideas for self-start 2-pole motor with hall dev., except sensor less type.
Old Nov 17, 2002, 11:15 PM
Tokyo, Japan
Joined Nov 2002
Single pole motor driver schematic
zagisrule,
All hardware info. is here.
Old Nov 18, 2002, 12:38 AM
S55 is offline
S55
Find More Posts by S55
S55
S55's Avatar
Beaverton, OR, USA
Joined Feb 2001
Takao,
Could you please explain in more details how the coil is done and secured to the stator? Pictures would help.
Thank you,
S55
S55 is offline Find More Posts by S55
Old Nov 18, 2002, 07:56 AM
Tokyo, Japan
Joined Nov 2002
There are a lot of no-hows.
Originally posted by Takao Shimizu
Do not ask me anymore to make this simple motor?!
Discussion The case for a single phase brushless jfrickmann Electric Motor Design and Construction 0 Mar 09, 2006 09:02 PM
More power: two controllers driving a single brushless motor Ron van Sommeren Power Systems 9 Aug 02, 2004 06:05 AM
Cool Brushless motor and single conversion Rx dru Power Systems 9 Dec 28, 2003 05:35 PM
