Old Jul 25, 2007, 02:47 PM
stereotype is offline
Find More Posts by stereotype
Joined Oct 2006
Electric motor problem
I have a small drilling machine driven by a 1/4 HP induction motor (British) sometimes it fails to start and just hums, if I switch off and try again normally it runs. This happens not on a regular basis, sometimes it goes for days OK then plays up. Is there some sort of maintenance needed? David
stereotype is offline Find More Posts by stereotype
Old Jul 25, 2007, 03:43 PM
John Stevenson
John Stevenson
Guest
n/a Posts
Re: Electric motor problem
On Wed, 25 Jul 2007 14:47:15 -0500, stereotype
What tune does it hum ?
Old Jul 25, 2007, 03:45 PM
dave sanderson
dave sanderson
Guest
n/a Posts
sounds like the start /run cap is on its way out. when its not working
if you spin it up by hand does it run?
new caps are quite cheap.
of course I could be wrong, no doubt someone more knowledgeable will
be along shortly.
Dave
Old Jul 25, 2007, 04:25 PM
ChrisQuayle
ChrisQuayle
Guest
n/a Posts
Check all the wiring for continuity and tight connections first,
especially the leads that go into the motor terminals. They can
sometimes work loose on older motors. As someone else said, after that,
it's most likely the start capacitor, or it's wiring...
Chris
Old Jul 25, 2007, 10:56 PM
Don Young
Don Young
Guest
n/a Posts
"stereotype" <stereotype.2uansn@rcgroups.com> wrote in message
news:stereotype.2uansn@rcgroups.com...
> stereotype
> stereotype's Profile: http://www.rcgroups.com/forums/member.php?u=119209
> View this thread: http://www.rcgroups.com/forums/showthread.php?t=718458
If it has a centrifugal starting switch (you can hear a click when it starts
and again when it is nearly stopped) the switch contacts and the mechanism
to operate it can be in need of cleaning. This usually requires disassembly
of the motor. No lubrication is normally used.
Don Young, USA
Old Jul 26, 2007, 06:09 AM
MikeH_QB
MikeH_QB
Guest
n/a Posts
> stereotype
> stereotype's Profile:http://www.rcgroups.com/forums/member.php?u=119209
> View this thread:http://www.rcgroups.com/forums/showthread.php?t=718458
Pretty sure it the cap that's getting old & 'leaky'. Hasn't failed
altogether as it would never start or possibly blow mains fuse. They
just get a bit worn out sometimes. Your cheapest and quickest option
is to replace the cap, they don't cost much and are (normally)
external so dead easy to get access to & replace. Tip - just be
careful fiddling with any connections if you have recently attempted
to start it, as the cap may hold a nasty residual charge which might
make your hair stand on end, eyes light up and teeth rattle a bit!
Old Jul 26, 2007, 12:40 PM
David Powell
David Powell
Guest
n/a Posts
In article <vhdfa350t18719r9nnm80r98vlv2b2ccg7@4ax.com>,
John Stevenson <john@stevenson-engineers.co.uk> in
Anything, it doesn't know the words, so it has to hum.
Regards,
David P.
Old Jul 26, 2007, 02:21 PM
Joined Oct 2006
> stereotype
Don Young, USA
Thanks for all your input, yes Don it is a cetrifugal start motor, i'll take it apart and check the contacts. David
Old Jul 28, 2007, 02:21 PM
eskimobob
eskimobob
Guest
n/a Posts
I have this problem on two bits of kit I have just bought second
hand. I can clearly hear that the centrifugal switch does not always
'click' back in when the motor stops so I assume that some lubrication
is required. I'm planning on investigating further when I get some
enthusiasm...
Old Jul 28, 2007, 09:01 PM
Don Young
Don Young
Guest
n/a Posts
"eskimobob" <martinberriman@gmail.com> wrote in message
news:1185650472.389200.142730@b79g2000hse.googlegr oups.com...
> enthusiasm...
I think cleaning is called for but I do not think that these mechanisms are
generally lubricated. It might be ok in an enclosed motor where the dirt is
kept out if no lubricant gets on the switch contacts.
Don Young, USA
Old Jul 29, 2007, 04:42 AM
Bob Minchin
Bob Minchin
Guest
n/a Posts
> enthusiasm...
Lubrication is normally the enemy of these switches as it harbours dirt.
Complete cleanliness is normally the the best way IMHO
Bob
Old Aug 16, 2011, 12:19 PM
Emimec
Emimec
Guest
n/a Posts
Firstly, lets establish that I am not an electrician..........
I have a pedestal drill, 3 phase, with a Memota (MEM) push button starter
(NVR). Motor is the common "Hoover" style 1/3 or 1/2 horse, cant remember
which.
The motor does not start on its own, you have to "spin" the chuck to get it
to go under its own steam (Electric). Also, the motor seems to lack any real
"guts", it will stop rotating fairly easily. The motor case seems to get
reasonably hot to the touch.
This drill is only used for countersinking 16mm dia full depth in a pre
drilled 10.5mm hole in mild steel. Its common to do a batch of 70+
countersinks in a session.
Would I be right in thinking 1 phase has gone down ?, if so, does it point
to the motor or the starter ? Is there a test I can make to eliminate one or
the other, or does my description of the problem already do this to the
experienced person ?
A volt meter shows all 3 phases coming in to the starter from the supply
source.
Help/advice most appreciated
Bob
Old Aug 16, 2011, 01:26 PM
Mark Rand
Mark Rand
Guest
n/a Posts
On Tue, 16 Aug 2011 18:19:37 +0100, "Emimec" <emimec.19@NOSPAMbtinternet.com>
>source.
>Bob
Sounds like you've got an open circuit phase in the starter or motor.
In order or simplicity:-
Take the junction box cover off the motor and remove the wires coming from the
starter. Arrange them so they won't touch anything (insulting tape, bit of
wood, whatever...). Measure the voltage between said wires when starter is on.
That'll tell you if it's the starter or the motor. If the meter has got a
resistance range, measure the coil winding resistances. Measure between phase
and star point if visible. otherwise, measure phase to phase. Noticeable
differences between the three readings will indicate an open circuit.
Taking the non-drive end off the motor and looking at the windings will
indicate major magic smoke escape.
Regards
Mark Rand
RTFM
Old Aug 16, 2011, 02:32 PM
Emimec
Emimec
Guest
n/a Posts
"Mark Rand" <randm@internettie.co.uk> wrote in message
news:ancl475k5jpg9rpaviu5rf6m5ups8civp6@4ax.com...
>>or
>>source.
>>Bob
> the
> on.
> phase
> Regards
> Mark Rand
> RTFM
Many Thanks.
Will do this Saturday morning.
Bob
AXI electric motor problem slowstick4ap Power Systems 3 Oct 15, 2005 05:45 PM
Electric Motor Throttle Problem joeg123 Batteries and Chargers 6 Jul 03, 2005 07:55 PM
Sky Scooter Motor Problem tic Beginner Training Area (Aircraft-Electric) 5 Jul 09, 2001 11:01 AM
Aveox motor problem (shaft moving back)? rcdude Electric Plane Talk 1 May 20, 2001 06:11 PM
