Old Jul 26, 2007, 03:19 PM
FedericoA is offline
Find More Posts by FedericoA
Italy, Sicily, Palermo
Joined Sep 2006
Help after a minor crash my gyro e-sky is not working
After about 10 flights with my king 2 i had a minor crash for wind causing one blade broke...no others damages....
After i replace with new blades the gyro light was blinking first red than fixed red and not green light.
I tryied to make the heli fly but had difficulties on making take off.....
VERY SAD ......
Please help.....
FedericoA is offline Find More Posts by FedericoA
Old Jul 26, 2007, 06:12 PM
chrise2 is offline
Find More Posts by chrise2
Too dumb to upload an avatar.
chrise2's Avatar
On the LIRR somewhere
Joined Jan 2007
Do you have the 704 gyro that comes with the RTF version? If so, solid red is correct. There is no green light like the manual says. I'm sure your problem is not with the gyro, but you banged up something in your rotor head. There's a shaft that connects the main blade grips to each other called the feathering shaft. It bends super easy. If its bent, bad stuff happens. You need to take the shaft out and bend it straight or get a new one. It doesn't need to be super straight, just as best as you can. You should also re-trim the entire heli (balance the blades, check the pitches of the paddles and blades)
chrise2 is offline Find More Posts by chrise2
Old Jul 28, 2007, 06:10 AM
Joined Sep 2006
thank you for you replay.....I will check and let you know......
Eclipse and 401 gyro -5th channel not working JoeR Hitec/Multiplex USA 6 Jan 19, 2006 09:33 AM
Help! Why is my JR XP8103 radio not working?!!! asmokindeal Electric Plane Talk 6 Apr 22, 2004 03:01 AM
Can someone help me with my TX/RX? It's not working... TurboRacer Radios 5 Aug 19, 2003 08:12 AM
Logo 10 questions.after minor crash skypup Electric Heli Talk 10 Feb 16, 2003 11:21 AM
