Old Nov 13, 2002, 03:41 AM
Takao Shimizu is offline
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Dual conversion PPM receiver schematic
This is my Rx for my plane.
Takao Shimizu is offline Find More Posts by Takao Shimizu
Old Nov 13, 2002, 05:03 AM
jandirks is offline
Find More Posts by jandirks
Amersfoort, The Netherlands
Joined May 2002
Hi,
Interesting, any info on weight and building costs? Do you have a PCB for it?
Regards,
Jan-Dirk
jandirks is offline Find More Posts by jandirks
Old Nov 13, 2002, 06:03 AM
Tokyo, Japan
Joined Nov 2002
Jan-Dirk;
Left one is dual conversion, Right one is direct(NOT Single) conversion Rx.
Top Secrect as you see!?
Old Nov 14, 2002, 05:07 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I like your use of the RSSI output to set the detect threshold of the decoded data. Is this something that you thought up on your own? This looks {to me} like a better way than the RC integrator method.
And speaking of the RSSI output, here is an idea for you. Extend the buffered output to a 2-pin connector. Now, when you are range testing at the field, just plug in your DVM or a custom LED bargraph display to accurately see the RF strength. Sure beats waiting for servos to glitch.
Regards,
Mr. RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Nov 15, 2002, 01:44 AM
Tokyo, Japan
Joined Nov 2002
Mr.RC-CAM,
Not my idea.
The slicer digital output has a lot of FM noise while no RF signal coming at this Rx. But, the shift register carry out all FM pulsed noise.
That is why I used 74164+pulse omittion circuit.
Old Nov 16, 2002, 11:13 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Thanks for the additional info. Please keep us informed on your progress.
By the way, point "B" on the schematic is actually VCC. It belongs on the signal line going to U3 pin 1-2 (or so I believe).
Regards,
Mr. RC-CAM
Old Nov 17, 2002, 09:39 PM
Tokyo, Japan
Joined Nov 2002
I edit it.
Thanks Mr.RC-CAM,
I edit the schematic.
Have you think about R17 delay circuit on my schematic, anyway?
Takao
Old Nov 17, 2002, 10:32 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I have seen that RC circuitry trickery on other R/C designs and it works well. Here is another home brew Rx that uses a variation of it:
http://home.nordnet.fr/~fthobois/anglais/rx17-b.htm
I was most interested in your use of the RSSI output to manage the signal offset voltage level. I think that is a wonderful idea.
Regards,
Mr. RC-CAM
Old Jan 07, 2012, 09:38 AM
mikeclair is offline
Find More Posts by mikeclair
Joined Jan 2012
Does anyone have a Schematic of a 3 or 4 channel receiver?
mikeclair is offline Find More Posts by mikeclair
PCM or Dual Conversion PPM? Hogster Electric Heli Talk 30 Nov 20, 2005 01:17 AM
Sold FMA M5 Sub Micro Dual Conversion FM Receiver w/ Crystal - $40 SHIPPED rongreg13 Aircraft - General - Radio Equipment (FS/W) 1 Aug 31, 2005 01:05 AM
Futaba & Airtronics Dual Conversion Transmitter Receiver Crystal ch 13 24 38 DPage Aircraft - General - Radio Equipment (FS/W) 0 Mar 26, 2005 06:54 AM
Futaba R127DF Dual-Conversion 7ch receiver: $25 shipped meteor Aircraft - Electric - Airplanes (FS/W) 4 Apr 23, 2004 06:48 PM
Hitec Dual Conversion FM Receiver Crystal for Ch 60 J R Purcell Aircraft - Electric - Airplanes (FS/W) 4 Mar 26, 2002 02:49 PM
