Old Jul 24, 2007, 11:48 AM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
Parkzone Micro Cessna: Life expectancy?
One of the biggest problems with these micro planes and copters is that the motors and batteries work hard and live short lives.
Assuming average treatment, how many flights do you think you can get out of this plane before it croaks?
What parts will go first? Has anyone had to replace/repair anything yet? How did it go?
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Jul 24, 2007, 11:56 AM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
well i dont know, but its really important to cycle teh battery for about 3-5 times, and brake in teh motor on lowthrottle/low voltage for about 7-10hours, that will give it longer life time and better performance
ihor14448 is offline Find More Posts by ihor14448
Old Jul 24, 2007, 12:19 PM
Hauntme13 is offline
Find More Posts by Hauntme13
Vernonia, OR
Joined Mar 2004
And unlike the cheapies (aeroace and the like), you can order the parts separately.
Parts
Hauntme13 is offline Find More Posts by Hauntme13
Old Jul 24, 2007, 12:39 PM
Joined Jun 2005
What? You have to buy the whole fuselage for $60 to replace the motor?
Old Jul 24, 2007, 12:44 PM
Vernonia, OR
Joined Mar 2004
Read the page:
Main Motor: Cessna 210 Centurion
$8.99 [PKZ3016]
Gear Box w/Motor: Cessna 210 Centurion
$13.29 [PKZ3028]
Old Jul 24, 2007, 01:07 PM
Torx is offline
Find More Posts by Torx
Torx's Avatar
United States, TN, Memphis
Joined Apr 2007
i was thinking about this too, its a very high price item and life expectancy/replacable parts should very well be considered.
Torx is offline Find More Posts by Torx
Old Jul 24, 2007, 01:24 PM
bluemeane is offline
Find More Posts by bluemeane
bluemeane's Avatar
Joined Apr 2007
ummmmm, 7-10 hours???
doesnt that seem a little overboard????
thats like 28 to 40 battery cycles run through it....
bluemeane is offline Find More Posts by bluemeane
Old Jul 24, 2007, 03:44 PM
modfly is online now
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
dude..if you break in a motor for 7-10 hours at any throttle it will be worn out!
I don't do any of that motor break in foolishness...take a few apart, you will see all this does is wear out the brushes!
modfly is online now Find More Posts by modfly
Old Jul 24, 2007, 03:47 PM
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
you dont..you simply hack the old one out and find a suitable replacement..preferally one that is inexpensive..I have a stash of motors that come from toys, gliders flea market junk whatever...
Old Jul 24, 2007, 03:53 PM
hoverboy is offline
Find More Posts by hoverboy
Anything RC
hoverboy's Avatar
Huntington Beach, California
Joined Mar 2005
Breaking in motors!...
I break in all my motors.. for about 5min "only", at low speed!....
Modfly:..is this a waste of time???...or am i really helping it out by not gunning it right off the bat!.....
What about brushless?....any reason to run it for a few minutes first, at low speed?
hoverboy is offline Find More Posts by hoverboy
Old Jul 24, 2007, 04:10 PM
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
nope...waste of time...I have taken hundreds apart and inspected...no reason to break in...best thing to do is not let them get hot as this ruins the brushes...I know I'm gonna get a lot of flak over this..but as an electronic tech..I can tell you there is no good reason to "break in" an electric motor.
edit..ok now some of your larger DC motors with spring loader brush holders and feeds do require break in or seating..but not the motors we use in r\c..I laugh when I read of someone doing the "water break in" utterly useless and damaging to the motor at the very least!
Old Jul 24, 2007, 04:29 PM
circletree is offline
Find More Posts by circletree
circletree's Avatar
United States, SC, Spartanburg
Joined Jan 2007
if the motor is brushed with square carbon brushes and they aren't properly seated to the commutator the leading edge of the brush breaks down, forms brush dust which only helps to grind the comm down even more. slowly running the brushes in matches the radius of the comm to the brush and helps increase efficiency of the brushes. now, the small 380-550 size motors we use don't show great benefit from seating brushes the 1000-2000hp DC motors i normally deal with do!
circletree is offline Find More Posts by circletree
Old Jul 24, 2007, 05:02 PM
spektrumdss is offline
Find More Posts by spektrumdss
Dam,I done spilt my drink
Peoria Il
Joined Jun 2007
I break them in slightly,I figure it dosnt hurt so why not.
spektrumdss is offline Find More Posts by spektrumdss
Old Jul 25, 2007, 12:32 AM
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
yea..I'm referring to r\c motors not industrial grade 1,2khp motors..
Old Jul 25, 2007, 01:53 AM
relaxr is offline
Find More Posts by relaxr
RC-Kraut
relaxr's Avatar
Joined Feb 2006
Asked myself also about life expectancy:
-the frame is delicate, one hard crash and the wing or tail may be damaged heavily, but can be fixed easily. Also spare parts are available
-pagermotor: imho the most critical part. I have not too much confidence in them. From the xtwins (comparable size, comparable quality???) I know some die after minutes some after around 10-20 hours. For me the critical point of this plane. I startet in first flights with 1/2 throttle max., if it helps - I dont know.
-Rx : depends on its construction of servos (pagers, see above...) and the motors ESC. Anyone did some electronic tests? Hopefully its well designed (?).
-Lipo: is charged with around 3C, will last for some time (200 cycles?). Can be exchanged for rel. low money. Classic wearout part.
Experience and time will help, as no defects are reported up to now I am hoping for long fun with it, without fixing things.
CU
relaxr is offline Find More Posts by relaxr
Discussion 15" Parkzone Micro Cessna 210 flyingace451 Micro Ready-to-Fly 16 Aug 09, 2007 04:11 PM
Discussion Parkzone Micro Cessna Pro? Smokescreen38 Micro Ready-to-Fly 19 Jul 27, 2007 08:05 PM
Discussion parkzone Micro Cessna 210 RTF mecevans Micro Ready-to-Fly 7 Apr 30, 2007 01:14 AM
Alert Parkzone Micro Cessna Hugequark Scratchbuilt Indoor and Micro Models 28 Apr 18, 2007 01:38 PM
New Product parkzone micro cessna gunracer Parkflyers 18 Apr 16, 2007 05:01 PM
